    maxon::String Fails to Display "º" in Control Name
    c++windows
    2 Posts 2 Posters 670 Views 1 Watching
    • Viktor VelickoV Offline
      Viktor Velicko
      Hi guys,
      I'm having an issue creating attribute panel control names that include the degree symbol "º".
      For example, when creating a button control with the following Maxon string:
      Example A (works):
      const char* name_char = "Slope 90";
      maxon::String name_maxon(name_char);
      Example B (fails – button name is blank):
      const char* name_char = "Slope 90º";
      The name_char variable is just for testing purposes. In the actual application, the string is read from the file system.
      The name_maxon string is then used to set the control name in the attribute panel.
      Any ideas why the degree symbol causes the control name to appear blank?
      Thanks!
        ferdinand @Viktor Velicko
        Hey @Viktor-Velicko,
        Thank you for reaching out to us. Generally, our codebase supports Unicode, but in C++ source code and in *.str resource files, we only support Unicode escape sequences, not Unicode symbols directly. In Python, we do support Unicode symbols directly. In the 2025.3 SDK, I just added a code example for how to use Python to create a Unicode escaping pipeline around *.str files.
        So, the Unicode string const String slopeLabel = "Slope 90º"_s; would be written as const String slopeLabel = "Slope 90\\u00b0"_s; in C++. A bit more verbose variant would be const String slopeLabel ="Slope 90"_s + String("\\u00b0", STRINGENCODING::BIT7HEX));. In Python, you can use the string directly as slopeLabel: str = "Slope 90°".
