    Render depth map using python
    3 Posts 2 Posters 965 Views 1 Watching
    • G Offline
      Gregor M
      I'm creating a simple Python plugin and i need to render depth map using c4d.RENDERFLAGS_EXTERNAL. I'm not sure how to do this.
      from c4d import gui, plugins, storage
      import os
      PLUGIN_ID = 1234567
      def GetFilterTypeFromFilename(filename):
          ext = os.path.splitext(filename)[1].lower()
          if ext == '.bmp':
              return c4d.FILTER_BMP
          elif ext == '.jpg' or ext == '.jpeg':
              return c4d.FILTER_JPG
          elif ext == '.png':
              return c4d.FILTER_PNG
          elif ext == '.tif' or ext == '.tiff':
              return c4d.FILTER_TIF
          elif ext == '.exr':
              return c4d.FILTER_EXR
              return c4d.FILTER_PNG  # Default to PNG if extension is unrecognized
      class RenderDialog(gui.GeDialog):
          DESTINATION_FILE = 1001
          BROWSE_BUTTON = 1002
          RENDER_BUTTON = 2000
          def CreateLayout(self):
              self.SetTitle("External Render Plugin")
              # Add Destination File Field
              self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT, cols=2)
              self.AddStaticText(id=0, flags=c4d.BFH_LEFT, name="Destination File:")
              self.AddEditText(id=self.DESTINATION_FILE, flags=c4d.BFH_SCALEFIT)
              self.GroupEnd()
              # Add Browse Button
              self.AddButton(id=self.BROWSE_BUTTON, flags=c4d.BFH_LEFT, name="Browse")
              # Add Render Button
              self.AddButton(id=self.RENDER_BUTTON, flags=c4d.BFH_CENTER, name="Render")
          def Command(self, id, msg):
              if id == self.BROWSE_BUTTON:
                  path = storage.SaveDialog(title="Select Destination File")
                  if path:
                      self.SetString(self.DESTINATION_FILE, path)
              elif id == self.RENDER_BUTTON:
                  path = self.GetString(self.DESTINATION_FILE)
                  if not path:
                      gui.MessageDialog("Please specify a destination file.")
                  # Get the active document and render settings
                  rd = doc.GetActiveRenderData()
                  rdata = rd.GetDataInstance().GetClone(c4d.COPYFLAGS_NONE)
                  # Set render settings
                  rdata[c4d.RDATA_PATH] = path
                  rdata[c4d.RDATA_RENDERENGINE] = c4d.RDATA_RENDERENGINE_STANDARD
                  # Create a bitmap to render into
                  width = int(rdata[c4d.RDATA_XRES])
                  height = int(rdata[c4d.RDATA_YRES])
                  bmp = c4d.bitmaps.BaseBitmap()
                  result = bmp.Init(width, height)
                  if result != c4d.IMAGERESULT_OK:
                      gui.MessageDialog("Failed to initialize bitmap.")
                  # Trigger render
                  render_result = c4d.documents.RenderDocument(
                      doc,       # Document to render
                      rdata,     # Render settings
                      bmp,       # Bitmap to render into
                      c4d.RENDERFLAGS_EXTERNAL | c4d.RENDERFLAGS_DONTANIMATE  # Flags
                  if render_result != c4d.RENDERRESULT_OK:
                      gui.MessageDialog("Render failed.")
                      # Determine the appropriate file format filter
                      filter_type = GetFilterTypeFromFilename(path)
                      # Save the rendered image
                      save_result = bmp.Save(path, filter_type, c4d.BaseContainer())
                      if save_result != c4d.IMAGERESULT_OK:
                          gui.MessageDialog("Failed to save image.")
                          gui.MessageDialog("Render completed and saved.")
              return False
      class ExternalRenderPlugin(plugins.CommandData):
          def __init__(self):
              self.dlg = None
          def Execute(self, doc):
              if not self.dlg:
                  self.dlg = RenderDialog()
              self.dlg.Open(c4d.DLG_TYPE_ASYNC, defaultw=400, defaulth=100)
          plugins.RegisterCommandPlugin(
              id=PLUGIN_ID,
              str="External Render Plugin",
              info=0,
              icon=None,
              help="Render current frame to a specified file",
              dat=ExternalRenderPlugin()
        ferdinand @Gregor M
        Hello @Gregor-M,
        Thank you for reaching out to us. You cannot really use c4d.documents.RenderDocument for this as it does not rally support multipass output. But you can use the render queue.
