    Issue - Loading Spline Object with Python Tag from Asset Browser via Python Script
    Scheduled Pinned Locked Moved Bugs
    20242023python
    5 Posts 3 Posters 1.8k Views 1 Watching
    • B Offline
      blkmsk
      Hello^^
      I am experiencing a weird, but very specific behaviour in c4d 2024:
      When I try to load a Spline Object with a Python Tag attached to it from the Asset Browser via a python script, Cinema 4D 2024 gets stuck. But this happens only with Spline Object and only in 2024. I tried it with a Null Object as well with a Polygon Object and those are loading fine.
      In Cinema 4D 2023 there is no issue. all three Objects (Spline, Null and Polygon) get loaded with the script and manually loading the Asset by double clicking it in the Asset Browser is also no problem in both versions. Could this be simply a bug?
      Here is a small video to show you the behaviour in both R 2023 and R 2024.
      The script I used is a striped down version from one of the example scripts on github.
      Thank you in advance for your time!
      • i_mazlovI Offline
        i_mazlov @blkmsk
        Hi @blkmsk ,
        Thank you for sharing your experience and reporting the issue. I've created a ticket in our internal bug tracking system.
        Ilia
        • B Offline
          blkmsk
          Hi I just wanted to follow up and ask if this will be fixed any time soon?
          Its not super urgent but this bug is putting a project of mine on hold where I want to pull a rig (with several python tags on spline control objects) from the asset browser with a script. For the moment its not a problem to do it manually though but I would love to automate this.
          Cheers Ben
          • M m_adam moved this topic from Cinema 4D SDK on
          • M Offline
            m_adam
            Hi I just looked at the issue and fixed it. Sadly there is no workaround for you.
            Regarding when the fix will be available, it wont be in the next one but will be in the next next one, regarding when it will be available to you I can't say precisely but should be in the next months.
            • B Offline
              blkmsk
              Awesome, Thank you so much @m_adam !
              Cheers and best regards
              Ben
