    Create Xpresso Python node
    python2024
    3 Posts 2 Posters 787 Views 1 Watching
    • B Offline
      Brakusha
      Hi. I ask you to forgive me for my English. I have to use a translator. My problem is this: I'm trying to create a Xpresso Python node in my script, using a command GvNodeMaster.CreateNode. I`m use node ID_OPERATOR_COFFEE. The node appears in the editor window, but for some reason it is dead, and its title is red. Once created, I can't do anything with the node. Can't fill the script window or anything. I'm creating this node because there was already advice here: to create a Python node, contact the coffee operator. What am I doing wrong?
      Sample code:
      from typing import Optional
      doc: c4d.documents.BaseDocument  # The active document
      op: Optional[c4d.BaseObject]  # The active object, None if unselected
          tag = op.GetTag(c4d.Texpresso)
          nodemaster = tag.GetNodeMaster()
          noderoot = nodemaster.GetRoot()
          mynode = nodemaster.CreateNode(noderoot, c4d.ID_OPERATOR_COFFEE, None, 0, 0)
      • M Offline
        m_adam
        Hi you can create it this way:
            mynode = nodemaster.CreateNode(noderoot, c4d.GVpython, None, 0, 0)
            print(mynode.GetOperatorID() == c4d.GVpython)
        • B Offline
          Brakusha
          WOW!!! It turns out that there is a node specifically for python. But in the documentation, in the list GV Node Types, it is not indicated. This fact forced me to look for workarounds. Thanks for the help
