    Python: Detect Plugins
    2024pythonwindows
    12 Posts 3 Posters 2.3k Views 2 Watching
    • J Offline
      JohnThomas
      Hi.
      I am working on a Python project that is browsing through all of the objects and tags in a scene. As part of this I am trying to detect which of the objects and tags are plugins. In addition to this I am trying to detect if any of the things in the scene are Maxon One exclusive content.
      For a brute force method I know that I can compare the id of a given object or tag against a list of ids to tell if one of them is a plugin but I don't have a way of knowing if something is a plugin that I don't know the id of. I'm not overly familiar with Maxon One content but I assume that the same kind of method would apply for brute force detecting.
      So in summary my question is, is there a way to detect if a given object or tag in the scene is a plugin or Maxon One content that is not just comparing a list of ids against all of the content in a scene?
      Any help would be greatly appreciated,
      John Thomas
      • M Offline
        m_adam
        Hi @JohnThomas, I will have a deeper look at it next week, but its seems to me that for the moment is not possible to detect if a capsule is coming from Maxon One.
        With that's said, you can detect if a BaseList2D is python based by looking at the file path the plugin is registered from.
        def HierarchyIterator(bl2d):
            while bl2d:
                yield bl2d
                for opChild in HierarchyIterator(bl2d.GetDown()):
                    yield opChild
                bl2d = bl2d.GetNext()
        def IsPythonPlugin(bl2d):
            basePlugin = c4d.plugins.FindPlugin(bl2d.GetType())
            pluginFile = basePlugin.GetFilename()
            return pluginFile.endswith("pyp") or pluginFile.endswith("pypv") or pluginFile.endswith("pype")
            for obj in HierarchyIterator(doc.GetFirstObject()):
                print(IsPythonPlugin(obj))
        ThomasBT 1 Reply Last reply Reply Quote 0
        • J Offline
          JohnThomas
          Thanks for the response.
          Your code seems to work for Python plugins but is there a way to detect if something is a plugin for an xdl64 or xlib. I know that I could just check if the plugin ends with either of those but a Cube also counts as a plugin with either an xdl64 or xlib. Is there a way to tell if it is a Cinema plugin in this way or a user added one?
          With the Maxon One question, is there a way to tell if a scene is Maxon One dependent without being able to detect a Maxon One object specifically?
          John Thomas
          • ThomasBT Offline
            ThomasB @m_adam
            @m_adam
            Sorry, little question, what does the python extenstion "pype" mean?
            Thanks,
            T.B
            • M Offline
              m_adam
              Hi John Thomas, sorry I missed your reply, you can do the same by checking if the path is not part of the "corelibs" folder or the Redshift one.
              Find bellow an example bellow, I just did a string comparison, for a safer approach you will need to compare with the absolute path.
                  while bl2d:
                      yield bl2d
                          yield opChild
              def isCppPlugins(bl2d):
                  if IsPythonPlugin(bl2d):
                      return False
                  return not ("corelibs" in pluginFile or "Redshift" in pluginFile)
                      print(IsPythonPlugin(obj), isCppPlugins(obj))
              @ThomasB pype is the old encryption file format for python plugin file (you can't create them since R16 but you can still load them).
              • J Offline
                JohnThomas
                Thanks for the response, the code seems to work as hoped for detecting a plugin.
                Have you had a chance to look into detecting a Maxon One capsule?
                John Thomas
                • J Offline
                  JohnThomas
                  Any luck with detecting Maxon One?
                  John Thomas
                  • J Offline
                    JohnThomas
                    John Thomas
                    • M Offline
                      m_adam
                      Hi @JohnThomas first of all you will only be able to add Maxon One assets in the Cinema 4D instance that has Maxon One. If you do not have Maxon One you will still see Maxon One assets in the asset browser, and you can find their asset description and get their meta data but you cant load the asset.
