    how to detect obj selected in InExcludeData()?
    2025python
    7 Posts 2 Posters 1.0k Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      i use this script code to detect obj selected in InExcludeData(),always return "None"
          ie = op[c4d.ID_USERDATA,1]
          for i in range(ie.GetObjectCount()):
              print(ie.GetData(i)[c4d.IN_EXCLUDE_DATA_SELECTION])
      i found a example code in this post,but it also not work.
      Thanks for any help!
      相信我,可以的!
        ferdinand @chuanzhen
        Hey @chuanzhen,
        Thank you for reaching out to us. For me this works fine, but I also struggled for a second with this. The crucial information is probably that you have to set SEND_SELCHNGMSG in the InExcludeCustomGui for which this shall work. Since this information is rather obscure, I have updated the docs of InExcludeData::GetData to better reflect this.
        chuanzhenC 2 Replies Last reply Reply Quote 1
          chuanzhen @ferdinand
          @ferdinand Thanks,it works!
          相信我,可以的!
            chuanzhen
            Supplement an example of generating UserData using code:
                bc = c4d.GetCustomDataTypeDefault(c4d.CUSTOMDATATYPE_INEXCLUDE_LIST)
                bc[c4d.DESC_NAME] = "Test"
                bc[c4d.IN_EXCLUDE_FLAG_SEND_SELCHANGE_MSG] = True
                did = op.AddUserData(bc)
            相信我,可以的!
              Hi @ferdinand , in .res file, how to set InExcludeData IN_EXCLUDE_FLAG_SEND_SELCHANGE_MSG is True? in c++ API doc,there no this flags for IN_EXCLUDE_FLAG_SEND_SELCHANGE_MSG
              相信我,可以的!
                @chuanzhen
                chuanzhenC 1 Reply Last reply Reply Quote 0
                  @ferdinand Thank you. hope this can be updated in the document👍
                  相信我,可以的!
