    C++ Import Custom Extension With Modal
    windowsc++2024
    2 Posts 2 Posters 571 Views
    • R Offline
      RyanTheDev
      So im making a plugin in c++. I have a plugin successfully reading a custom file type however i cant intiate a dialogue, it just keeps failing. I was wondering if anyone had any refrences or solutions i could utilize to try and get this too work. Im trying to import materials and objects from this custom, file type through a pop up. Any help would be greatly apreciated.
      • i_mazlovI Offline
        i_mazlov @RyanTheDev
        Hi @RyanTheDev,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        Please elaborate on your question, there's no good reference or solution you can get without providing the context. What is a "custom file type"? do you mean you've implemented BaseSceneLoader plugin? When you try to open dialog? Is it happening on main thread? What's the code that does this? What does it mean "keeps failing" - does it give you error instead?
        You can also have a look at SCENEFILTER::DIALOGSALLOWED flag, if it's applicable in your case.
        Ilia
