    Problem with MessageData plugin
    2023windowspython
    5 Posts 2 Posters 1.7k Views 2 Watching
    • gheyretG Offline
      gheyret
      Hi guys~
      My goal is detecting and get any keybord key pressed and released.
      So my idea is useing MessageData.CoreMessage() and gui.GetInputEvent() to get which key was pressed and released.
      But the problem is when i press some key , some time it can print the result, but mostly it can't .
      I don't know if i do some mistakes, there is the code:
      from c4d import plugins
      pid = 20231019
      pname = "msg_test"
      class MSG(plugins.MessageData):
          def GetTimer(self):
              return 100  # ms
          def CoreMessage(self, id, bc):
              if id == c4d.MSG_TIMER:
                  if c4d.gui.GetInputEvent(c4d.BFM_INPUT_KEYBOARD, bc):
                       key = bc[c4d.BFM_INPUT_CHANNEL]
                       print(key)
                       print (c4d.gui.Shortcut2String(bc[c4d.BFM_INPUT_QUALIFIER], bc[c4d.BFM_INPUT_CHANNEL]))
          reg = plugins.RegisterMessagePlugin(id=pid, str=pname, info=0, dat=MSG())
      www.boghma.com
        ferdinand @gheyret
        Hey @gheyret,
        Thank you for reaching out to us. What you do there does not match the description of what you want to do.
        What you do in your code is checking the current input state of the keyboard every 100 milliseconds. When the user happens to press the key in between your polling, i.e., the user already released the key when your function runs, you will detect nothing. This is even further complicated by the fact that timer events are not the most precise thing in the world and for requesting a stride of 100 ms, you will end up with an event queue which looks for example like this 92ms, 117ms, 81ms, 123ms, ....
        Core messages are the wrong choice for this, the natural message stream for this would be GUI messages; specifically the BFM_INPUT family. But for that you need a dialog or similar entity, and it must be in focus. In C++ there is SceneHookData and its method KeyBoardInput which allows you to hook into the global keyboard input stream. But SceneHookData has never been exposed to Python.
        Maybe you can explain what you want to achieve on a functionality level, e.g., "create a new material everytime the user presses the 'm' key", so that we can see if there is some "out-of-the-box-thinking"-solution for your problem.
        gheyretG 1 Reply Last reply Reply Quote 0
        • gheyretG Offline
          gheyret @ferdinand
          oops , my bad, i forgot to delet the Timer in this test code. However, even if I delete the Timer, the above problem still exists.
          In fact, this is a pre-development feasibility test. My idea goes something like this: I have a pre-written toolset, and then users can bind these tool commands to the shortcut they want, and when the shortcut is pressed, the corresponding command will be executed.
          And you sad the CoreMessage is wrong choice and SceneHookData is not available in python.
          I want to know why the CoreMessage is wrong choice and is there have other way to get global keyboard input?
          www.boghma.com
            ferdinand @gheyret
            Hey @gheyret ,
            @gheyret said in Problem with MessageData plugin:
            Because core messages are not the message stream for mouse and keyboard inputs. Core events covey things like the scene having been updated, or viewports or other parts of Cinema 4D being redrawn. Timer events are also conveyed as core messages. Your code cannot work and it is always hard to answer questions when users show us other code than the one they are using, but:
            1. You do what your code from above shows, hook into MSG_TIMER and register for 100 ms: I have explained above why this is error prone.
            2. You do not hook into MSG_TIMER and instead evaluate the keyboard state every time CoreMessage is called (so on each core message event). This is even worse, because there is no guarantee that a core message is broadcasted at the same time when the user is typing. In fact, there is a good chance that you get core event starved when the user is typing, and you have no timer running which is forcing core messages.
            As I said, the natural message stream for this is GUI messages, as Cinema 4D will call you there on its own when the user is making inputs (with BFM_INPUT as lined out above). But you need some form of UI implementation for that, and it only works when the user is focusing on that UI of yours. The thing which does what you want is a SceneHook as they are meant to be the spider in the web kind of thing you are here after.
            I would recommend having a look at the Message Manual, it should clarify things.
            You can get the global keyboard state, just as you do it. But what you cannot do is hook into the global input stream (get state: you pull state, stream: Cinema 4D pushes states to you). SceneHookData is sort of an exception, but as you can see in the C++ docs I linked to in my former post, you must be careful there too.
            • gheyretG Offline
              gheyret @ferdinand
              Hi @ferdinand
              Thank you so much for your explain, i understand what's happen now.
              www.boghma.com
