    Title in dropdown menu
    2 Posts 2 Posters 1.0k Views
    • M Offline
      manudin
      I found in this topic a code which creates a menu and sub menu but I did not found how to create titles inside menus. something like this:
      from c4d import gui
      def EnhanceMainMenu():
          mainMenu = gui.GetMenuResource("M_EDITOR")
          pluginsMenu = gui.SearchPluginMenuResource()
          menu = c4d.BaseContainer()
          menu.InsData(c4d.MENURESOURCE_SUBTITLE, "My Menu 1")
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_{}".format(c4d.Ocube))
          menu.InsData(c4d.MENURESOURCE_SEPERATOR, True);
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_{}".format(c4d.Osphere))
          menu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_{}".format(c4d.Oplane))
          submenu = c4d.BaseContainer()
          submenu.InsData(c4d.MENURESOURCE_SUBTITLE, "Menu 2 ")
          submenu.InsData(c4d.MENURESOURCE_COMMAND, "PLUGIN_CMD_{}".format(c4d.Onull))
          menu.InsData(c4d.MENURESOURCE_SUBMENU, submenu)
          if pluginsMenu: mainMenu.InsDataAfter(c4d.MENURESOURCE_STRING, menu, pluginsMenu)
          else: mainMenu.InsData(c4d.MENURESOURCE_STRING, menu)
      def PluginMessage(id, data):
          if id==c4d.C4DPL_BUILDMENU:
              EnhanceMainMenu()
      • i_mazlovI Offline
        i_mazlov @manudin
        Hello @manudin!
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        These static text separators are just normal separators with provided title. You can do this by assigning BaseContainer instead of boolean (please check the code snippet below).
        Ilia
        from c4d import gui
            menu.InsData(c4d.MENURESOURCE_SEPARATOR, True);
            m = c4d.BaseContainer()
            m.InsData(c4d.MENURESOURCE_SUBTITLE, "My Category")
            menu.InsData(c4d.MENURESOURCE_SEPARATOR, m)
            if c4d.threading.GeIsMainThreadAndNoDrawThread():
                c4d.gui.UpdateMenus()
            EnhanceMainMenu()
