    VertexMap Display (Behavior Equivalent to Double-Click)
    2026pythonwindows
    3 Posts 2 Posters 533 Views 1 Watching
    • ymoonY Offline
      ymoon
      When you select a Vertex Map tag on an object and double-click it, the colors become visible in the viewport. How can I replicate this double-click behavior through a script?
          obj = doc.SearchObject("PointObj")
          vmap_tag = None
          for tag in obj.GetTags():
              if tag.CheckType(c4d.Tvertexmap):
                  vmap_tag = tag
                  break
          doc.SetActiveTag(vmap_tag, c4d.SELECTION_NEW)
        ferdinand @ymoon
        Hey @ymoon,
        Thank you for your question. First of all, your code is more complicated than it has to be. You can just call BaseObject.GetTag to get the first tag of a specific type on an object. Also, your code already does what you are asking for, it selects the tag and therefore causes Cinema 4D to draw the vertex map in the viewport (equivalent to single clicking the tag).
        To have the Paint Tool enabled (i.e., what happens when you double click a vertex map), you could either activate the tool yourself, or just send MSG_EDIT to the tag, the message which is sent to scene elements when they are double clicked.
        Code
            if not op:
                return c4d.gui.MessageDialog("Please select an object.")
            tag: c4d.BaseTag | None = op.GetTag(c4d.Tvertexmap)
            if not tag:
                return c4d.gui.MessageDialog("The selected object has no Vertex Map tag.")
            doc.SetActiveTag(tag, c4d.SELECTION_NEW)
            tag.Message(c4d.MSG_EDIT)
        • ymoonY Offline
          ymoon
          Thank you. It works well. --> tag.Message(c4d.MSG_EDIT)
