    Comparing render settings
    windows2024python
    2 Posts 2 Posters 845 Views 1 Watching
    • H Offline
      hoganXYZ
      Hello fellow developers, this is my first post so I hope I've accurately tagged and formatted. I'll try to be as clear as possible, but this is one of my first large scale projects so I may miss some very obvious issues, refer to things incorrectly, or build things out in a overly-verbose way. I'm more than happy to clarify anything.
      The Goal
      Allow an artist to define render setting and project setting guidelines in a scene file as well as mark the critical settings. This data would then be used as a sanity check before a job could be submitted to a web based or local render farm.
      Current approach
      Currently I am only focused on properly generating the guidelines as it will teach me about properly accessing the data I need. Here is the current basic flow:
      • Get the current doc
      • Get the Active Render Data
      • Get the name of the render data
      • For the data and ids in the renderdata.GetDescription(c4d.DESCFLAGS_DESC_NONE), get the name and the identity.
      • GetDataInstance of the renderdata, then use GetData(each id) to get the value of each setting
      ex: Parameter Name: Anti-Aliasing, ID: (5002, 15, 110304), Type: RDATA_ANTIALIASING
      First question: This does not allow me to find the name, or description, or container id of the selected option, so I can get the value and look up the representation of that value, but it requires me to reference the drsettings.h file or keep a lookup table in my script. Is there a way I can find the strings I'm looking for? I want to retrieve "RDATA_ANTIALIASING_GEOMETRY", "Geometry"
      It is important that I retrieve detailed information about the redshift AOV settings, so I have split that into a separate process. I wrote this first, so the method is different and I will likely refactor to work more similarly to above.
      • get redshift videopost redshift.FindAddVideoPost(renderdata, redshift.VPrsrenderer)
      • iterate through a dictionary of hard-coded container ids with corresponding nested dictionaries describing their selections.
      ex:
      "REDSHIFT_AOV_FILE_COMPRESSION" : {
              "Display Name" : "File Compression Type",
              "Values" : {
                  1: {
                      "Display Name" : "File Compression Default",
                      "Attribute Identifer" : "REDHIFT_AOV_FILE_COMPRESSION_DEFAULT"
                  100: {
                      "Display Name" : "File Compression TIFF LZW",
                      "Attribute Identifer" : "REDHIFT_AOV_FILE_COMPRESSION_TIFF_LZW"
      Second question: Am I making this way harder on myself than I need it to be? Is there a more elegant solution that simply 'zips' two render settings and flags any crashes?
      I am still struggling to understand how this data is represented through the sdk and how to debug. I am trying to figure out how I can 'browse' the data that is retrieved when I call GetActiveRenderData() for example, as that would help me decide how to store and access it later.
      Anyway I hope this isn't too basic of a question and I am already very thankful for the insight shared on other posts. I will be continuing to work on this for a while, so if I make any significant changes I will update here.
      Thanks in advance.
        ferdinand @hoganXYZ
        Hello @hoganXYZ,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        While you obviously have put a lot of effort in your posting, the somewhat brutal truth is that it is too long and does not pose a specific question, or that it is at least very hard to pinpoint them. I would recommend having a look at the support procedures lined out above and the section for how to ask good questions. The briefer the better and the question should be ideally in the first sentence.
        So, when I read here a bit between the lines, you want to access the data container of a node, for example for the render data. You somehow landed there on description access, but that is a little bit backwards way of doing things. I tried to untangle a few things in the code example shown below. I hope this helps.
        Code
        """Demonstrates how to access the parameter data of a node at the example of the active render data.
            # Get the active render data for the document.
            rdata: c4d.documents.RenderData = doc.GetActiveRenderData()
            # Each scene element (e.g. objects, materials, tags, etc.) has a a data container and a
            # description. The data container holds the actual data, while the description holds the
            # UI data for that data. We get here an instance of the data container, i.e., all changes
            # made to #data will be reflected in the actual render data.
            data: c4d.BaseContainer = rdata.GetDataInstance()
            description: c4d.Description = rdata.GetDescription(c4d.DESCFLAGS_DESC_0)
            # Data containers are realized as c4d.BaseContainer objects. They are a list of key-value pairs
            # where the key is an integer and the value is one of the many types a BaseContainer can hold.
            # For these integer values then exist symbols to make things a bit more readable. We can iterate
            # over a container, but unlike for descriptions this will not unfold nested containers.
            for key, value in data:
                print(f"Key: {key}, Type: {type(value)}, Value: {value}")
            # Key: 6014, Type: <class 'int'>, Value: 1
            # Key: 5008, Type: <class 'float'>, Value: 1280.0
            # Key: 5009, Type: <class 'float'>, Value: 720.0
            # Key: 6004, Type: <class 'float'>, Value: 72.0
            # Key: 6006, Type: <class 'float'>, Value: 1.7777777777777777
            # Or we can use a symbol to access a value directly, here with __getitem__ syntax (the square
            # brackets) unique to Python (there are also GetInt32, GetFloat, GetString, etc. methods).
            print(f"{data[c4d.RDATA_XRES] = }")
            # data[c4d.RDATA_XRES] = 1280.0
            print ("\n", "-" * 100, "\n")
            # A description is the somewhat GUI counter part to the data container of a node, it holds for
            # example the name of a parameter (in the currently active language) and also its API symbol
            # (when there is one, not all parameters have one). Descriptions also expose more data "entries"
            # then a data container, as we will also see here things like groups and basic parameters shared
            # by all nodes.
            descData: c4d.BaseContainer # The data container of the currently yielded parameter.
            pid: int # The ID of the currently yielded parameter.