                      With that's said the license information about an asset is stored in it's asset description meta data. You can get the license information about any asset like so:
                      import maxon
                      class ASSETLICENSETYPE:
                          ALLBITS = (1 << 30) | ((1 << 0) | (1 << 2) | (1 << 4) | (1 << 6) | (1 << 8) | (1 << 10) | (1 << 12)) | ((1 << 1) | (1 << 3) | (1 << 5) | (1 << 7) | (1 << 9) | (1 << 11) | (1 << 13))
                          ENABLE_IN_ALL = (1 << 0) | (1 << 2) | (1 << 4) | (1 << 6) | (1 << 8) | (1 << 10) | (1 << 12)
                          ENABLE_IN_CINEWARE = 1 << 12
                          ENABLE_IN_EDUCATION = 1 << 10
                          ENABLE_IN_LITE = 1 << 6
                          ENABLE_IN_PERPETUAL = 1 << 2
                          ENABLE_IN_STUDENT = 1 << 8
                          ENABLE_IN_SUBSCRIPTION = 1 << 0
                          ENABLE_IN_TRIAL = 1 << 4
                          NONE = 0
                          ONLY_IN_MAXONONE = 1 << 30
                          SHOW_IN_ALL = (1 << 1) | (1 << 3) | (1 << 5) | (1 << 7) | (1 << 9) | (1 << 11) | (1 << 13)
                          SHOW_IN_CINEWARE = 1 << 13
                          SHOW_IN_EDUCATION = 1 << 11
                          SHOW_IN_LITE = 1 << 7
                          SHOW_IN_PERPETUAL = 1 << 3
                          SHOW_IN_STUDENT = 1 << 9
                          SHOW_IN_SUBSCRIPTION = 1 << 1
                          SHOW_IN_TRIAL = 1 << 5
                      def GetAssetDescription(assetId: str) -> maxon.AssetDescription:
                          repository = maxon.AssetInterface.GetUserPrefsRepository()
                          if not repository:
                              raise RuntimeError("Could not access the user preferences repository.")
                          assetDescription = repository.FindLatestAsset(maxon.AssetTypes.File(), assetId, maxon.Id(), maxon.ASSET_FIND_MODE.LATEST)
                              if not assetDescription or assetDescription.IsNullValue():
                                  assetDescription = repository.FindLatestAsset(maxon.AssetTypes.NodeTemplate(), assetId, maxon.Id(), maxon.ASSET_FIND_MODE.LATEST)
                              if not assetDescription:
                                  raise RuntimeError(f"Could not find the '{assetId}' asset.")
                          return assetDescription
                      def TestLicenses(licenses, flag):
                          out = [False] * len(licenses)
                          for i, lic in enumerate(licenses):
                              out[i] = bool(lic & flag)
                          return out
                          everyoneAssetId = "file_faaca247ca4107d0"
                          everyoneAssetDescription = GetAssetDescription(everyoneAssetId)
                          everyoneLicense = everyoneAssetDescription.GetMetaData().Get(maxon.ASSETMETADATA.ValidLicenseType)
                          subscriptionAssetId = "file_e0f13aae45bf949e"
                          subAssetDescription = GetAssetDescription(subscriptionAssetId)
                          subLicense = subAssetDescription.GetMetaData().Get(maxon.ASSETMETADATA.ValidLicenseType)
                          mxOnlyAssetId = "object_6ae75db1dd872ee61a81cc637cf7aa24"
                          mxOnlyAssetDescription = GetAssetDescription(mxOnlyAssetId)
                          mxOnlyLicense = mxOnlyAssetDescription.GetMetaData().Get(maxon.ASSETMETADATA.ValidLicenseType)
                          # Finally test all licenses
                          licenses = [everyoneLicense, subLicense, mxOnlyLicense]
                          inAll = TestLicenses(licenses, ASSETLICENSETYPE.ENABLE_IN_ALL)
                          sub = TestLicenses(licenses, ASSETLICENSETYPE.ENABLE_IN_SUBSCRIPTION)
                          perpetual = TestLicenses(licenses, ASSETLICENSETYPE.ENABLE_IN_PERPETUAL)
                          trial = TestLicenses(licenses, ASSETLICENSETYPE.ENABLE_IN_TRIAL)
                          lite = TestLicenses(licenses, ASSETLICENSETYPE.ENABLE_IN_LITE)
                          student = TestLicenses(licenses, ASSETLICENSETYPE.ENABLE_IN_STUDENT)
                          edu = TestLicenses(licenses, ASSETLICENSETYPE.ENABLE_IN_EDUCATION)
                          cineware = TestLicenses(licenses, ASSETLICENSETYPE.ENABLE_IN_CINEWARE)
                          mxOne = TestLicenses(licenses, ASSETLICENSETYPE.ONLY_IN_MAXONONE)
                              print(f"In All: {inAll[i]}, Subscription: {sub[i]}, Perpetual: {perpetual[i]}, Trial: {trial[i]}, Lite: {lite[i]}, Student: {student[i]}, Education: {edu[i]}, Cineware: {cineware[i]}, Maxon One: {mxOne[i]}")
                      With that's said the main issue is to retrieve the asset id from a given capsule in a scene. All capsules (except nodal but I will come to them latter) when they are inserted into a scene, they become part of the scene as native objects and they are not assets anymore so there is no way to tell if it come from an asset or not.
