    Plugin or script on python for receive data (udp server)
    Scheduled Pinned Locked Moved General Talk
    programming
    2 Posts 2 Posters 903 Views 1 Watching
    • D Offline
      damzic
      Good day!
      I'm using C4D from 2009 year and i'm very like it. But this software didn't have realtime face mocap function. And didn`t have realtime mocap plugins, I didn't find any simple ones, at least. but now i have all functions for do this.The only problem remains receiving and processing data in real time. I tried to host a node with a Python script in Expresso, which had a listening server, but due to an interface update the program froze.
      Facial motion capture software (IFacialMocap) sends data in next format:
      BlendShape Name-Parameters (0 ~ 100) | BlendShape Names-Parameters (0 ~ 100) | .... | = head # Euler angles X (degree), Euler angles Y, Euler angles Z, Position values X, Position values Y, Position values Z | rightEye #Euler angles X, Euler angles Y, Euler angles Z | leftEye #Euler angles X, Euler angles Y, Euler angles Z |
      No have problem with the parsing data, problem with receive it.
      Now i am recording in blender, then import to C4D, then create Xpresso chains and transfer the facial blendshapes animation along the chains.
      Here is a short video of result:
      Facial blendshapes work fine, head rotation including.
      I don't need this personally, but i want create open plugin for C4D with real time face animation. It will be cool look in Cinema.
      If somebody has some free time and knows the intricacies of working with python in C4D, i am ready for preparing this feature. Due to high workload in my project, have no time learning C4D python realisation. For more questions [email protected].
      • M Offline
        m_adam
        Hi just in case for Cinema 4D, there is already Move by Maxon. With that's said it's always nice to have new plugins in Cinema 4D.
        I have to admit I struggle a bit to understand if you ask for someone to help you to solve your issue or take over the Cinema 4D development of this plugin.
        If this is the second one I would encourage you to be a bit more clear in order to maybe convince someone to take over.
        In any case good luck and if you have any technical question related to Cinema 4D, feel free to ask in the Cinema 4D category.