            # Iterate over all parameters in the description, this will unfold nested data.
            for descData, pid, _ in description:
                label: str = descData[c4d.DESC_NAME] # Get the label of the parameter as seen in Cinema 4D.
                # One of the more fringe values of a description are the API symbol strings. Here we better
                # use a getter function as there is no guarantee that these symbols are actually present.
                apiSymbol: str | None = descData.GetString(c4d.DESC_IDENT, None)
                if not apiSymbol:
                    apiSymbol = descData.GetString(c4d.DESC_IDENT_ORIGIN, None)
                # The value for the parameter can be accessed with the yielded DescID and and the node itself,
                # (not the data container). We use here C4DAtom.GetParameter() which in Python is again
                # wrapped as __getitem__ (in this case as GeListNode.__getitem__ for some reason and not as
                # C4DAtom.__getitem__).
                # We have to be however a bit cautious as not all parameter values are wrapped for Python
                # and accessing them will then fail. Other than the data container, the description will
                # relentlessly iterate over everything in that node, intended for public consumption or not.
                value: any = "Inaccessible in Python"
                try:
                    value: any = rdata[pid]
                except Exception as e:
                    pass
                print (f"Label: {label}, API Symbol: {apiSymbol}, Value: {value}")
                # Label: Basic Properties, API Symbol: Obaselist, Value: Inaccessible in Python
                # Label: Icon, API Symbol: ID_BASELIST_ICON_SETTINGS_GROUP, Value: Inaccessible in Python
                # Label: Icon File / ID, API Symbol: ID_BASELIST_ICON_FILE, Value:
                # Label: Icon Color, API Symbol: None, Value: 0
                # Label: Color, API Symbol: ID_BASELIST_ICON_COLOR, Value: Vector(1, 0.9, 0.4)
                # For more details about description containers see:
                #   https://developers.maxon.net/docs/py/2024_4_0a/modules/c4d/Description/
                # What to do here from here on out is up to you. You could technically accumulate all
                # parameter values that have an API symbol and then store them in a dictionary but the
                # question would be "why?" as that is not how Cinema 4D works. If you just want to store
                # aka serialize some Cinema 4D data, you should HyperFile as it can store things like a
                # BaseContainer directly.
                # Finally, regarding the unsupported types when accessing parameters, you will run into
                # this a lot when working with Redshift as it does not expose its specialized data
                # types to Python. The somewhat counter intuitive answer to that is then multi-level
                # DescIDs. Parameters can be nested in Cinema 4D and while you might not have access to
                #   myNode[c4d.RS_FANCY_PARAM]
                # which returns FancyType, you might have access to
                #   myNode[c4d.RS_FANCY_PARAM, c4d.RS_STRING_COMPONENT]
                # I.e., a string component within the FancyType. This is a bit of a rabbit hole and you
                # should open a new thread if you run into this issue.
        Full output (yikes!):
        Key: 6025, Type: <class 'int'>, Value: 1
        Key: 6002, Type: <class 'int'>, Value: 0
        Key: 6008, Type: <class 'float'>, Value: 1.0
        Key: 5300, Type: <class 'int'>, Value: 1036219
        Key: 5002, Type: <class 'int'>, Value: 1
        Key: 6016, Type: <class 'int'>, Value: 1
        Key: 6017, Type: <class 'int'>, Value: 1