                      For nodal one it is possible but very hacky for the moment, and while it should work I do not really advice to use it on production. So find bellow a way that will work on 2024.2.0 (only look at the main function the rest are hacks to get it working).
                      import maxon
                          NONE = 0
                      @maxon.MAXON_INTERFACE(maxon.MAXON_REFERENCE_COPY_ON_WRITE, "net.maxon.node.interface.nodetemplate")
                      class NodeTemplateInterface(maxon.AssetInterface):
                          pass
                      @maxon.MAXON_REFERENCE(NodeTemplateInterface)
                      class NodeTemplate(NodeTemplateInterface, maxon.Data):
                          def __new__(cls, *args):
                              return object.__new__(cls)
                      @maxon.MAXON_INTERFACE(maxon.MAXON_REFERENCE_COPY_ON_WRITE, "net.maxon.node.interface.nodesystem")
                      class NodeSystemInterface(maxon.ObjectInterface):
                          @maxon.MAXON_METHOD('net.maxon.node.interface.nodesystem.GetTemplate@c849c0c06c1a1ac5')
                          def GetTemplate(self):
                              pass
                          @maxon.MAXON_METHOD('net.maxon.node.interface.nodesystem.GetAllBases@4292dc8effe69932')
                          def GetAllBases(self):
                              pass
                      @maxon.MAXON_REFERENCE(NodeSystemInterface)
                      class NodeSystem(NodeSystemInterface, maxon.Data):
                      def GetAssetIdFromCapsule(bl2D):
                          allNimbusRef = bl2D.GetAllNimbusRefs()
                          if not allNimbusRef:
                              raise ValueError("The given baselist 2D his is not a capsule")
                          sceneNodeNimbus = allNimbusRef[0][1]
                          graph = sceneNodeNimbus.GetGraph()
                          rootNodeSystem = graph.GetBase(graph.GetRoot())
                          firstNodeSystemBase = [""]
                          def GetFirstNodeSystemBase(nodeSystem):
                              firstNodeSystemBase[0] = nodeSystem.GetTemplate().GetId()
                              return False
                          rootNodeSystem.GetAllBases(GetFirstNodeSystemBase)
                          if not firstNodeSystemBase[0]:
                              return rootNodeSystem.GetTemplate().GetId()
                          return firstNodeSystemBase[0]
                          if not repository:
                      def TestLicenses(lic, flag):
                          return bool(lic & flag)
                          capsuleAssetId = GetAssetIdFromCapsule(op)
                          capsuleAssetDescription = GetAssetDescription(capsuleAssetId)
                          capsuleLicense = capsuleAssetDescription.GetMetaData().Get(maxon.ASSETMETADATA.ValidLicenseType, ASSETLICENSETYPE.NONE)
                          print(f"Asset Id: {capsuleAssetId}")
                          if capsuleLicense != ASSETLICENSETYPE.NONE:
                              # Test the license
                              inAll = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ENABLE_IN_ALL)
                              sub = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ENABLE_IN_SUBSCRIPTION)
                              perpetual = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ENABLE_IN_PERPETUAL)
                              trial = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ENABLE_IN_TRIAL)
                              lite = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ENABLE_IN_LITE)
                              student = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ENABLE_IN_STUDENT)
                              edu = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ENABLE_IN_EDUCATION)
                              cineware = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ENABLE_IN_CINEWARE)
                              mxOne = TestLicenses(capsuleLicense, ASSETLICENSETYPE.ONLY_IN_MAXONONE)
                              print(f"In All: {inAll}, Subscription: {sub}, Perpetual: {perpetual}, Trial: {trial}, Lite: {lite}, Student: {student}, Education: {edu}, Cineware: {cineware}, Maxon One: {mxOne}")
                      For 2024.4 I plan to simplify the asset ID retrieval from a capsule. So thanks for the question and sorry for the delay.
                      J 1 Reply Last reply Reply Quote 1
                      • J Offline
                        JohnThomas @m_adam
                        @m_adam
                        Going through the code you have the line
                        Looking at the sdk the NodeTemplate for AssetTypes first appears in 2024.2. Is there a way to tell if there is a Maxon One asset in 2023 or is this new functionality that isn't possible in older versions?
                        John Thomas
                        • M Offline
                          m_adam
                          Hi correct in the previous version, there was an issue in our parser so this symbol was not exposed to Python.
                          But you can add the next line before
                          maxon.AssetTypes.NodeTemplate = maxon.MAXON_DECLARATION("net.maxon.node.assettype.nodetemplate")
                          • J Offline
                            JohnThomas
                            Thanks for the response. I'll see if this does what I need it to
                            John Thomas
