    How to draw a primitive object in BaseDraw
    python20232024s26
    3 Posts 2 Posters 924 Views 2 Watching
    • gheyretG Offline
      gheyret
      Hi everyone!
      I try to draw a primitive object like Plane, Cube, e.t.c with Tooldata.Draw().
      And in BaseDraw, i saw it have tow method to draw object:
      • BaseDraw.DrawPolygonObject()
      • BaseDraw.DrawObject()
      I've tried both methods in my code, but it's not working
      def Draw(self, doc, data, bd, bh, bt, flags):
          bd.SetMatrix_Screen()
          obj = c4d.BaseObject(c4d.Ocube)
          bd.DrawPolygonObject(bh, obj, flags=c4d.DRAWOBJECT_NONE, parent=None, col=Vector(0.5))
          bd.DrawObject(bh, obj, flags=c4d.DRAWOBJECT_NONE, drawpass=c4d.DRAWPASS_OBJECT, parent=None, col=Vector(0.5))
          return c4d.TOOLDRAW_NONE
      The explanation of both methods in the documentation is simple and straightforward.
      And i'm not sure if I can't use these two methods in ToolData, or am I misunderstanding something?
      www.boghma.com
        ferdinand @gheyret
        Hey @gheyret,
        Thank you for reaching out to us. Your obj there has no cache. You just instantiated it, there is nothing to draw. We talked about cache building multiple times on the forum, for example here. In the geometry model section of our Python examples, I also went over caches and cache building in geometry_caches_s26.py.
        You should however be careful with the amount of work you do in Draw. Although the method is despite its name not actually a drawing method and would be more aptly named as GetDrawingInstructions, you should still go for performance there. Building complex geometry there is not a good idea. Either build your inputs beforehand, or better, draw primitives like a cube yourself (constructed out of shaded polygons or lines).
        gheyretG 1 Reply Last reply Reply Quote 0
        • gheyretG Offline
          gheyret @ferdinand
          Hi @ferdinand
          Thank you for your reply and guidance. I'll get around to it.
          Cheers šŸ»
          Gheyret
          www.boghma.com
