    • Unread
    How to drag rows in Treeview
    2024python
    4 Posts 2 Posters 588 Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      I have read many posts about the dragging behavior of treeview, all of which are examples of dragging from the outside into treeview. What I want is to drag the rows of treeview to rearrange them, just like an object manager dragging objects.
      This post also mentioned some explanations about the drag and drop process, but I am still confused about how to start.
      I found an example of code in this post. Can we implement the drag behavior of treeview rows on this basis
      import weakref
      # Be sure to use a unique ID obtained from [URL-REMOVED]
      PLUGIN_ID = 1000010  # TEST ID ONLY
      # TreeView Column IDs.
      ID_CHECKBOX = 1
      ID_NAME = 2
      ID_OTHER = 3
      def TextureObjectIterator(lst):
          for parentTex in lst:
              yield parentTex
              for childTex in TextureObjectIterator(parentTex.GetChildren()):
                  yield childTex
      class TextureObject(object):
          Class which represent a texture, aka an Item in our list
          texturePath = "TexPath"
          otherData = "OtherData"
          _selected = False
          _open = True
          def __init__(self, texturePath):
              self.texturePath = texturePath
              self.otherData += texturePath
              self.children = []
              self._parent = None
          @property
          def IsSelected(self):
              return self._selected
          def Select(self):
              self._selected = True
          def Deselect(self):
              self._selected = False
          @property
          def IsOpened(self):
              return self._open
          def Open(self):
              self._open = True
          def Close(self):
              self._open = False
          def AddChild(self, obj):
              obj._parent = weakref.ref(self)
              self.children.append(obj)
          def GetChildren(self):
              return self.children
          def GetParent(self):
              if self._parent:
                  return self._parent()
              return None
          def __repr__(self):
              return str(self)
          def __str__(self):
              return self.texturePath
      class ListView(c4d.gui.TreeViewFunctions):
          def __init__(self):
              self.listOfTexture = list()  # Store all objects we need to display in this list
              # Add some defaults values
              t1 = TextureObject("T1")
              t2 = TextureObject("T2")
              t3 = TextureObject("T3")
              t4 = TextureObject("T4")
              self.listOfTexture.extend([t1, t2, t3, t4])
          def IsResizeColAllowed(self, root, userdata, lColID):
          def IsTristate(self, root, userdata):
              return False
          def GetColumnWidth(self, root, userdata, obj, col, area):
              return 80  # All have the same initial width
          def IsMoveColAllowed(self, root, userdata, lColID):
              # The user is allowed to move all columns.
              # TREEVIEW_MOVE_COLUMN must be set in the container of AddCustomGui.
          def GetFirst(self, root, userdata):
              Return the first element in the hierarchy, or None if there is no element.
              rValue = None if not self.listOfTexture else self.listOfTexture[0]
              return rValue
          def GetDown(self, root, userdata, obj):
              Return a child of a node, since we only want a list, we return None everytime
              children = obj.GetChildren()
              if children:
                  return children[0]
              return None
          def GetNext(self, root, userdata, obj):
              Returns the next Object to display after arg:'obj'
              rValue = None
              # If does have a child it means it's a child.
              objParent = obj.GetParent()
              listToSearch = objParent.GetChildren() if objParent is not None else self.listOfTexture
              currentObjIndex = listToSearch.index(obj)
              nextIndex = currentObjIndex + 1
              if nextIndex < len(listToSearch):
                  rValue = listToSearch[nextIndex]
              return rValue
          def GetPred(self, root, userdata, obj):
              Returns the previous Object to display before arg:'obj'
              rValue = None
              predIndex = currentObjIndex - 1
              if 0 <= predIndex < len(listToSearch):
                  rValue = listToSearch[predIndex]
              return rValue
          def GetId(self, root, userdata, obj):
              Return a unique ID for the element in the TreeView.
              return hash(obj)
          def Select(self, root, userdata, obj, mode):
              Called when the user selects an element.
              if mode == c4d.SELECTION_NEW:
                  for tex in self.listOfTexture:
                      tex.Deselect()
                  obj.Select()
              elif mode == c4d.SELECTION_ADD:
                  obj.Select()
              elif mode == c4d.SELECTION_SUB:
                  obj.Deselect()
          def IsSelected(self, root, userdata, obj):
              Returns: True if *obj* is selected, False if not.
