    Accessing Parameters of Filters in a Volume Builder
    windowspython2023
    3 Posts 2 Posters 667 Views 2 Watching
    • D Offline
      datamilch
      Hi there,
      I'd like to access some parameters of the filters in a Volume Builder, like 'dilate and erode > offset' or the fields parameter of the smooth filter. But I don't know how.
      There is nothing really in the documentation or the forum.
      The only thing related filters, that I found, was 'volume.SendVolumeCommand()' but suppose, this is not meant to be used with the volume builder.
      VolumeBuilder.GetSettingsContainerForIndex() will return None for filter layers - but that's also what the documentation says. I attached a file to demonstrate this.
          settings = op.GetObject()
          volume_builder = settings[c4d.ID_USERDATA,1]
          for i in range( volume_builder.GetInputObjectCount() ):
              bc = volume_builder.GetSettingsContainerForIndex(i)
              print (bc)
      # returns:
      None   # the filter layer
      <c4d.BaseContainer object at 0x0000024296092D40> # the cube object
      When I drag the parameter, that I want to change, in the console it is called 'SDFDilateandErode[c4d.ID_VOLUMEFILTER_RESHAPE_OFFSET]' but again, I have no idea how to access it.
      Help would be much appreciated.
      volume builder filters 01.c4d
      D 1 Reply Last reply Reply Quote 0
      • D Offline
        datamilch @datamilch
        Oh shit! I just realized the filters exist as objects in c4d ... * facepalm *
        I suppose this will resolve my problems for now.
        Should I delete the topic?
          ferdinand @datamilch
          Hey @datamilch,
          Thank you for reaching out to us and answering your own question. In general we prefer it when topics do not get deleted, so that other users can benefit from a topic. You should also not be able to delete this topic anymore since more than three hours have passed since you posted and because your topic has replies.
