    Change Icon Color parameter
    2024python
    6 Posts 3 Posters 1.2k Views
    • chuanzhenC Offline
      chuanzhen
      hi,
      I use script to create bone and insert it to document, set it Icon Color=Display Color,Why does the Icon Color parameter of the object turn to Custom when I click on it.
          for i in range(2):
              obj = c4d.BaseObject(c4d.Ojoint)
              obj[c4d.ID_BASELIST_ICON_COLORIZE_MODE] = 2
              obj[c4d.ID_BASEOBJECT_USECOLOR] = 2
              obj[c4d.ID_BASEOBJECT_COLOR] = c4d.Vector()
              obj.SetName(str(i))
              doc.InsertObject(obj)
      Thanks for any help!
      相信我,可以的!
      • JH23J Offline
        JH23
        Hello chuanzhen,
        I tried this, you're right, it's strange, but curiously if a value is assigned to the color it manages to be created with the defined color without the need for interaction, this is a possible solution, even so I would like to know what could be happening.
        Cinema_4D_72OIMo0GEM.mp4
        James H.
        chuanzhenC 1 Reply Last reply Reply Quote 0
          chuanzhen @JH23
          @JH23 Thanks for your help,this is indeed a solution.
          For existing objects in Object Manager, using this code is effective, but creating a new object and setting it up yields a different result, which is confusing.
          @chuanzhen said in Change Icon Color parameter:
              for i in range(2):
                  obj.SetName(str(i))
          相信我,可以的!
          JH23J 1 Reply Last reply Reply Quote 1
          • JH23J Offline
            JH23 @chuanzhen
            Hi @chuanzhen,
            I wanted to say that it is confusing that it fails to create an automatic color when defining the use of icons with custom colors, I suspect a reason why this happens but I am not at all sure, I am still happy that this solution works for you, even so I would like to know if this is something planned or some kind of bug.
            James H.
            • i_mazlovI Offline
              i_mazlov @JH23
              Hi @chuanzhen,
              The "Display Color" value of the "Icon Color" attribute is a dynamic value (comparing to "None" and "Custom" being static values), this was explained in the related thread: Python Documentation - Icon Color. This is the reason why it requires special handling, namely (as Manuel explained in the related thread: Simple Organisational Structure Generation Script), one needs to send a c4d.MSG_GETCUSTOMICON_SETTINGS message to the object to properly set this attribute. Please check the example code snippet that shows its usage.
              Ilia
              Example code, showing the usage of the c4d.MSG_GETCUSTOMICON_SETTINGS message:
                  # Configure object display color attribute
                  obj[c4d.ID_BASEOBJECT_USECOLOR] = c4d.ID_BASEOBJECT_USECOLOR_ALWAYS
                  obj[c4d.ID_BASEOBJECT_COLOR] = c4d.Vector(1, 0, 1)
                  # Configure object icon color attribute
                  settings = c4d.CustomIconSettings()
                  settings._colorMode = 2
                  obj.Message(c4d.MSG_GETCUSTOMICON_SETTINGS, {'setting': settings})
                  obj[c4d.ID_BASELIST_ICON_COLORIZE_MODE] = c4d.ID_BASELIST_ICON_COLORIZE_MODE_CUSTOM + 1
                  obj.SetName("Magenta Joint")
              chuanzhenC 1 Reply Last reply Reply Quote 1
                chuanzhen @i_mazlov
                @i_mazlov Thanks for your help, it works well.
                相信我,可以的!