              return obj.IsSelected
          def SetCheck(self, root, userdata, obj, column, checked, msg):
              Called when the user clicks on a checkbox for an object in a
              `c4d.LV_CHECKBOX` column.
              if checked:
                  obj.Select()
                  obj.Deselect()
          def IsChecked(self, root, userdata, obj, column):
              Returns: (int): Status of the checkbox in the specified *column* for *obj*.
              if obj.IsSelected:
                  return c4d.LV_CHECKBOX_CHECKED | c4d.LV_CHECKBOX_ENABLED
                  return c4d.LV_CHECKBOX_ENABLED
          def IsOpened(self, root, userdata, obj):
              Returns: (bool): Status If it's opened = True (folded) or closed = False.
              # If there is some children
              return obj.IsOpened
          def Open(self, root, userdata, obj, onoff):
              Called when the user clicks on a folding state of an object to display/hide its children
              if onoff:
                  obj.Open()
                  obj.Close()
          def GetName(self, root, userdata, obj):
              Returns the name to display for arg:'obj', only called for column of type LV_TREE
              return str(obj)  # Or obj.texturePath
          def DrawCell(self, root, userdata, obj, col, drawinfo, bgColor):
              Draw into a Cell, only called for column of type LV_USER
              if col == ID_OTHER:
                  name = obj.otherData
                  geUserArea = drawinfo["frame"]
                  w = geUserArea.DrawGetTextWidth(name)
                  h = geUserArea.DrawGetFontHeight()
                  xpos = drawinfo["xpos"]
                  ypos = drawinfo["ypos"] + drawinfo["height"]
                  drawinfo["frame"].DrawText(name, xpos, int(ypos - h * 1.1))
          def DoubleClick(self, root, userdata, obj, col, mouseinfo):
              Called when the user double-clicks on an entry in the TreeView.
              Returns:
                (bool): True if the double-click was handled, False if the
                  default action should kick in. The default action will invoke
                  the rename procedure for the object, causing `SetName()` to be
                  called.
              c4d.gui.MessageDialog("You clicked on " + str(obj))
          def DeletePressed(self, root, userdata):
              "Called when a delete event is received."
              for tex in reversed(list(TextureObjectIterator(self.listOfTexture))):
                  if tex.IsSelected:
                      listToRemove = objParent.GetChildren() if objParent is not None else self.listOfTexture
                      listToRemove.remove(tex)
          def DragStart(self, root: object, userdata: object, obj: object) -> int:
              print("drag")
              c4d.gui.SetMousePointer(c4d.MOUSE_INSERTMOVE)
              return c4d.TREEVIEW_DRAGSTART_ALLOW | c4d.TREEVIEW_DRAGSTART_SELECT
          def SetDragObject(self, root: object, userdata: object, obj: object) -> None:
              pass
      class TestDialog(c4d.gui.GeDialog):
          _treegui = None  # Our CustomGui TreeView
          _listView = ListView()  # Our Instance of c4d.gui.TreeViewFunctions
          def CreateLayout(self):
              # Create the TreeView GUI.
              customgui = c4d.BaseContainer()
              customgui.SetBool(c4d.TREEVIEW_BORDER, c4d.BORDER_THIN_IN)
              customgui.SetBool(c4d.TREEVIEW_HAS_HEADER, True)  # True if the tree view may have a header line.
              customgui.SetBool(c4d.TREEVIEW_HIDE_LINES, False)  # True if no lines should be drawn.
              customgui.SetBool(c4d.TREEVIEW_MOVE_COLUMN, True)  # True if the user can move the columns.
              customgui.SetBool(c4d.TREEVIEW_RESIZE_HEADER, True)  # True if the column width can be changed by the user.
              customgui.SetBool(c4d.TREEVIEW_FIXED_LAYOUT, True)  # True if all lines have the same height.
              customgui.SetBool(c4d.TREEVIEW_ALTERNATE_BG, True)  # Alternate background per line.
              customgui.SetBool(c4d.TREEVIEW_CURSORKEYS, True)  # True if cursor keys should be processed.
              customgui.SetBool(c4d.TREEVIEW_NOENTERRENAME, False)  # Suppresses the rename popup when the user presses enter.
