    node size
    pythonwindows2023
    4 Posts 3 Posters 1.3k Views
    • L Offline
      ll2pakll
      Windows 10
      Cinema 4d 2023.2.1
      Python
      Good evening.
      How can I change or optimize the size of the node? It is possible to do it manually, but to do it programmatically I have not found a way neither in the documentation, nor in the history of the forum. Let me clarify that I mean the class c4d.modules.graphview.GvNode.
      • i_mazlovI Offline
        i_mazlov
        Hi @ll2pakll ,
        The size of the GvNode is stored in a corresponding BaseContainer and is not publicly exposed. There was some related issue here: BaseContainer missing for GvNode created with c4dpy.
        Seems that the answer here is the same as in the related thread: no workaround.
        Ilia
        • T Offline
          Thodos
          Most of the time this error persists because NodeSpace is not initialized. If you open and close Xpresso editor for xpresso tag then you can access node size in base container.
          • L Offline
            ll2pakll
            Thank you for the answers.
