    After undo, point object SetAllPoints not update
    2024python
    3 Posts 2 Posters 864 Views 1 Watching
    • chuanzhenC Offline
      chuanzhen
      I encountered a problem. When I set the position of an object's point, however, when I undo it and set it again, the object does not refresh in time. Only if I click on the object again and set it again will it be refreshed in time.
      This is the video,
      This is simple code:
      import os
      import sys
      from c4d import gui,bitmaps,plugins,utils,modules
      PLUGIN_ID = 10000001
      class S_test_Dialog(gui.GeDialog):
          def CreateLayout(self):
              self.SetTitle("test")
              self.GroupBegin(1000,c4d.BFH_SCALEFIT,4,0)
              self.AddStaticText(1003, c4d.BFH_RIGHT, 80, 20, "  Target ")
              bc = c4d.GetCustomDataTypeDefault(c4d.DTYPE_BASELISTLINK)
              self.AddCustomGui(1004, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT, 300, 0, bc)
              self.GroupEnd()
              self.AddButton(1010, c4d.BFH_SCALEFIT, 150, 30, "ChangePoints")
          def Command(self, id, msg):
              if id == 1010:
                  target = self.FindCustomGui(1004, c4d.CUSTOMGUI_LINKBOX).GetData()
                  all_p = target.GetAllPoints()
                  for id,pos in enumerate(all_p):
                      all_p[id] = c4d.Vector(0)
                  doc.StartUndo()
                  doc.AddUndo(c4d.UNDOTYPE_CHANGE,target)
                  target.SetAllPoints(all_p)
                  target.Message(c4d.MSG_UPDATE)
                  doc.EndUndo()
      class S_test(plugins.CommandData):
          dialog = None
          def Execute(self,doc):
              # create the dialog
              if self.dialog is None:
                  self.dialog = S_test_Dialog()
              return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=400, defaulth=100)
          def RestoreLayout(self, sec_ref):
              # manage nonmodal dialog
              return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
      # Execute main()
      if __name__=='__main__':
          path, fn = os.path.split(__file__)
          plugins.RegisterCommandPlugin(id=PLUGIN_ID,
                                        str="S_test",
                                        info=0,
                                        help="",
                                        dat=S_test(),
                                        icon=None)
      Thanks for any help!
      相信我,可以的!
      ferdinandF 1 Reply Last reply Reply Quote 1
        ferdinand @chuanzhen
        Hello @chuanzhen,
        Thank you for reaching out to us. The problems you encounter stem from the fact that you use the wrong method to retrieve your link.
        When you undo an action, the object will not be the same anymore since the object has been replaced with whatever was found in the undo-stack. You simply must use the correct method c4d.gui.LinkBoxGui.GetLink and things will also work after an undo.
        Code:
            self.GroupBegin(1000, c4d.BFH_SCALEFIT, 4, 0)
            # We store the custom GUI so that we do not have to grab it every time.
            self._link = self.AddCustomGui(
                c4d.GetCustomDataTypeDefault(c4d.DTYPE_BASELISTLINK))
            self.GroupEnd()
            if id == 1010:
                # This line was problematic because you did use BaseCustomGui.GetData and not
                # LinkBoxGui.GetLink which has special logic for this type. This can fail.
                # target = self.FindCustomGui(1004, c4d.CUSTOMGUI_LINKBOX).GetData()
                # This cannot, it will automatically reattach a dangling link (after an undo for
                # example). We could also do that ourself with UUIDs but why when we do not have to :)
                target: c4d.BaseObject | None = self._link.GetLink(doc, c4d.Opolygon)
                if not target:
                points: list[c4d.Vector] = [c4d.Vector() for _ in range(target.GetPointCount())]
                doc.StartUndo()
                doc.AddUndo(c4d.UNDOTYPE_CHANGE, target)
                target.SetAllPoints(points)
                doc.EndUndo()
        chuanzhenC 1 Reply Last reply Reply Quote 1
          chuanzhen @ferdinand
          @ferdinand Thanks for your help!
          相信我,可以的!
