    Enables or disables all Emission in the scene
    python2025windows
    3 Posts 2 Posters 709 Views 1 Watching
    • I Offline
      itstanthony
      Hi everyone,
      I’m looking for a way to globally enable or disable all emission in a Cinema 4D scene using Redshift — ideally without having to iterate through each material. I’d like to control this via Python.
      Is there a way to access the global emission toggle through Redshift’s render overrides? (C4D+RS latest versions)
      Any pointers would be much appreciated
      Thanks in advance!
        ferdinand @itstanthony
        Hello @itstanthony,
        Thank you for reaching out to us. Please have a look at Access renderer specific settings with python for the details of how and why. The ID you are looking for is REDSHIFT_RENDERER_EMISSION_ENABLE.
        """Demonstrates how to access Redshift render engine render settings attached
        to render data.
            """Entry point.
            # doc in predefined in script manger scripts, so this would not be
            # necessary, but since you did call GetActiveDocument() I copied this
            # here.
            if not isinstance(doc, c4d.documents.BaseDocument):
                raise RuntimeError("Could not access active document.")
            renderData = doc.GetActiveRenderData()
            # The elements in the render settings are video post plugins. Some of
            # the common entries, e.g., Output/Save are mapped automatically to the
            # render data, for everything that is optional, we must access the
            # corresponding BaseVideoPost. Your idea with FindPlugin was not bad, but
            # that will only give you the BasePlugin and not the actual video post
            # instance associated with the concrete render data instance.
            # We could also get the Redshift id like you did with RDATA_RENDERENGINE,
            # but this assumes that the Redshift is indeed the active render engine.
            # So, for me it is a bit more comfy to hard-code it.
            redshiftRenderEngineId = 1036219
            # Iterate over the video post to find one matching the render engine.
            videoPost = renderData.GetFirstVideoPost()
            while (videoPost):
                if videoPost.CheckType(redshiftRenderEngineId):
                    break
                videoPost = videoPost.GetNext()
            if not isinstance(videoPost, c4d.documents.BaseVideoPost):
                raise RuntimeError(
                    f"Could not access video post for '{redshiftRenderEngineId = }'")
            # Disable the emisssion in Globals/Other Overrides
            videoPost[c4d.REDSHIFT_RENDERER_EMISSION_ENABLE] = False
        • I Offline
          itstanthony
          Hi Ferdinand,
          Thanks a lot for the clear explanation and for taking the time to share the code. The part about accessing BaseVideoPost and using REDSHIFT_RENDERER_EMISSION_ENABLE was spot on. Exactly what I needed. Works perfectly!
          Really appreciate it.
          Anthony
