    Unable to set override in take
    4 Posts 2 Posters 1.1k Views 1 Watching
    • R Offline
      robpayne
      Hi, I am having difficulty generating take overrides with ‘FindOrAddOverrideParam()’. When I run my script it creates a set of takes with an override but no value.
      My script does ‘work’ if I use ‘OverrideNode()’ instead, but this overrides all of the parameters for the given object, which is much more than I want or need.
      My code runs from a Python tag and is activated by a user data button. The intention is to increment the user data by one for each child object.
      Any assistance would be greatly appreciated.
      def createTake():
          # Get existing take structure
          take_data = doc.GetTakeData()
          main_take = take_data.GetMainTake()
          # Get Selector child objects
          obj = op.GetObject()
          # Create header take
          select_take = take_data.AddTake("Selector", main_take, None)
          select_take.SetName(obj.GetName())
          child = obj.GetDown()
          #records original user value, used with OverrideNode()
          originalSelection = obj[c4d.ID_USERDATA,2]
          n = 1
          while child:
              print (f"n{n}  obj {child.GetName()}")
              childTake = take_data.AddTake("Selection", select_take, None)
              childTake.SetName(child.GetName())
              obj[c4d.ID_USERDATA,2] = n #increment userdata, used with OverrideNode()
              descId = c4d.DescID(c4d.DescLevel(c4d.ID_USERDATA), c4d.DescLevel(2))
              #childTake.OverrideNode(take_data, obj, False)
              overrideNode = childTake.FindOrAddOverrideParam(take_data, obj, descId, n)
              n = n + 1
              child = child.GetNext()
          obj[c4d.ID_USERDATA,2] = originalSelection #restores original user value, used with OverrideNode()
      def message(msg_type, data):
          if msg_type == c4d.MSG_NOTIFY_EVENT:
              event_data = data['event_data']
              if event_data['msg_id'] == c4d.MSG_DESCRIPTION_COMMAND:
                  desc_id = event_data['msg_data']['id']
                  if desc_id[1].id == 5: # The ID of the User Data
                      print ("Button Pressed")
                      createTake()
          # Check if we already listen for message
          if not obj.FindEventNotification(doc, op, c4d.NOTIFY_EVENT_MESSAGE):
              obj.AddEventNotification(op, c4d.NOTIFY_EVENT_MESSAGE, 0, c4d.BaseContainer())
        ferdinand @robpayne
        Hello @robpayne,
        Getting Started
        It is strongly recommended to read the first two topics carefully, especially the section Support Procedures: Asking Questions.
        About your First Question
        Your question is lacking a bit in repeatability (see Support Procedures: Asking Questions) because you do not provide a scene.
        The first thing I would do, is remove the fanciness here. I assume this is meant to be a Python Programming tag solution. You do sort of the right thing by using a button and message() instead of the main() function which would run off-main thread. You are however still lacking a main thread check before you call your createTake. To learn more about threading restrictions in our Threading Manual. Also the fact that you hook with an event notification into the host of your tag so that can you can add and press the button there, does not make this more streamlined. It is fine to be fancy when everything runs, but I would avoid it when running into problems.
        I removed all the fluff from you code and ran it as a Script Manager script. The problem is then that I can only speculate about how your scene is meant to look like and what kind of parameter type c4d.USERDATA, 2 is meant to be, I guess a BaseLink? I can also only guess what your child loop is meant to do functionally, because there [USERDATA, 2] now seems to be an integer. The line obj[c4d.ID_USERDATA,2] = n is also not necessary but your comment somewhat implies that you are aware, but you should remove it. When I run your code within what I can guess, its output looks fine to me. I
        With all that being said, the Take system can be hairy subject, so problems are not unusual, especially in the context of FindOrAddOverrideParam. You can find here multiple FindOrAddOverrideParam topics I answered in the past. A common trap is that users do not enable overrides in the UI as discussed here.
        Worth a look ar also our Python Take System examples.
        When you require more help, please provide executable code/a scene and a clear explanation of what you consider to fail.
        R 1 Reply Last reply Reply Quote 0
        • R Offline
          robpayne @ferdinand
          Hi @ferdinand , thank you for kindly informing me, and for your guidance.
          I was able to achieve a working solution by simplifying. This Script Manager script:
          1. creates a cube
          2. creates a take
          3. creates an override with new width for the cube
              # Instantiate a cube – for test only
              obj = c4d.BaseObject(c4d.Ocube)
              doc.InsertObject(obj)
              # Get take structure
              takeData = doc.GetTakeData()
              mainTake = takeData.GetMainTake()
              #Insert new take
              newTake = takeData.AddTake("Test", mainTake, None)
              #Capture descID of paramater to override
              descID = c4d.DescID(c4d.DescLevel(c4d.PRIM_CUBE_LEN, c4d.DTYPE_VECTOR, 0), c4d.DescLevel(c4d.VECTOR_X,c4d.DTYPE_REAL,0))
              #Set take override
              newTake.FindOrAddOverrideParam(takeData, obj, descID, 10)
          The problem I had before was my descID was improperly collected. I needed to specify datatypes, as is the case here.
          Many thanks,
          Rob
            ferdinand @robpayne
            Hey @robpayne that is great to hear, thank you for informing us!