        Key: 6018, Type: <class 'int'>, Value: 1
        Key: 6019, Type: <class 'int'>, Value: 1
        Key: 6020, Type: <class 'int'>, Value: 0
        Key: 6021, Type: <class 'int'>, Value: 0
        Key: 6027, Type: <class 'int'>, Value: 0
        Key: 5007, Type: <class 'int'>, Value: 2
        Key: 5010, Type: <class 'int'>, Value: 0
        Key: 5011, Type: <class 'float'>, Value: 320.0
        Key: 5012, Type: <class 'float'>, Value: 240.0
        Key: 5013, Type: <class 'float'>, Value: 1.0
        Key: 5014, Type: <class 'float'>, Value: 1.0
        Key: 5016, Type: <class 'int'>, Value: 1
        Key: 5081, Type: <class 'int'>, Value: 1
        Key: 5017, Type: <class 'c4d.BaseTime'>, Value: <c4d.BaseTime object at 0x7f8364192080>
        Key: 5018, Type: <class 'c4d.BaseTime'>, Value: <c4d.BaseTime object at 0x7f8364190a00>
        Key: 5019, Type: <class 'int'>, Value: 0
        Key: 5020, Type: <class 'float'>, Value: 30.0
        Key: 5021, Type: <class 'int'>, Value: 0
        Key: 5022, Type: <class 'int'>, Value: 1
        Key: 5024, Type: <class 'int'>, Value: 1
        Key: 5025, Type: <class 'int'>, Value: 15
        Key: 5026, Type: <class 'int'>, Value: 15
        Key: 5027, Type: <class 'float'>, Value: 0.001
        Key: 5028, Type: <class 'float'>, Value: 0.5
        Key: 28508, Type: <class 'float'>, Value: 2.0
        Key: 28509, Type: <class 'float'>, Value: 2.0
        Key: 28510, Type: <class 'int'>, Value: 0
        Key: 5061, Type: <class 'float'>, Value: 1.0
        Key: 5063, Type: <class 'int'>, Value: 5
        Key: 5064, Type: <class 'int'>, Value: 1
        Key: 5033, Type: <class 'int'>, Value: 1100
        Key: 5035, Type: <class 'int'>, Value: 0
        Key: 5076, Type: <class 'int'>, Value: 1
        Key: 5077, Type: <class 'int'>, Value: 0
        Key: 5036, Type: <class 'int'>, Value: 0
        Key: 5038, Type: <class 'int'>, Value: 0
        Key: 5039, Type: <class 'int'>, Value: 0
        Key: 5219, Type: <class 'int'>, Value: 0
        Key: 5040, Type: <class 'int'>, Value: 0
        Key: 5065, Type: <class 'int'>, Value: 320
        Key: 5066, Type: <class 'int'>, Value: 240
        Key: 5041, Type: <class 'str'>, Value:
        Key: 5043, Type: <class 'int'>, Value: 36
        Key: 5044, Type: <class 'float'>, Value: 0.0
        Key: 5045, Type: <class 'float'>, Value: 6.283185307179586
        Key: 5046, Type: <class 'int'>, Value: 19
        Key: 5047, Type: <class 'float'>, Value: 1.5707963267948966
        Key: 5048, Type: <class 'float'>, Value: -1.5707963267948966
        Key: 5052, Type: <class 'int'>, Value: 1
        Key: 5079, Type: <class 'int'>, Value: 0
        Key: 5080, Type: <class 'int'>, Value: 0
        Key: 5069, Type: <class 'int'>, Value: 1
        Key: 5071, Type: <class 'float'>, Value: 0.1
        Key: 5078, Type: <class 'float'>, Value: 0.5
        Key: 5070, Type: <class 'int'>, Value: 0
        Key: 5072, Type: <class 'int'>, Value: 0
        Key: 5073, Type: <class 'int'>, Value: 2
        Key: 5074, Type: <class 'int'>, Value: 1
        Key: 5082, Type: <class 'int'>, Value: 0
        Key: 5075, Type: <class 'int'>, Value: 1
        Key: 5200, Type: <class 'int'>, Value: 1
        Key: 5201, Type: <class 'int'>, Value: 1
        Key: 5606, Type: <class 'int'>, Value: 0
        Key: 5211, Type: <class 'int'>, Value: 0
        Key: 9200, Type: <class 'int'>, Value: 0
        Key: 5212, Type: <class 'int'>, Value: 0
        Key: 5202, Type: <class 'int'>, Value: 1
        Key: 5203, Type: <class 'int'>, Value: 1106
        Key: 5205, Type: <class 'int'>, Value: 0
        Key: 5206, Type: <class 'str'>, Value:
        Key: 5207, Type: <class 'int'>, Value: 1
        Key: 5208, Type: <class 'int'>, Value: 2
        Key: 5210, Type: <class 'int'>, Value: 1