              customgui.SetBool(c4d.TREEVIEW_NO_MULTISELECT, True)
              self._treegui = self.AddCustomGui(1000, c4d.CUSTOMGUI_TREEVIEW, "", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 300,
                                                300, customgui)
              if not self._treegui:
                  print("[ERROR]: Could not create TreeView")
                  return False
              self.AddButton(1001, c4d.BFH_CENTER, name="Add")
              self.AddButton(1002, c4d.BFH_CENTER, name="Add Child to selected")
          def InitValues(self):
              # Initialize the column layout for the TreeView.
              layout = c4d.BaseContainer()
              layout.SetLong(ID_CHECKBOX, c4d.LV_CHECKBOX)
              layout.SetLong(ID_NAME, c4d.LV_TREE)
              layout.SetLong(ID_OTHER, c4d.LV_USER)
              self._treegui.SetLayout(3, layout)
              # Set the header titles.
              self._treegui.SetHeaderText(ID_CHECKBOX, "Check")
              self._treegui.SetHeaderText(ID_NAME, "Name")
              self._treegui.SetHeaderText(ID_OTHER, "Other")
              self._treegui.Refresh()
              # Set TreeViewFunctions instance used by our CUSTOMGUI_TREEVIEW
              self._treegui.SetRoot(self._treegui, self._listView, None)
          def Command(self, id, msg):
              # Click on button
              if id == 1001:
                  # Add data to our DataStructure (ListView)
                  newID = len(self._listView.listOfTexture) + 1
                  tex = TextureObject("T{}".format(newID))
                  self._listView.listOfTexture.append(tex)
                  # Refresh the TreeView
              elif id == 1002:
                  for parentTex in TextureObjectIterator(self._listView.listOfTexture):
                      if not parentTex.IsSelected:
                          continue
                      newID = len(parentTex.GetChildren()) + 1
                      tex = TextureObject("T{0}.{1}".format(str(parentTex), newID))
                      parentTex.AddChild(tex)
          global dialog
          dialog = TestDialog()
          dialog.Open(c4d.DLG_TYPE_ASYNC, defaulth=600, defaultw=600)
      Thanks for your help
      η›ΈδΏ‘ζˆ‘οΌŒε―δ»₯ηš„οΌ
        ferdinand @chuanzhen
        Hey @chuanzhen,
        Thank you for reaching out to us. Well, you must implement the documented drag methods which you already sort of started to implement in your code. The reason why your DragStart did not do anything, is because you need at least DragStart and GetDragType to get drag handling going.
        What is also not so good in your example is that you implement your own hierarchy type, which complicates things when you want to drag data, as you cannot pack up arbitrary data as drag data. I solved this by packing up you TextUreObject trees as BaseList2D trees for dragging.
        See also Handling Treeview File Drag and Drop Events (this topic is about drag and drop events from the outside and not internal ones).
        Result
        Code
        """ I put --- snip (FH) --- markers around the places I modified.
        import weakref
        import mxutils
        ID_CHECKBOX = 1
        ID_NAME = 2
        ID_OTHER = 3
                yield parentTex
                    yield childTex
            _selected = False
            _open = True
                self.children = []
                self._parent = None
            @property
            def Select(self):
            def Deselect(self):
            @property
            def IsOpened(self):
                return self._open
            def Open(self):
                self._open = True
            def Close(self):
                self._open = False
                if self._parent:
                return None
            def __repr__(self):
                return str(self)
            def __str__(self):
            # --- snip (FH) ---
            # We must be able to pack up the to be dragged things in a data format the C++ core can deal
            # with, a pure Python object such as TextureObject cannot be the content of a drag event. So,
            # we realize converting TextureObject from and to to BaseList2D. Generally it would be better
            # to use BaseList2D directly as your tree elements.
            # Conversions for the fields of #TextureObject into the data container of a node.
            ID_TEXTURE: int = 10000
            ID_OTHER: int = 10001
            ID_SELECTED: int = 10002
            ID_OPEN: int = 10003
            def ToBaseList2D(self) -> c4d.BaseList2D:
                """Serializes #self into a tree of BaseList2D instances.
