    Call "Set Deformed Mesh" on Weight Tag
    2024pythonwindows
    2 Posts 2 Posters 837 Views 1 Watching
    • V Offline
      vwgamedev
      Hello, I am currently trying to realize an asset pipeline for our game project that allows us to prepare our characters and clothes for processing in Unity.
      Basically I have found a clean way to do this in Cinema4D that I can do by hand and that leads to success.
      I create a few extra bones that we need and do some renaming. None of this is a big deal. But it is important that we then run the "Set Deformed Mesh". If I do this manually, everything works perfectly, but I just can't find a way to call this function directly in Python. I have found a way to set the button to "Set Deformed Mesh" but this does not "press" it.:
      def apply_deformed_mesh(meshes):
          Apply 'Set Deformed Mesh' on all meshes with weight tags.
          for obj in meshes:
              weight_tag = obj.GetTag(c4d.Tweights)
              if weight_tag:
                  bc = weight_tag.GetDataInstance()
                  # Set the button to 'Set Deformed Mesh'
                  bc.SetInt32(c4d.ID_CA_WEIGHT_TAG_SET_BUTTON, c4d.ID_CA_WEIGHT_TAG_SET_DEFORMED_MESH)
                  weight_tag.Message(c4d.MSG_UPDATE)
          # Update the scene
      Is there a way to execute this command somehow to automate the whole thing?
      • M Offline
        m_adam
        Hi you need to use call button
            for obj in meshes:
                if weight_tag:
                    c4d.CallButton(weight_tag, c4d.ID_CA_WEIGHT_TAG_SET_BUTTON)
            # Update the scene