        Key: 5401, Type: <class 'int'>, Value: 1
        Key: 5301, Type: <class 'int'>, Value: 0
        Key: 5603, Type: <class 'float'>, Value: 1.0
        Key: 5604, Type: <class 'int'>, Value: 1
        Key: 6023, Type: <class 'int'>, Value: 0
        Key: 6024, Type: <class 'int'>, Value: 1
        Key: 5502, Type: <class 'float'>, Value: 128.0
        Key: 6013, Type: <class 'int'>, Value: 1
        Key: 6012, Type: <class 'int'>, Value: 1
        Key: 7002, Type: <class 'int'>, Value: 1
        Key: 7000, Type: <class 'int'>, Value: 64
        Key: 7001, Type: <class 'int'>, Value: 64
        Key: 7003, Type: <class 'int'>, Value: 0
        Key: 7004, Type: <class 'int'>, Value: 0
        Key: 7005, Type: <class 'int'>, Value: 0
        Key: 7006, Type: <class 'int'>, Value: 0
        Key: 7007, Type: <class 'int'>, Value: 0
        Key: 7008, Type: <class 'int'>, Value: 0
        Key: 6003, Type: <class 'int'>, Value: 0
        Key: 6005, Type: <class 'int'>, Value: 1
        Key: 28507, Type: <class 'c4d.bitmaps.ColorProfile'>, Value: sRGB IEC61966-2.1
        Key: 5204, Type: <class 'c4d.BaseContainer'>, Value: <c4d.BaseContainer object at 0x7f836ac2c700>
        Key: 5702, Type: <class 'c4d.BaseContainer'>, Value: <c4d.BaseContainer object at 0x7f836ac2ca80>
        Key: 8000, Type: <class 'int'>, Value: 0
        Key: 8018, Type: <class 'int'>, Value: 0
        Key: 8001, Type: <class 'int'>, Value: 2
        Key: 8023, Type: <class 'int'>, Value: 1
        Key: 8002, Type: <class 'int'>, Value: 0
        Key: 8003, Type: <class 'int'>, Value: 0
        Key: 8004, Type: <class 'int'>, Value: 2
        Key: 8007, Type: <class 'int'>, Value: 0
        Key: 8005, Type: <class 'int'>, Value: 4
        Key: 8006, Type: <class 'int'>, Value: 0
        Key: 8013, Type: <class 'int'>, Value: 0
        Key: 8014, Type: <class 'c4d.Vector'>, Value: Vector(1, 0, 0)
        Key: 8015, Type: <class 'c4d.Vector'>, Value: Vector(0, 1, 0)
        Key: 8009, Type: <class 'int'>, Value: 0
        Key: 8011, Type: <class 'int'>, Value: 0
        Key: 8010, Type: <class 'int'>, Value: 0
        Key: 8012, Type: <class 'int'>, Value: 0
        Key: 8017, Type: <class 'int'>, Value: 0
        Key: 8021, Type: <class 'int'>, Value: 1
        Key: 8022, Type: <class 'int'>, Value: 0
        Key: 8500, Type: <class 'int'>, Value: 0
        Key: 8501, Type: <class 'int'>, Value: 0
        Key: 8502, Type: <class 'int'>, Value: 0
        Key: 9000, Type: <class 'int'>, Value: 1
        Key: 9001, Type: <class 'int'>, Value: 1
        Key: 9002, Type: <class 'int'>, Value: 1
        Key: 9003, Type: <class 'int'>, Value: 0
        Key: 9004, Type: <class 'int'>, Value: 1
        Key: 10002, Type: <class 'int'>, Value: 1
        Key: 10003, Type: <class 'c4d.InExcludeData'>, Value: <c4d.InExcludeData object at 0x7f836ac0f300>
        Key: 10004, Type: <class 'int'>, Value: 0
        Key: 10006, Type: <class 'int'>, Value: 0
        Key: 10007, Type: <class 'int'>, Value: 1
        Key: 10008, Type: <class 'int'>, Value: 0
        Key: 10011, Type: <class 'int'>, Value: 1
        Key: 10012, Type: <class 'int'>, Value: 1
        Key: 10013, Type: <class 'int'>, Value: 1
        Key: 10015, Type: <class 'int'>, Value: 1
        Key: 10000, Type: <class 'int'>, Value: 0
        Key: 10001, Type: <class 'NoneType'>, Value: None
        Key: 1041671, Type: <class 'c4d.Vector'>, Value: Vector(1, 0.9, 0.4)
        Label: , API Symbol: None, Value: Inaccessible in Python
        Label: , API Symbol: ID_BASELIST_ICON_PRESET_BUTTONS, Value: Inaccessible in Python
        Label: Name, API Symbol: ID_BASELIST_NAME, Value: My Render Setting
        Label: Layer, API Symbol: ID_LAYER_LINK, Value: None
        Label: Node Space, API Symbol: ID_BASELIST_NODESPACE_ADD_REMOVE_GROUP, Value: Inaccessible in Python
