    In the UV Manager,cubic's c4d.CallCommand()
    python2024
    4 Posts 2 Posters 811 Views
    • 1 Offline
      1279906127
      In the UV Manager, what is the corresponding c4d.CallCommand() ID for cubic? I have looked for a long time and still can’t find it, and it doesn’t display the c4d.CallCommand ID in the Script Manager either. Thank you!Snipaste_2024-04-28_20-38-59.jpg
      • 1 Offline
        1279906127
        I’m not very familiar with using c4d.modules.bodypaint.CallUVCommand.
        • i_mazlovI Offline
          i_mazlov @1279906127
          Hi @1279906127,
          Getting Started
          It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
          About your First Question
          You can find an example on how the CallUvCommand is supposed to be used here: call_uv_command_r18.py. There's also an example from Ferdinand on how one can use automatic uv commands here: How to run UVCOMMAND_OPTIMALCUBICMAPPING.
          Regarding the Projection commands, these are not exposed to our public api and hence you cannot directly use them.
          Ilia
          • 1 Offline
            1279906127
            Okay, thank you!
