    Show or Hide Object in Viewport
    2024python
    4 Posts 3 Posters 1.5k Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      I encountered some issues when importing documents and performing hide and display object.
      this is an example c4d file to import --> import.c4d
      this is an example script code:
      class MyDialog (c4d.gui.GeDialog):
          def CreateLayout(self) -> bool:
              self.GroupBorderSpace(5, 5, 5, 5)
              self.GroupSpace(5, 5)
              self.AddButton(1000, c4d.BFH_SCALEFIT, name = "import")
              self.AddButton(1001, c4d.BFH_SCALEFIT, name = "show")
              self.AddButton(1002, c4d.BFH_SCALEFIT, name = "hide")
          def Command(self, id, msg):
              if id == 1000:
                  file_path = c4d.storage.LoadDialog()
                  c4d.documents.MergeDocument(doc,file_path,c4d.SCENEFILTER_OBJECTS|c4d.SCENEFILTER_MATERIALS)
                  for obj in doc.GetObjects():
                      obj.ChangeNBit(c4d.NBIT_EHIDE,c4d.NBITCONTROL_SET)
              if id == 1001:
                      obj.ChangeNBit(c4d.NBIT_EHIDE,c4d.NBITCONTROL_CLEAR)
                  c4d.DrawViews(c4d.DRAWFLAGS_FORCEFULLREDRAW)
              if id == 1002:
          dlg = MyDialog()
          dlg.Open(c4d.DLG_TYPE_ASYNC, 0, -1, -1, 200, 200)
      Step 1: Use "import" to merge a document into the current document, and then hide the imported object
      Step 2: Use "show" to restore the display of the object, but it will not refresh the display. Only by using the "Redraw" command can the display be refreshed
      Why c4d.EventAdd() and c4d.DrawView() doesn't work, did I miss something?
      It seems to only occur in the document imported for the first time, and when the "show" or "hide" command is used again, it works normally.
      Thanks for any help!
      相信我,可以的!
      gheyretG 1 Reply Last reply Reply Quote 0
      • gheyretG Offline
        gheyret @chuanzhen
        Hi @chuanzhen ,
        This is a Bug and it's already reported, you can find more info in this thread.
        www.boghma.com
        chuanzhenC 1 Reply Last reply Reply Quote 2
          chuanzhen @gheyret
          @gheyret Thanks for your help!👍
          i use "c4d.CallCommand(12147) # Redraw" to replace c4d.EventAdd() or c4d.Redraw(), it also work!
          change code:
                  if id == 1001:
          相信我,可以的!
            Sorry, I am rotating on the spot right now, did not yet get to answering here. @gheyret is right, there is still a bug, will give @m_adam a note on Monday.
