    How to set options when saving TIF file
    2023c++
    2 Posts 2 Posters 835 Views 1 Watching
    • kbarK Offline
      kbar
      Is it possible to set the Byte Order and Compression values when saving a TIF?
      BaseContainer bc; //What do we set here?
      bmp->Save(tiffFile, FILTER_TIF, &bc, SAVEBIT::USE16BITCHANNELS);
      https://www.gamelogicdesign.com
      https://www.plugins4d.com
        ferdinand @kbar
        Hello @kbar,
        Thank you for reaching out to us. You cannot do what you want to do from the classic API. When we use the classic API interface BaseBitmap::Save internally, we always pass nullptr or the empty container when saving a FILTER_TIF. There is unfortunately no classic API translation layer anymore for this aspect of TIFF saving.
        But you can get the underlying ImageRef with BaseBitmap::GetImageRef and then use the Image API directly to save things as you want them to be saved:
        • Saving an ImageRef to Disk
        • maxon::MEDIASESSION::TIFF::EXPORT Namespace
        Note that other than in the classic API, image data is expressed by more than one type in the maxon API. To save a plain ImageRef, you will have first to insert it into a ImageTextureRef via ::AddChildren, as only it has the ::Save method.
