    Plugin does not appear in Expression on client's Cinema 4D
    s262024c++windows
    24 Posts 3 Posters 9.9k Views 2 Watching
      ferdinand @yaya
      This:
      Platform=Win64;OSX
      Type=Solution
      Solution=\
      	plugins/cinema4dsdk;\
      	plugins/maxonsdk.module;\
      	plugins/microsdk;\
      	plugins/ragdoll
      is the projectdefitnion.txt of your solution, i.e., the build config which links all modules together. You must use plugins/ragdoll/project/projectdefitnion.txt instead, it is the build config for that module. Think of it as the CMakeLists.txt of that module when you are familiar with CMake. After these changes you must regenerate your project with the project tool.
      I quite frankly do not understand your solution, but as always, whatever works, works. So, if it does work for you, I am happy.
      The ".." in paths is common relative path syntax and means one folder up (in relation to the module). So, ../../foo means a foo folder in the root of your project.
      root
        foo
        plugins
          ragdoll
      • Y Offline
        yaya
        I know what is projectdefitnion.txt. I just do not understand how to use the line: AdditionalLibraryDirectories.Win64.Debug =../../curl 🙂
        And do I need to launch again the buildsdk23.bat right after each time I change this file.
        I have not added the static curl library in my project yet.
        https://www.ragdollplugin.com
          Well, you apparently do not, because you showed us the wrong projectdefitnion.txt file above, putting the command there won't work as I tried to explain 😉 And yes, you must regen your project after such changes, which I assume is what you mean with buildsdk23.bat.
          • Y Offline
            yaya
            Oh, you've edited your previous message! Thanks! I will try it.