        Label: , API Symbol: ID_BASELIST_NODESPACE_ADD_REMOVE_BUTTONS, Value: Inaccessible in Python
        Label: Save, API Symbol: RDATA_GLOBALSAVE, Value: 1
        Label: Enable Multi-Pass Rendering, API Symbol: RDATA_MULTIPASS_ENABLE, Value: 1
        Label: Enable Stereoscopic Rendering, API Symbol: RDATA_STEREO, Value: 0
        Label: Material Override, API Symbol: RDATA_MATERIAL_OVERRIDE, Value: 0
        Label: Renderer, API Symbol: RDATA_RENDERENGINE, Value: 1036219
        Label: Enable Magic Bullet Looks, API Symbol: None, Value: 0
        Label: None, API Symbol: None, Value: Inaccessible in Python
        Label: Enable Post Effects Pass, API Symbol: None, Value: 1
        Label: Output, API Symbol: RDATA_GROUP_OUTPUT, Value: Inaccessible in Python
        Label: , API Symbol: RDATA_PRESET, Value: None
        Label: , API Symbol: RDATA_PRESETTEXT, Value: Preset: 1280 x 720
        Label: Width, API Symbol: RDATA_XRES, Value: 1280.0
        Label: Width, API Symbol: RDATA_XRES_VIRTUAL, Value: 1280.0
        Label: , API Symbol: RDATA_SIZEUNIT, Value: 0
        Label: Height, API Symbol: RDATA_YRES, Value: 720.0
        Label: Height, API Symbol: RDATA_YRES_VIRTUAL, Value: 720.0
        Label: Lock Ratio, API Symbol: RDATA_LOCKRATIO, Value: 0
        Label: Adapt Data Rate, API Symbol: RDATA_ADAPT_DATARATE, Value: 1
        Label: Resolution, API Symbol: RDATA_PIXELRESOLUTION, Value: 72.0
        Label: Resolution, API Symbol: RDATA_PIXELRESOLUTION_VIRTUAL, Value: 72.0
        Label: , API Symbol: RDATA_PIXELRESOLUTIONUNIT, Value: 1
        Label: Image Resolution: , API Symbol: RDATA_INFOTEXT, Value: 1280 x 720 Pixel
        Label: Warning:, API Symbol: RDATA_PIXELRESOLUTION_WARNING, Value:
        Label: Render Region, API Symbol: RDATA_RENDERREGION, Value: 0
        Label: Left Border, API Symbol: RDATA_RENDERREGION_LEFT, Value: 0
        Label: Copy from IRR, API Symbol: RDATA_FROMIRR, Value: Inaccessible in Python
        Label: , API Symbol: RDATA_FROMIRR_STATICTEXT, Value:
        Label: Top Border, API Symbol: RDATA_RENDERREGION_TOP, Value: 0
        Label: Right Border, API Symbol: RDATA_RENDERREGION_RIGHT, Value: 0
        Label: Bottom Border, API Symbol: RDATA_RENDERREGION_BOTTOM, Value: 0
        Label: Film Aspect, API Symbol: RDATA_FILMASPECT, Value: 1.7777777777777777
        Label: , API Symbol: RDATA_FILMPRESET, Value: 3
        Label: Pixel Aspect, API Symbol: RDATA_PIXELASPECT, Value: 1.0
        Label: , API Symbol: RDATA_PIXELPRESET, Value: 1
        Label: Frame Rate, API Symbol: RDATA_FRAMERATE, Value: 30.0
        Label: Frame Range, API Symbol: RDATA_FRAMESEQUENCE, Value: 1
        Label: From, API Symbol: RDATA_FRAMEFROM, Value: <c4d.BaseTime object at 0x7f836ab60500>
        Label: To, API Symbol: RDATA_FRAMETO, Value: <c4d.BaseTime object at 0x7f836ab60500>
        Label: Frame Step, API Symbol: RDATA_FRAMESTEP, Value: 1
        Label: Fields, API Symbol: RDATA_FIELD, Value: 0
        Label: Frames: , API Symbol: RDATA_FRAMEOUTPUT, Value: 1 (from 0 to 0)
        Label: Annotations, API Symbol: RDATA_HELPTEXT, Value:
        Label: Save, API Symbol: RDATA_GROUP_SAVE, Value: Inaccessible in Python
        Label: Regular Image, API Symbol: RDATA_GROUP_SAVEIMAGE, Value: Inaccessible in Python
        Label: Save, API Symbol: RDATA_SAVEIMAGE, Value: 1
        Label: File, API Symbol: RDATA_PATH, Value:
        Label: Format, API Symbol: RDATA_FORMAT, Value: 1100
        Label: Warning:, API Symbol: RDATA_FORMAT_WARNING, Value:
        Label: Options..., API Symbol: RDATA_SAVEOPTIONS, Value: <c4d.BaseList2D object called  with ID 300001078 at 140202407763456>
        Label: Depth, API Symbol: RDATA_FORMATDEPTH, Value: 0
        Label: Name, API Symbol: RDATA_NAMEFORMAT, Value: 0