        Result
        Code
        """Renders a depth channel for the active document and shows it in the picture viewer.
        This script is a demonstration of how to render a depth pass for the active document and show it in
        the picture viewer. It does so by saving the document to a temporary file, setting up the depth
        pass, and then rendering the document using the batch renderer. After the rendering is done, the
        depth pass is loaded and shown in the picture viewer.
        We cannot use RenderDocument() to render a depth pass, as it does not support multipass channels.
        And we also cannot just use the render command, as a script manager script is blocking for commands,
        i.e., the render command will only be executed after the script has finished.
        # Requirements
        - The document must be saved before rendering.
        - The render engine must be set to Standard Renderer, as the depth pass is not supported by all
          other engines. If yours does, you can remove or adjust the check in the script. But Redshift has
          for example its own pass system.
        import os
        import time
        import mxutils
        doc: c4d.documents.BaseDocument # The active document.
        def EnableMultiPass(rData: c4d.documents.RenderData, passType: int) -> None:
            """Assures that the given #rData has a multipass of the given #passType.
            # Find an existing pass of the given type.
            hasPass: bool = False
            element: c4d.BaseList2D = rData.GetFirstMultipass()
            while element:
                if element.GetDataInstance()[c4d.MULTIPASSOBJECT_TYPE] == passType:
                    element.DelBit(c4d.BIT_VPDISABLED) # Make sure it is enabled.
                    hasPass = True
                    break
                element = element.GetNext()
            # If the pass was not found, create a new one.
            if not hasPass:
                element: c4d.BaseList2D = mxutils.CheckType(c4d.BaseList2D(c4d.Zmultipass))
                element[c4d.MULTIPASSOBJECT_TYPE] = passType
                rData.InsertMultipass(element)
            """Run the script.
            # Get the name and path of the current document and bail when it is an unsaved document.
            name: str = os.path.splitext(doc.GetDocumentName())[0]
            path: str = doc.GetDocumentPath()
            if not path:
                raise ValueError("The document must be saved before rendering.")
            # Get the batch render and bail when it is already running.
            batch: c4d.documents.BatchRender = c4d.documents.GetBatchRender()
            if batch.IsRendering():
                raise ValueError("The batch render is already running.")
            # Define a path for a copy of this document and a path to save the multipass images to.
            documentPath: str = os.path.join(path, f"{name}_job.c4d")
            multipassPath: str = os.path.join(path, f"{name}_job_multipass")
            depthPngPath: str = f"{multipassPath}_depth.png"
            # Get the render data from the document and get and set the relevant settings.
            rData: c4d.documents.RenderData = doc.GetActiveRenderData()
            if rData[c4d.RDATA_RENDERENGINE] != c4d.RDATA_RENDERENGINE_STANDARD:
                raise ValueError("The render engine must be set to Standard Renderer.")
            # Setup the depth pass.
            EnableMultiPass(rData, c4d.VPBUFFER_DEPTH)
            rData[c4d.RDATA_MULTIPASS_ENABLE] = True
            rData[c4d.RDATA_MULTIPASS_SAVEIMAGE] = True
            rData[c4d.RDATA_MULTIPASS_SAVEONEFILE] = False
            rData[c4d.RDATA_MULTIPASS_SAVEFORMAT] = c4d.FILTER_PNG
            rData[c4d.RDATA_MULTIPASS_FILENAME] = multipassPath
            # We cannot use RenderDocument() to render a depth pass, as it does not support multipass
            # channels. So, we must use the render queue and for that also setup the render data (which
            # is also why we did set the multipass save settings above).
            # Save the new file state to #documentPath and then push it into the render queue.
            if not c4d.documents.SaveDocument(doc, documentPath, c4d.SAVEDOCUMENTFLAGS_0, c4d.FORMAT_C4DEXPORT):
                raise ValueError("Failed to save the document.")
