    C++ SDK Matrix object style distribution
    2026c++
    3 Posts 2 Posters 842 Views 1 Watching
    • dexD Offline
      dex
      Hello!
      This is my first post here. See my bio for background.
      I have been studying the SDK docs the last two weeks and I'm taking my first steps trying to build plugins for Cinema4D. So I have a question and I'm looking for directions...
      Does C++ SDK allows you to create some sort of a custom Matrix Object style distribution?
      What I want to achieve is a generator/distribution that output point data that can be read by a cloner.
      It is important that the points encode position, orientation and size or scale and that the cloner can read that data and apply it to instances. Is this doable with the C++ SDK?
      If I have understood the SDK correctly, a point object can only encode position and possibly normals and that won't fulfill the requirements in my case.
      Any hint or help pointing me in the right direction would be much appreciated.
      Thanks in advance!
      /Fredrik
        ferdinand @dex
        Hello @dex,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: How to Ask Questions.
        About your First Question
        Thank you for reaching out to us.
        The SDK does not allow you create any MoGraph generators, the only thing you can implement are effectors and fields. A generator is effectively just an ObjectData plugin which generates some MoData stored as a tag on it, and then depending on the generator type, also generates some cache and/or viewport output. What a MoGraph generator does is not strongly defined, therefore each generator might have to be handled differently by our Core API; which makes it impossible to create a custom one.
        In the case of a Matrix object linked in a Cloner object in object mode, the custom behavior is that the Cloner will read the MoData tag of the Matrix object when it sees an Omgmatrix being linked. You could create an ObjectData plugin which generates the same MoData tag as the Matrix object, but it would not be recognized by the Cloner as a Matrix object, and thus not be treated as such. But you could create your own infrastructure which picks up on that. But in general, implementing your own generators within the MoGraph system is not possible and also not trivial.
        The most straight forward way to achieve what you want, would be probably to implement a custom effector which overrides the particle data to your liking. The only limitation of effectors is that they cannot change the particle count. A way out could be here to create some driver logic, e.g., a tag on the cloner which drives both the cloner and an instance of your custom generator in tandem. If you do that you have to be a bit careful with not violating threading restrictions or creating dirtiness feedback loops, but it is possible.
        The other alternative could be to just implement a polygon object ObjectData and generate tiny polygons for each (position, orientation, scale) tuple you want to have. Then in the cloner, you just clone in polygon mode onto your object and enable 'Enable Scaling', so that the particles are also scaled according to the size of the polygons.
        • dexD Offline
          dex
          Thank you so much Ferdinand!
          I have a way forward now for my plugin using the EffectorData ModifyPoints() method.
          Kind regards
          Fredrik