        Label: Image Color Profile, API Symbol: RDATA_IMAGECOLORPROFILE, Value: sRGB IEC61966-2.1
        Label: Alpha Channel, API Symbol: RDATA_ALPHACHANNEL, Value: 0
        Label: Straight Alpha, API Symbol: RDATA_STRAIGHTALPHA, Value: 0
        Label: Separate Alpha, API Symbol: RDATA_SEPARATEALPHA, Value: 0
        Label: 8 Bit Dithering, API Symbol: RDATA_TRUECOLORDITHERING, Value: 1
        Label: Include Sound, API Symbol: RDATA_INCLUDESOUND, Value: 0
        Label: Bake View Transform, API Symbol: RDATA_BAKE_OCIO_VIEW_TRANSFORM, Value: 0
        Label: QuickTime VR Options, API Symbol: RDATA_GROUP_QUICKTIMEVR, Value: Inaccessible in Python
        Label: Generate File, API Symbol: RDATA_VRGENERATE, Value: 0
        Label: Horizontal Steps, API Symbol: RDATA_HSTEPS, Value: 36
        Label: Start Angle, API Symbol: RDATA_HSTART, Value: 0.0
        Label: End Angle, API Symbol: RDATA_HEND, Value: 6.283185307179586
        Label: Vertical Steps, API Symbol: RDATA_VSTEPS, Value: 19
        Label: Start Angle, API Symbol: RDATA_VSTART, Value: 1.5707963267948966
        Label: End Angle, API Symbol: RDATA_VEND, Value: -1.5707963267948966
        Label: Default X Resolution, API Symbol: RDATA_VRDEFAULTX, Value: 320
        Label: Default Y Resolution, API Symbol: RDATA_VRDEFAULTY, Value: 240
        Label: Multi-Pass Image, API Symbol: RDATA_GROUP_SAVEMULTIPASSIMAGE, Value: Inaccessible in Python
        Label: Save, API Symbol: RDATA_MULTIPASS_SAVEIMAGE, Value: 1
        Label: File, API Symbol: RDATA_MULTIPASS_FILENAME, Value:
        Label: Format, API Symbol: RDATA_MULTIPASS_SAVEFORMAT, Value: 1106
        Label: Warning:, API Symbol: RDATA_MULTIPASS_SAVEFORMAT_WARNING, Value:
        Label: Options..., API Symbol: RDATA_MULTIPASS_SAVEOPTIONS, Value: <c4d.BaseList2D object called  with ID 300001078 at 140202407771904>
        Label: Depth, API Symbol: RDATA_MULTIPASS_SAVEDEPTH, Value: 1
        Label: Multi-Layer File, API Symbol: RDATA_MULTIPASS_SAVEONEFILE, Value: 1
        Label: Layer Name as Suffix, API Symbol: RDATA_MULTIPASS_SUFFIX, Value: 1
        Label: User Defined Layer Name, API Symbol: RDATA_MULTIPASS_USERNAMES, Value: 0
        Label: Straight Alpha, API Symbol: RDATA_MULTIPASS_STRAIGHTALPHA, Value: 0
        Label: Compositing Project File, API Symbol: RDATA_GROUP_PROJECTFILE, Value: Inaccessible in Python
        Label: Save, API Symbol: RDATA_PROJECTFILE, Value: 0
        Label: Target Application, API Symbol: RDATA_PROJECTFILETYPE, Value: 0
        Label: Relative, API Symbol: RDATA_PROJECTFILELOCAL, Value: 0
        Label: Include Timeline Marker, API Symbol: RDATA_PROJECTFILEMARKER, Value: 0
        Label: Include 3D Data, API Symbol: RDATA_PROJECTFILEDATA, Value: 0
        Label: Save FBX File, API Symbol: RDATA_PROJECTFILEFBX, Value: 0
        Label: Save Alembic File, API Symbol: RDATA_PROJECTFILEABC, Value: 0
        Label: Save Project File..., API Symbol: RDATA_PROJECTFILESAVE, Value: Inaccessible in Python
        Label: Multi-Pass, API Symbol: RDATA_GROUP_MULTIPASS, Value: Inaccessible in Python
        Label: Separate Lights, API Symbol: RDATA_MULTIPASS_LIGHTS, Value: 0
        Label: Mode, API Symbol: RDATA_MULTIPASS_LIGHTMODE, Value: 2
        Label: Shadow Correction, API Symbol: RDATA_MULTIPASS_SHADOWCORRECTION, Value: 0
        Label: Anti-Aliasing, API Symbol: RDATA_GROUP_ANTIALIASING, Value: Inaccessible in Python
        Label: Anti-Aliasing, API Symbol: RDATA_ANTIALIASING, Value: 1
        Label: Min Level, API Symbol: RDATA_AAMINLEVEL, Value: 0
        Label: Max Level, API Symbol: RDATA_AAMAXLEVEL, Value: 2
        Label: Threshold, API Symbol: RDATA_AATHRESHOLD, Value: 0.1
        Label: Use Object Properties, API Symbol: RDATA_AAOBJECTPROPERTIES, Value: 1
