    Tile rendering with Cinema 4D
    python2026
    7 Posts 2 Posters 1.9k Views 1 Watching
    • K Offline
      karthikbp
      Dear community,
      Is there a recommended way to do tile rendering—dividing a large image into smaller pieces that can be rendered quickly and then reassembled into one final image?
      Current Approach:
      We currently use the "Render Tiles" camera to divide an image into smaller pieces, then assemble them using software like FFmpeg or OpenImageIO.
      Here's our detailed step-by-step procedure: https://github.com/aws-deadline/deadline-cloud-for-cinema-4d/blob/mainline/docs/tile_rendering/tile_rendering.md based on this old article.
      Alternative approach:
      But while going over some of the render settings, I stumbled on "RDATA_RENDERREGION_LEFT" (similarly for left, top and bottom).
      Could we use this approach instead—rendering specific regions of the image separately and then assembling them into the final image?
      Has anyone implemented a similar solution or can provide guidance on whether this approach is feasible?
      Thank you for your assistance.
      K 1 Reply Last reply Reply Quote 0
      • K Offline
        karthikbp @karthikbp
        I was able to get tile rendering done by running a script like this:
        import os
        doc: c4d.documents.BaseDocument
        op: c4d.BaseObject | None
            # --- Configure these ---
            tiles_x = 2  # columns
            tiles_y = 2  # rows
            output_dir = os.path.join(os.path.expanduser("~"), "Desktop", "tiles")
            os.makedirs(output_dir, exist_ok=True)
            base_rd = doc.GetActiveRenderData()
            full_w = int(base_rd[c4d.RDATA_XRES])
            full_h = int(base_rd[c4d.RDATA_YRES])
            tile_w = full_w // tiles_x
            tile_h = full_h // tiles_y
            for ty in range(tiles_y):
                for tx in range(tiles_x):
                    rd = base_rd.GetClone()
                    left = tx * tile_w
                    top = ty * tile_h
                    right = left + tile_w
                    bottom = top + tile_h
                    # Region at full resolution
                    rd[c4d.RDATA_RENDERREGION] = True
                    rd[c4d.RDATA_RENDERREGION_LEFT] = left
                    rd[c4d.RDATA_RENDERREGION_TOP] = top
                    rd[c4d.RDATA_RENDERREGION_RIGHT] = right
                    rd[c4d.RDATA_RENDERREGION_BOTTOM] = bottom
                    # Full-res bitmap — C4D renders region into this
                    bmp = c4d.bitmaps.MultipassBitmap(full_w, full_h, c4d.COLORMODE_RGB)
                    bmp.AddChannel(True, True)
                    result = c4d.documents.RenderDocument(
                        doc,
                        rd.GetData(),
                        bmp,
                        c4d.RENDERFLAGS_EXTERNAL | c4d.RENDERFLAGS_SHOWERRORS,
                    if result != c4d.RENDERRESULT_OK:
                        print(f"Tile ({tx}, {ty}) failed with code: {result}")
                        continue
                    # Crop the tile region out of the full bitmap
                    tile_bmp = c4d.bitmaps.BaseBitmap()
                    tile_bmp.Init(tile_w, tile_h)
                    for y in range(tile_h):
                        for x in range(tile_w):
                            r, g, b = bmp.GetPixel(left + x, top + y)
                            tile_bmp.SetPixel(x, y, r, g, b)
                    path = os.path.join(output_dir, f"tile_{tx}_{ty}.png")
                    tile_bmp.Save(path, c4d.FILTER_PNG)
                    print(f"Saved {path}")
            c4d.gui.MessageDialog(
                f"Done! {tiles_x * tiles_y} tiles saved to:\n{output_dir}"
        • K Offline
          Hmm, I was able to reassemble the tiles within Cinema 4D as well. Here's the script with reassembly.
          Feel free to chime in if we should not be doing this (performance impact, does not work with different renderers etc)
          import os
              """Renders the scene as a grid of tiles, then reassembles into the final image."""
              tiles_x = 2
              tiles_y = 2
              final_path = os.path.join(output_dir, "final_assembled.png")
              tile_bmps = {}
                      left = tx * tile_w
                      top_ = ty * tile_h
                      bottom = top_ + tile_h
                      rd[c4d.RDATA_RENDERREGION_TOP] = top_
                      print(f"Rendering tile ({tx}, {ty}) region=({left},{top_})-({right},{bottom})")
                          doc,
                          rd.GetData(),
                          bmp,
                      # Crop tile — use same coords as region
                              r, g, b = bmp.GetPixel(left + x, top_ + y)
                      tile_path = os.path.join(output_dir, f"tile_{tx}_{ty}.png")
                      tile_bmp.Save(tile_path, c4d.FILTER_PNG)
                      print(f"Saved {tile_path}")
                      tile_bmps[(tx, ty)] = tile_bmp
              # --- Reassemble: place each tile at its matching position, no flip ---
              print("Assembling final image...")