            # Disable all possibly already existing jobs in the batch renderer, add a new job in front,
            # and carry out the rendering.
            for i in range(batch.GetElementCount()):
                batch.EnableElement(i, False)
            batch.AddFile(documentPath, 0)
            batch.SetRendering(c4d.BR_START)
            c4d.StatusSetText(f"Rendering {name}...")
            c4d.StatusSetSpin()
            while batch.IsRendering():
                time.sleep(.25)
            # The batch render is done, we check if the depth pass exists and load it.
            c4d.StatusClear()
            if not os.path.exists(depthPngPath):
                raise ValueError(f"Failed to render the multipass image to {depthPngPath}.")
            bmp: c4d.bitmaps.BaseBitmap = c4d.bitmaps.BaseBitmap()
            if not bmp.InitWith(depthPngPath):
                raise ValueError(f"Failed to load bitmap from: {depthPngPath}")
            # Do something with the bitmap, we just show it in the picture viewer.
            c4d.bitmaps.ShowBitmap(bmp)
        if __name__=='__main__':
        • G Offline
          Gregor M
          Thank you for the quick answer.
          Unfortunately this approach was quite destructive for my workflow, so i found a workaround using materials and 3d gradients. For anyone who want to render z-depth in python from c4d scene, this may be the approach. There may be some tweaks considering color space.
          It would be nice to get access to this kind of data inside cinema 4d's python without crazy workarounds.
          import os
          PLUGIN_ID = 1234567  # Replace this ID with your unique plugin ID from Maxon
              if ext == '.bmp':
              elif ext == '.png':
              elif ext == '.exr':
                  self.GroupEnd()
                  # Add Browse Button
                  # Add Render Button
                      if path:
                      if not path:
                      # Create a large sphere object
                      sphere = c4d.BaseObject(c4d.Osphere)
                      sphere[c4d.PRIM_SPHERE_RAD] = 10000000  # Set radius to 10,000,000 m
                      doc.InsertObject(sphere)
                      # Check if a material named "LuminanceMaterial" already exists
                      material = doc.SearchMaterial("LuminanceMaterial")
                      if not material:
                          # Create new material and set its parameters
                          material = c4d.BaseMaterial(c4d.Mmaterial)
                          material.SetName("LuminanceMaterial")
                          material[c4d.MATERIAL_USE_COLOR] = False
                          material[c4d.MATERIAL_USE_REFLECTION] = False
                          material[c4d.MATERIAL_USE_LUMINANCE] = True
                          # Create gradient shader and set it as luminance
                          gradient_shader = c4d.BaseShader(c4d.Xgradient)
                          if gradient_shader:
                              gradient_shader[c4d.SLA_GRADIENT_TYPE] = c4d.SLA_GRADIENT_TYPE_3D_LINEAR  # 3D Linear Gradient
                              gradient_shader[c4d.SLA_GRADIENT_SPACE] = c4d.SLA_GRADIENT_SPACE_WORLD  # World space
                              gradient_shader[c4d.SLA_GRADIENT_CYCLE] = False
                              material[c4d.MATERIAL_LUMINANCE_SHADER] = gradient_shader
                              material.InsertShader(gradient_shader)
                          # Insert material into the document
                          doc.InsertMaterial(material)
                      # Update gradient start and end points for the current camera
                      gradient_shader = material[c4d.MATERIAL_LUMINANCE_SHADER]
                      if gradient_shader:
                          camera = doc.GetActiveObject()
                          if not camera or camera.GetType() != c4d.Ocamera:
                              camera = doc.GetRenderBaseDraw().GetSceneCamera(doc)
                          if not camera:
                              camera = doc.GetRenderBaseDraw().GetEditorCamera()
                          if camera:
                              start_position = camera.GetMg().off
                              focus_distance = camera[c4d.CAMERAOBJECT_TARGETDISTANCE]
                              end_position = start_position + (camera.GetMg().v3 * focus_distance)  # Use v3 for z-axis direction
                              gradient_shader[c4d.SLA_GRADIENT_START] = start_position
                              gradient_shader[c4d.SLA_GRADIENT_END] = end_position
                      # Enable material override in render settings
                      rd[c4d.RDATA_MATERIAL_OVERRIDE] = True
                      rd[c4d.RDATA_MATERIAL_OVERRIDE_LINK] = material
                      # Trigger render
                      # Turn off material override after rendering
                      rd[c4d.RDATA_MATERIAL_OVERRIDE] = False
                      rd[c4d.RDATA_MATERIAL_OVERRIDE_LINK] = None
                      # Delete the large sphere after rendering
                      sphere.Remove()
                      # Delete the material after rendering
                      if material:
                          material.Remove()
                      # Refresh the document
                  return False
              def __init__(self):
                  self.dlg = None
                  if not self.dlg:
                  id=PLUGIN_ID,
                  info=0,
                  icon=None,
