    Start IPR rendering in the viewport
    windowsc++2025
    5 Posts 2 Posters 799 Views 1 Watching
    • F Offline
      freeze
      I register a VideoPostPlugin as a renderer.Now I can render an image to viewport or picture viewer in c4d with my own renderer plugin.
      How can I get the message that the scene changed so I can update the render view with new scene data and display in the viewport of c4d ,just like Redshift Start IPR ,using c++.
      Many Thanks!
        ferdinand @freeze
        Hello @freeze,
        thank you for reaching out to us. Scene changes are communicated as the core message EVMSG_CHANGE, such messages can be received in the CoreMessage methods of a GeDialog (and derived types) or MessageData instance.
        There is however no data which would inform you what has changed. You are expected to track that yourself. See How to detect a new light and pram change? for one of the cases where we discussed tracking scene changes. The case is for Python which is more or less analogous to C++. They main difference in C++ is that you can use GeMarker directly and do not have to go over MAXON_CREATOR_ID (which is just the data of the GeMarker of the node).
        F 1 Reply Last reply Reply Quote 0
        • F Offline
          freeze @ferdinand
          Hello @ferdinand ,
          I have created a Message method as:
          Bool SmarayPlugin::Message(GeListNode* node, Int32 type, void* data)
              BaseList2D* const item = static_cast<BaseList2D*>(node);
              if (!item)
                  return false;
              BaseContainer* renderdata = item->GetDataInstance();
              switch (type)
              case MSG_DESCRIPTION_COMMAND:
                  DescriptionCommand* dc = static_cast< DescriptionCommand*>(data);
                  if (dc->_descId[0].id == AOV_MANAGER_BUTTON)
                      if (aov_dialog) {
                          aov_dialog->Close();
                          DeleteObj(aov_dialog);
                      aov_dialog = NewObjClear(UISmarayAOVManager, renderdata);
                      if (aov_dialog) {
                          aov_dialog->Open(DLG_TYPE::ASYNC, 800, 800, 800, 600);
                  break;
              default:
                  break;
              return VideoPostData::Message(node, type, data);
          I use it to get the button clicked event to create dialog for setting the AOVs and I find that it may get different type of Message .So can I just check if it is EVMSG_CHANGE and go through my own logic here?
            ferdinand @freeze
            Hey @freeze,
            no, that would not be correct. This is a NodeData::Message method you are showing us here which hooks into the message stream sent to a node, not the core message stream. As already explained above, you will need the CoreMessage method of a GeDialog (or derived types) or MessageData instance to receive core messages. I also posted a link to (Python) example code above.
            There is no dedicated manual for the message system in C++, but we have a small one for the Python API.
            • F Offline
              freeze @ferdinand
              @ferdinand Thank you for answering ,I 'll try it.