        Label: Consider Multi-Passes, API Symbol: RDATA_AACONSIDERMULTIPASSES, Value: 0
        Label: Filter, API Symbol: RDATA_AAFILTER, Value: 0
        Label: Custom Size, API Symbol: RDATA_AACUSTOMFILTERSIZE, Value: 0
        Label: Filter Width, API Symbol: RDATA_AAFILTERSIZEX, Value: 2.0
        Label: Filter Height, API Symbol: RDATA_AAFILTERSIZEY, Value: 2.0
        Label: Clip Negative Component, API Symbol: RDATA_AACLIPNEGATIVE, Value: 0
        Label: MIP Scale, API Symbol: RDATA_AAMIPGLOBAL, Value: 0.5
        Label: Small Fragments, API Symbol: RDATA_SMALLFRAGMENTS, Value: 0
        Label: Material Override, API Symbol: RDATA_GROUP_OVERRIDEMAT, Value: Inaccessible in Python
        Label: Custom Material, API Symbol: RDATA_MATERIAL_OVERRIDE_LINK, Value: None
        Label: Mode, API Symbol: RDATA_MATERIAL_OVERRIDE_EXCLUSION_MODE, Value: 1
        Label: Materials, API Symbol: RDATA_MATERIAL_OVERRIDE_EXCLUSION_LIST, Value: <c4d.InExcludeData object at 0x7f836ab66f80>
        Label: Preserve, API Symbol: RDATA_GROUP_OVERRIDEMAT_PRESERVE, Value: Inaccessible in Python
        Label: Diffuse Color, API Symbol: RDATA_MATERIAL_OVERRIDE_COLOR, Value: 0
        Label: Luminance, API Symbol: RDATA_MATERIAL_OVERRIDE_LUMINANCE, Value: 0
        Label: Transparency, API Symbol: RDATA_MATERIAL_OVERRIDE_TRANS, Value: 1
        Label: Reflectance, API Symbol: RDATA_MATERIAL_OVERRIDE_REFL, Value: 0
        Label: Bump, API Symbol: RDATA_MATERIAL_OVERRIDE_BUMP, Value: 1
        Label: Normal, API Symbol: RDATA_MATERIAL_OVERRIDE_NORM, Value: 1
        Label: Alpha, API Symbol: RDATA_MATERIAL_OVERRIDE_ALPHA, Value: 1
        Label: Displacement, API Symbol: RDATA_MATERIAL_OVERRIDE_DSPL, Value: 1
        Label: The node materials are not supported., API Symbol: RDATA_GROUP_OVERRIDEMAT_PRESERVE_STR, Value:
        Label: Options, API Symbol: RDATA_GROUP_OPTIONS, Value: Inaccessible in Python
        Label: Transparency, API Symbol: RDATA_OPTION_TRANSPARENCY, Value: 1
        Label: Ray Threshold, API Symbol: RDATA_THRESHOLD, Value: 0.001
        Label: Refraction, API Symbol: RDATA_OPTION_REFRACTION, Value: 1
        Label: Ray Depth, API Symbol: RDATA_RAYDEPTH, Value: 15
        Label: Reflection, API Symbol: RDATA_OPTION_REFLECTION, Value: 1
        Label: Reflection Depth, API Symbol: RDATA_REFLECTIONDEPTH, Value: 5
        Label: Shadow, API Symbol: RDATA_OPTION_SHADOW, Value: 1
        Label: Shadow Depth, API Symbol: RDATA_SHADOWDEPTH, Value: 15
        Label: Limit Reflections to Floor/Sky, API Symbol: RDATA_LIMITREFLECTION, Value: 0
        Label: Level of Detail, API Symbol: RDATA_LOD, Value: 1.0
        Label: Blurriness, API Symbol: RDATA_ENABLEBLURRY, Value: 1
        Label: Global Brightness, API Symbol: RDATA_GLOBALBRIGHTNESS, Value: 1.0
        Label: Limit Shadows to Soft, API Symbol: RDATA_LIMITSHADOW, Value: 0
        Label: Motion Scale, API Symbol: RDATA_MOTIONLENGTH, Value: 128.0
        Label: Cache Shadow Maps, API Symbol: RDATA_CACHESHADOWMAPS, Value: 0
        Label: Active Object Only, API Symbol: RDATA_ACTIVEOBJECTONLY, Value: 0
        Label: Default Light, API Symbol: RDATA_AUTOLIGHT, Value: 1
        Label: Textures, API Symbol: RDATA_TEXTURES, Value: 1
        Label: Show Texture Errors, API Symbol: RDATA_TEXTUREERROR, Value: 1
        Label: Volumetric Lighting, API Symbol: RDATA_VOLUMETRICLIGHTING, Value: 1
        Label: Use Display Tag LOD, API Symbol: RDATA_USELOD, Value: 0
        Label: Render HUD, API Symbol: RDATA_SHOWHUD, Value: 0
        Label: Render Doodle, API Symbol: RDATA_RENDERDOODLE, Value: 1
        Label: Sub Polygon Displacement, API Symbol: RDATA_ENABLESPD, Value: 1
        Label: Post Effects, API Symbol: RDATA_POSTEFFECTS_ENABLE, Value: 1
        Label: Identical Noise Distribution, API Symbol: RDATA_NOISE_LOCK, Value: 0
