    Docked Dialog Problem with width of CUSTOMGUI_FILENAME
    windowspython2025
    6 Posts 2 Posters 1.7k Views 1 Watching
    • D Offline
      datamilch
      hi there,
      i'm working on a command plugin with gedialog, that i want to dock in the layout.
      one of the gui elements is AddCustomGui c4d.CUSTOMGUI_FILENAME.
      the paths that are stored can be quite long.
      the problem is, that the dialog wants to show the complete string, which makes the dialog extremely wide.
      this only happens when the dialog is docked. then i can not scale the dialog smaller then the length of the string/filename.
      if the dialog is not docked i can scale it smaller and the overflowing string is hidden.
      sadly AddCustomGui has no properties initw and inith. i tried some combinations of flags but had no success.
      am i missing something?
      i could place the element in a scrollgroup, but then the "open document" button might be hidden in the part that is scrolled away.
      any other options or workarouds?
      cheers, sebastian
      here is the code
      import c4d, typing
      ID_PLUGIN_CMD: int = 1025245
      class MainDialog(c4d.gui.GeDialog):
          ID_GRP_MAIN     = 1000
          ID_TEXT_1       = 1001
          ID_TEXT_2       = 1002
          extra_long_str  = "this is some realy looooooooooooooooooooooooooooooooong text"
          def __init__(self) -> None:
              super().__init__()
          def InitValues(self) -> bool:
              return super().InitValues()
          def CreateLayout(self) -> bool:
              self.SetTitle("My Dialog")
              self.GroupBegin(id=self.ID_GRP_MAIN, flags=c4d.BFH_SCALEFIT, cols=1)
              self.GroupSpace(spacex=5, spacey=5)
              self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT, cols=2)
              self.AddStaticText(0, c4d.BFH_LEFT, name="path", initw=0 )
              bc = c4d.BaseContainer()
              self.AddCustomGui(self.ID_TEXT_1, c4d.CUSTOMGUI_FILENAME, '' ,c4d.BFH_SCALEFIT, 0, 0, bc,)
              self.AddStaticText(0, c4d.BFH_LEFT, name="text", initw=0 )
              self.AddEditText(self.ID_TEXT_2, c4d.BFH_FIT, 20,10 )
              self.GroupEnd()
              self.GroupEnd()
              self.SetString( id=self.ID_TEXT_1, value=self.extra_long_str )
              self.SetString( id=self.ID_TEXT_2, value=self.extra_long_str )
              return  super().CreateLayout()
          def Command(self, cid: int, msg: c4d.BaseContainer) -> bool:
              return super().Command(cid, msg)
      class DialogManagerCommand (c4d.plugins.CommandData):
          dialog: typing.Optional[MainDialog] = None
          def Execute(self, doc: c4d.documents.BaseDocument) -> bool:
              if self.dialog is None:
                  self.dialog = MainDialog()
              if self.dialog.IsOpen() and not self.dialog.GetFolding():
                  self.dialog.SetFolding(True)
                  self.dialog.Open(c4d.DLG_TYPE_ASYNC, ID_PLUGIN_CMD, -2, -2, defaultw=300, defaulth=200)
          def RestoreLayout(self, secret: any) -> bool:
              return self.dialog.Restore(ID_PLUGIN_CMD, secret)
          def GetState(self, doc: c4d.documents.BaseDocument) -> int:
              result: int = c4d.CMD_ENABLED
              if self.dialog:
                      result |= c4d.CMD_VALUE
              return result
      def RegisterPlugin() -> bool:
          return c4d.plugins.RegisterCommandPlugin(
              id=ID_PLUGIN_CMD,
              str="filename_test_01",
              info=c4d.PLUGINFLAG_SMALLNODE,
              icon=None,
              help="",
              dat=DialogManagerCommand())
          if not RegisterPlugin():
              raise RuntimeError( f"Failed to register {DialogManagerCommand} plugin." )
      • i_mazlovI Offline
        i_mazlov
        Hi @datamilch,
        Although I highly suspect this to be a bug, I'll need more time to double check it. I'll update you further, once have a more clear vision on this.
        Ilia
        • D Offline
          datamilch
          Thanks for the preliminary feedback.
          I'll wait patiently šŸ™‚
          • i_mazlovI Offline
            i_mazlov @datamilch
            Hi Sebastian,
            Thanks for your patience. TLDR; it's a bug but you still need to set minimal width.
            The issue is twofold:
            1. For this UI element to work as intended you need to specify the minimal width argument minw, for example using the c4d.gui.SizeChr() function:
              self.AddCustomGui(self.ID_TEXT_1, c4d.CUSTOMGUI_FILENAME, '', c4d.BFH_SCALEFIT, c4d.gui.SizeChr(80), 0, bc)
            2. There's currently a bug, which prevents this from working properly. The fix is going to be included in one of further Cinema 4D releases.
            After the fix is released, given you're using the minw argument, the issue wouldn't be there anymore. Thanks for drawing our attention to this issue!
            Ilia
            • D Offline
              datamilch
              hi, thanks for the info.
              i just updated to 2025.2.0 ... but i suppose the fix is not in this one yet? not sure when the release date was ...
              • i_mazlovI Offline
                i_mazlov @datamilch
                Hi Sebastian,
                correct, it hasn't been included into 2025.2.0. The next minor release will likely have it fixed though.
                Ilia
