    How to access and modify the default gravity value of the scene using Python script in Cinema 4D?
    3 Posts 2 Posters 634 Views 1 Watching
    • lakpoL Offline
      lakpo
      Hi everyone,
      I'm working on a Python script in Cinema 4D and I'm trying to toggle the default gravity of the scene between 0 and -981. I've tried several approaches, but I can't seem to find the correct method to access and modify this value.
      Here's what I've attempted so far:
      from typing import Optional
      doc: c4d.documents.BaseDocument  # The active document
      op: Optional[c4d.BaseObject]  # The active object, None if unselected
          def object() -> Optional[c4d.BaseObject]:
              return doc.GetActiveObject()
          active_object = object()
          if not active_object:
          current_gravity = active_object[c4d.PBDSCENE_DEFAULTGRAVITY]
          if current_gravity == 0:
              active_object[c4d.PBDSCENE_DEFAULTGRAVITY] = -981
              active_object[c4d.PBDSCENE_DEFAULTGRAVITY] = 0
      Unfortunately, this doesn't work. If anyone can point me to the correct way to access and modify this value, that would be great!
      Thanks in advance for your help! 😊
        ferdinand @lakpo
        Hey @lakpo,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        The answer to your question depends on what you would consider the 'default gravity value of the scene'. There are basically two interpretations:
        1. You want to change the value for the default simulation scene as accessible via the Attribute Manager in document mode. You would here have to dig out the default simulation scene from its scene hook. That scene object will never be part of the normal object tree and you can therefor not access it with BaseDocument.GetActiveObject. We recently talked about this very subject here including some example code.
        2. You want to reset the gravity value of a simulation scene, no matter if the default or a custom one, to its default value. You would have to access the description of the node, get the parameter you are interested in, and then read DESC_DEFAULT.
        • lakpoL Offline
          lakpo
          Hi Ferdinand,
          I just wanted to thank you for your invaluable help! Thanks to your guidance, I was able to solve my issue with toggling the default gravity in Cinema 4D. Honestly, I didn't think it would be this complicated! 😅
          For anyone who might encounter a similar problem, here's the script I used, based on your code. It allows access to the global default simulation scene in the simulation hook and toggles the gravity value between 0 and -981:
          op: c4d.BaseObject | None  # The primary selected object in the document. Can be None.
          c4d.SHsimulation: int = 1057220  # The ID of the simulation hook.
              """Called by Cinema 4D when the script is executed."""
              # Get the simulation hook of the active document
              simulationHook: c4d.BaseList2D | None = doc.FindSceneHook(c4d.SHsimulation)
              if not simulationHook:
                  raise RuntimeError("Cannot find the simulation hook.")
              # Retrieve the object branch from the simulation hook
              branches: list[dict] = simulationHook.GetBranchInfo()
              data: dict | None = next(n for n in branches if n["id"] == c4d.Obase)  # We're looking for the object branch.
              if not data:
                  raise RuntimeError("Malformed simulation hook with missing object branch.")
              # Get the simulation scene
              simulationScene: c4d.BaseObject | None = data["head"].GetFirst()
              if not simulationScene:
                  raise RuntimeError("Malformed simulation hook with missing object branch children.")
              # Toggle gravity between 0 and -981
              if simulationScene[c4d.PBDSCENE_DEFAULTGRAVITY] == 0:
                  simulationScene[c4d.PBDSCENE_DEFAULTGRAVITY] = -981
                  simulationScene[c4d.PBDSCENE_DEFAULTGRAVITY] = 0
          This script toggles the default gravity of the simulation scene between 0 and -981 depending on its current value.
          Thanks again for your help! I hope this can be useful to others who might face the same issue.