                # We use null objects to store our data but also could use any other node.
                node: c4d.BaseList2D = c4d.BaseList2D(c4d.Onull)
                node[self.ID_TEXTURE] = self.texturePath
                node[self.ID_OTHER] = self.otherData
                node[self.ID_SELECTED] = False
                node[self.ID_OPEN] = self.IsOpened
                for child in self.children:
                    child.ToBaseList2D().InsertUnderLast(node)
                return node
            @classmethod
            def FromBaseList2D(cls, node: c4d.BaseList2D) -> "TextureObject":
                """Deserializes #node in a #TextureObject tree.
                obj = cls(node[cls.ID_TEXTURE])
                obj.otherData = node[cls.ID_OTHER]
                obj._selected = node[cls.ID_SELECTED]
                obj._open = node[cls.ID_OPEN]
                for child in node.GetChildren():
                    obj.AddChild(cls.FromBaseList2D(child))
                return obj
            # --- snip end (FH) ---
            def __init__(self):
            # --- snip (FH) ---
            # You made some really weird choices for root and userdata. The root is the TreeViewFunctions
            # itself, and userdata is None. The root is usually the root element of your displayed content,
            # e.g., ListView.listOfTexture in your case.
            def GetDragType(self, root: "ListView", userdata: None, obj: TextureObject) -> int:
                """Define what data type is being dragged, such as scene elements or strings.
                # There is no way to drag arbitrary Python data, so we chose atom arrays, i.e., scene
                # elements and pack up your TextureObject instances as scene elements.
                return c4d.DRAGTYPE_ATOMARRAY
            def DragStart(self, root: "ListView", userdata: None, obj: TextureObject) -> int:
                """Called when the user starts dragging an element and returns the allowed drag actions.
            def GenerateDragArray(self, root: "ListView", userdata: None,
                                  obj: TextureObject) -> list[c4d.BaseList2D]:
                """Called by Cinema 4D to let the treeview pack up the drag data for a drag event on #obj.
                # We just pack up #obj and send it as a node. I did not deal with multi selections here.
                return [obj.ToBaseList2D()]
            def AcceptDragObject(self, root: "ListView", userData: None, obj: TextureObject,
                                 dragType: int, dragData: any) -> tuple[bool, int]:
                """Called by Cinema 4D to decide if #dragData is valid data to be dragged onto #item.
                Since all rows accept textures being dragged onto them, we can ignore #item here.
                # Not the most through check, this for example will also "allow" drag events from the OM,
                # which then later on will fail. Here should be a more through check if #dragData is valid
                # data.
                if (dragType != c4d.DRAGTYPE_ATOMARRAY or
                    not mxutils.CheckIterable(dragData, c4d.BaseList2D, minCount=1)):
                    return False
                return c4d.INSERT_UNDER, False
            def InsertObject(self, root: "ListView", userData: None, obj: TextureObject, dragType: int,
                             dragData: any, insertMode: int, doCopy: bool) -> None:
                """Called by Cinema 4D once a drag event has finished which before has been indicated as
                valid by #AcceptDragObject.
                # Just unpack our drag data and insert it.
                node: c4d.BaseList2D = mxutils.CheckIterable(dragData, c4d.BaseList2D, minCount=1)[0]
                obj.AddChild(TextureObject.FromBaseList2D(node))
                return False
                return rValue
                if children:
                    return children[0]
                return None
                rValue = None
                return rValue
                rValue = None
                return rValue
                return hash(obj)
                        tex.Deselect()
                    obj.Select()
                    obj.Select()
                    obj.Deselect()
                if checked:
                    obj.Select()
                    obj.Deselect()
                if obj.IsSelected:
                return obj.IsOpened
                if onoff:
                    obj.Open()
                    obj.Close()
                if col == ID_OTHER:
                Returns:
                    called.
                    if tex.IsSelected:
                                                  300, customgui)
                    return False
                # Click on button
                if id == 1001:
                elif id == 1002:
                            continue
            global dialog
          Hey,
          And I forgot: I see this weakref stuff floating around for a while in TreeViewFunctions code. I do not know who brought it into circulation. It does not really hurt in a technical sense but makes such code more intimidating. You can remove it and write obj._parent = self instead of obj._parent = weakref.ref(self). A weak reference is a reference that does not prevent the referenced object from being garbage collected.
          When there is a child with a ref to a parent, what would be a scenario where one wants the parent to be deleted without the child being deleted or the child having its parent set to None. A child in CS has by definition always a parent, so having the child to weak-ref its parent seems pretty pointless (unless I am overlooking something here).
          chuanzhenC 1 Reply Last reply Reply Quote 0
            chuanzhen @ferdinand
            @ferdinand Thanks for your help!πŸ‘
