    HOW TO Turn off the auto tangent checkbox on keyframes using python API
    pythonwindows20232024
    4 Posts 3 Posters 1.6k Views
    • H Offline
      heytraile
      Hi, I'd like to know how to turn off the Auto Tangents and Remove Overshooting checkbox on keys in C4D using the python API. I wrote a tool to bring keyframe data from C4D to other applications but with Auto Tangents and Remove Overshooting on, I'm getting differences in my tangents. Once I turn them off and run my tool again, I'm getting the correct results.
      There is the
      CKey.SetAutomaticTangentMode
      but it does nothing for me. Is there a way to do this with the API? I've attached an image to show the checkboxes I'm referring to.
      Thanks in advance.
      • K Offline
        kng_ito
        These can be used for doing so.
        CKey.ChangeNBit(c4d.NBIT_CKEY_AUTO, False)
        CKey.ChangeNBit(c4d.NBIT_CKEY_REMOVEOVERSHOOT, False)
        By the way, if you want to get correct value of tangents, CCurve.GetTangents() should work correctly, instead of using CKey.GetTimeLeft, etc.
        • i_mazlovI Offline
          i_mazlov @heytraile
          Hi @heytraile ,
          Getting Started
          It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
          About your First Question
          Function c4d.SetAutomaticTangentMode() is meant to change the value of the "Angle" attribute and in my opinion is just poorly named.
          What you actually need to do is to execute function ChangeNBit() (@kng_ito, thank you for providing fast answer). However, the usage kng_ito showed above is not 100% correct. Namely, you'd need to use one of the NBITCONTROL values. In case you want to remove these checkboxes, the code would be:
          key.ChangeNBit(c4d.NBIT_CKEY_AUTO, c4d.NBITCONTROL_CLEAR)
          key.ChangeNBit(c4d.NBIT_CKEY_REMOVEOVERSHOOT, c4d.NBITCONTROL_CLEAR)
          You can also find some code examples on how to work with animation related data in our repository, e.g. CTrack Create Keys
          Ilia
          H 1 Reply Last reply Reply Quote 0
          • H Offline
            heytraile @i_mazlov
            @i_mazlov Thanks much for explanation.