        Label: Subsurface Scattering, API Symbol: RDATA_SSS, Value: 1
        Label: Bucket Sequence, API Symbol: RDATA_BUCKETSEQUENCE, Value: 0
        Label: Automatic Size, API Symbol: RDATA_AUTOMATICBUCKETSIZE, Value: 1
        Label: Bucket Width, API Symbol: RDATA_BUCKETSIZEX, Value: 64
        Label: Bucket Height, API Symbol: RDATA_BUCKETSIZEY, Value: 64
        Label: Stereoscopic, API Symbol: RDATA_GROUP_STEREO, Value: Inaccessible in Python
        Label: Calculate Stereoscopic Images, API Symbol: RDATA_STEREO_CALCRESULT, Value: 1
        Label: Single Channel, API Symbol: RDATA_STEREO_SINGLECHANNEL, Value: 1
        Label: Non-Stereoscopic Image, API Symbol: RDATA_STEREO_CALCULATE_ORIGINAL, Value: 0
        Label: Use Folder for Saving, API Symbol: RDATA_STEREO_SAVE_FOLDER, Value: 0
        Label: Channels, API Symbol: RDATA_STEREO_CHANNELS, Value: 2
        Label: Mode, API Symbol: RDATA_STEREO_MODE, Value: 0
        Label: Additional Parallax (pixel), API Symbol: RDATA_STEREO_PARALLAX, Value: 0
        Label: Swap Left/Right, API Symbol: RDATA_STEREO_SWAP, Value: 0
        Label: Anaglyph, API Symbol: RDATA_GROUP_STEREO_ANA, Value: Inaccessible in Python
        Label: System, API Symbol: RDATA_STEREO_ANAGLYPH_SYSTEM_FULL, Value: 2
        Label: System, API Symbol: RDATA_STEREO_ANAGLYPH_SYSTEM_NON_FULL, Value: 0
        Label: Left, API Symbol: RDATA_STEREO_ANAGLYPH_COL_LEFT, Value: Vector(1, 0, 0)
        Label: Right, API Symbol: RDATA_STEREO_ANAGLYPH_COL_RIGHT, Value: Vector(0, 1, 0)
        Label: Method, API Symbol: RDATA_STEREO_ANAGLYPH_METHOD, Value: 4
        Label: Side-by-Side, API Symbol: RDATA_GROUP_STEREO_SBS, Value: Inaccessible in Python
        Label: Alignment, API Symbol: RDATA_STEREO_SBS_ALIGN, Value: 0
        Label: Left Mirror X, API Symbol: RDATA_STEREO_SBS_LEFT_MX, Value: 0
        Label: Left Mirror Y, API Symbol: RDATA_STEREO_SBS_LEFT_MY, Value: 0
        Label: Right Mirror X, API Symbol: RDATA_STEREO_SBS_RIGHT_MX, Value: 0
        Label: Right Mirror Y, API Symbol: RDATA_STEREO_SBS_RIGHT_MY, Value: 0
        Label: Interlaced, API Symbol: RDATA_GROUP_STEREO_INTER, Value: Inaccessible in Python
        Label: Type, API Symbol: RDATA_STEREO_INTERLACED_TYPE, Value: 0
        Label: Team Render, API Symbol: RDATA_GROUP_NET, Value: Inaccessible in Python
        Label: Single Image, API Symbol: RDATA_GROUP_NET_SINGLEIMAGE, Value: Inaccessible in Python
        Label: Distribute Subsurface Caches, API Symbol: RDATA_NET_CACHES_SSS, Value: 1
        Label: Distribute Ambient Occlusion Caches, API Symbol: RDATA_NET_CACHES_AO, Value: 1
        Label: Distribute Irradiance Caches, API Symbol: RDATA_NET_CACHES_GI, Value: 1
        Label: Distribute Light Mapping Caches, API Symbol: RDATA_NET_CACHES_LM, Value: 1
        Label: Distribute Radiosity Map Caches, API Symbol: RDATA_NET_CACHES_RM, Value: 0
        Label: Magic Bullet Looks, API Symbol: None, Value: <c4d.documents.BaseVideoPost object called Magic Bullet Looks/Magic Bullet Looks with ID 1054755 at 140202407811328>
        Label: Magic Bullet Looks, API Symbol: None, Value: <c4d.documents.BaseVideoPost object called Magic Bullet Looks/Magic Bullet Looks with ID 1054755 at 140202407811584>
        Label: Redshift, API Symbol: None, Value: <c4d.documents.BaseVideoPost object called Redshift/Redshift with ID 1036219 at 140202407811072>
        Label: Redshift, API Symbol: None, Value: <c4d.documents.BaseVideoPost object called Redshift/Redshift with ID 1036219 at 140202407811328>
        Label: Post Effects Pass, API Symbol: None, Value: <c4d.BaseList2D object called Post Effects/Post Effects with ID 300001048 at 140202407811584>
        Label: Post Effects, API Symbol: None, Value: <c4d.BaseList2D object called Post Effects/Post Effects with ID 300001048 at 140202407811072>