              final_bmp = c4d.bitmaps.BaseBitmap()
              final_bmp.Init(full_w, full_h)
                      tile_bmp = tile_bmps[(tx, ty)]
                      dst_x = tx * tile_w
                      dst_y = ty * tile_h
                              r, g, b = tile_bmp.GetPixel(x, y)
                              final_bmp.SetPixel(dst_x + x, dst_y + y, r, g, b)
              final_bmp.Save(final_path, c4d.FILTER_PNG)
              print(f"Saved assembled image to {final_path}")
              c4d.bitmaps.ShowBitmap(final_bmp)
                  f"Done! {tiles_x * tiles_y} tiles rendered and assembled.\n{final_path}"
            ferdinand @karthikbp
            Hey @karthikbp,
            Thank you for reaching out to us. And sorry, I somehow overlooked your topic. Yes, that is how I would have done it too, via RDATA_RENDERREGION_LEFT, etc. The 2026.2 Python SDK will contain new rendering examples, that could be something I could add, as tile rendering is something that comes up from time to time.
            As a fair warning: Your code will not respect OCIO, i.e., the images will have the wrong colors. Since you marked this as 2026, where OCIO is the color management standard, this would apply to all documents. See open_color_io_2025_2.py for an example how to do it correctly. The next release will streamline things there quite a bit.
            • K Offline
              karthikbp @ferdinand
              Thanks @ferdinand .
              I was about to add to this forum post that the rendered images are bit darker than actual.
              Thanks for the code link. Here's my updated script with changes for OCIO and I was able to get it rendering correctly at least locally.
              Anything to avoid or missed here?
              import os
              def EnsureIsOcioDocument(doc: c4d.documents.BaseDocument) -> None:
                  if doc[c4d.DOCUMENT_COLOR_MANAGEMENT] is not c4d.DOCUMENT_COLOR_MANAGEMENT_OCIO:
                      doc[c4d.DOCUMENT_COLOR_MANAGEMENT] = c4d.DOCUMENT_COLOR_MANAGEMENT_OCIO
                      doc.UpdateOcioColorSpaces()
                      if c4d.threading.GeIsMainThreadAndNoDrawThread():
                  tiles_x = 2
                  tiles_y = 2
                  EnsureIsOcioDocument(doc)
                  if not doc.GetDocumentPath():
                      c4d.gui.MessageDialog("Please save the document first.")
                  # Work directly on the document's render data, matching the reference pattern.
                  renderData: c4d.documents.RenderData = doc.GetActiveRenderData()
                  data: c4d.BaseContainer = renderData.GetDataInstance()
                  requiresBaking: bool = data[c4d.RDATA_FORMATDEPTH] is c4d.RDATA_FORMATDEPTH_8
                  xRes: int = int(data[c4d.RDATA_XRES_VIRTUAL] or data[c4d.RDATA_XRES])
                  yRes: int = int(data[c4d.RDATA_YRES_VIRTUAL] or data[c4d.RDATA_YRES])
                  tile_w = xRes // tiles_x
                  tile_h = yRes // tiles_y
                  # Determine save bit flags based on format depth
                  if data[c4d.RDATA_FORMATDEPTH] is c4d.RDATA_FORMATDEPTH_16:
                      save_bits = c4d.SAVEBIT_16BITCHANNELS
                  elif data[c4d.RDATA_FORMATDEPTH] is c4d.RDATA_FORMATDEPTH_32:
                      save_bits = c4d.SAVEBIT_32BITCHANNELS
                      save_bits = c4d.SAVEBIT_NONE
                  # Save original render region state to restore later
                  orig_region = data[c4d.RDATA_RENDERREGION]
                  orig_region_left = data[c4d.RDATA_RENDERREGION_LEFT]
                  orig_region_top = data[c4d.RDATA_RENDERREGION_TOP]
                  orig_region_right = data[c4d.RDATA_RENDERREGION_RIGHT]
                  orig_region_bottom = data[c4d.RDATA_RENDERREGION_BOTTOM]
                  orig_bake_flag = data.GetBool(c4d.RDATA_BAKE_OCIO_VIEW_TRANSFORM_RENDER)
                  if requiresBaking:
                      data[c4d.RDATA_BAKE_OCIO_VIEW_TRANSFORM_RENDER] = False
                  tile_bmps = {}
                          left = tx * tile_w
                          top_ = ty * tile_h
                          data[c4d.RDATA_RENDERREGION] = True
                          # RDATA_RENDERREGION_* are offsets inward from each edge,
                          # not absolute pixel coordinates.
                          data[c4d.RDATA_RENDERREGION_LEFT] = left
                          data[c4d.RDATA_RENDERREGION_TOP] = top_
                          data[c4d.RDATA_RENDERREGION_RIGHT] = xRes - right
                          data[c4d.RDATA_RENDERREGION_BOTTOM] = yRes - bottom
                          # Always render as 32-bit float
                          bmp = c4d.bitmaps.MultipassBitmap(xRes, yRes, c4d.COLORMODE_RGBf)
                              doc,
                              data,
                              bmp,
                              c4d.RENDERFLAGS_EXTERNAL,
                              # Restore original settings before returning
                              data[c4d.RDATA_RENDERREGION] = orig_region
                              data[c4d.RDATA_RENDERREGION_LEFT] = orig_region_left
                              data[c4d.RDATA_RENDERREGION_TOP] = orig_region_top
                              data[c4d.RDATA_RENDERREGION_RIGHT] = orig_region_right
                              data[c4d.RDATA_RENDERREGION_BOTTOM] = orig_region_bottom
                              data[c4d.RDATA_BAKE_OCIO_VIEW_TRANSFORM_RENDER] = orig_bake_flag
                          # Bake OCIO and null profiles — exactly as reference
                          if requiresBaking:
                              bmp = c4d.documents.BakeOcioViewToBitmap(bmp, data, c4d.SAVEBIT_NONE) or bmp
                          bmp.SetColorProfile(c4d.bitmaps.ColorProfile(), c4d.COLORPROFILE_INDEX_DISPLAYSPACE)
                          bmp.SetColorProfile(c4d.bitmaps.ColorProfile(), c4d.COLORPROFILE_INDEX_VIEW_TRANSFORM)
                          # Crop tile preserving bit depth
                          tile_bmp = bmp.GetClonePart(left, top_, tile_w, tile_h)
                          if tile_bmp is None:
                              print(f"Tile ({tx}, {ty}) crop failed")
                              continue
                          tile_bmp.Save(tile_path, c4d.FILTER_PNG, c4d.BaseContainer(), save_bits)
                  # Restore original render data settings
                  # --- Reassemble using GetPixelCnt/SetPixelCnt to preserve full bit depth ---
                  # Get bit depth from the first tile
                  first_tile = tile_bmps.get((0, 0))
                  if first_tile is None:
                      print("No tiles to assemble")
                  tile_bpp = first_tile.GetBt()
                  bpc = tile_bpp // 3
                  if bpc == 32:
                      color_mode = c4d.COLORMODE_RGBf
                      inc = 12
                  elif bpc == 16:
                      color_mode = c4d.COLORMODE_RGBw
                      inc = 6
                      inc = 3
                  final_bmp.Init(xRes, yRes, depth=tile_bpp)
                  row_buffer = bytearray(tile_w * inc)
                  row_view = memoryview(row_buffer)
                          if (tx, ty) not in tile_bmps:
                              continue
                          dst_x = tx * tile_w
                          dst_y = ty * tile_h
                          for py in range(tile_h):
                              tile_bmp.GetPixelCnt(0, py, tile_w, row_view, inc, color_mode, c4d.PIXELCNT_0)
                              final_bmp.SetPixelCnt(dst_x, dst_y + py, tile_w, row_view, inc, color_mode, c4d.PIXELCNT_0)
                  final_bmp.Save(final_path, c4d.FILTER_PNG, c4d.BaseContainer(), save_bits)
                  c4d.gui.MessageDialog(f"Done! {tiles_x * tiles_y} tiles rendered and assembled.\n{final_path}")
                @karthikbp
                As far as I can see this at a glance, this seems to be correct. You already did the most important thing by using RDATA_RENDERREGION and not some camera cropping tricks, so it renders with the full scene data for each tile.
                There is however one issue, and it depends on the render engine how it is handled. At verbatim, kernels applied to your rendering (e.g., a box filter) will be slightly wrong, because for the the seams of a tile, there is data missing (the seam pixels of the neighboring tile) which would exist in a full rendering. E.g., when you have this,
                              x y
                    Tile A    x y    Tile B
                              x y
                a rendering split into two tiles Tile A and Tile B, where x are the 'seam pixels' of Tile A and y are the seam pixels of Tile B. If you would have rendered the whole image in one go, processing one of the xs with a kernel would have included neighboring pixels, i.e., also what is now the seam pixels y of the other tile. So, at the borders of the tile, any filter kernels you will apply will not be quite the same.
                To prevent that issue, Redshift does render region tiles with an extra border of the maximum size of the kernels used for that rendering. But the standard renderer does not do that. Other render engines which might support our render region setting might not do that either. In such cases, you would have to either live with the small error or render with an extra border yourself, depending on the kernels that will be used., and then crop the final result back.
                  ferdinand @ferdinand
                  Hey,
                  just as an FYI, I added this as an example to the 2026.2 rendering examples. You will be able to find it under \scripts\04_3d_concepts\rendering\render_document_tiles_2026_2.py. Since the script will use some 2026.2 features, it does not make much sense to post a preview here, as you will not be able to run it right now. The example also does the kernel border thing we discussed here.
