    How to get a Vertex Map to trigger animated object?
    2024
    2 Posts 2 Posters 790 Views
    • S Offline
      spektor04
      Hi, I have 3 splines in a sweep that I have animated across thirty 30 frames using an FFD deformer and PLA.
      I have these splines in a matrix using a redshift tag.
      I want these to be triggered with a vertex map that I have growing on a plane. The splines work as expected and get triggered but the animation on them get triggered all at the same time. Is there a way to get them to trigger once the vertex maps reveal them? I e tried baking as alembic and using connect objects but with no joy. Any tips or advice would be great, thanks
      J 1 Reply Last reply Reply Quote 0
      • J Offline
        jana @spektor04
        Hello @spektor04 ,
        Welcome to the Plugin Café forum and the Cinema 4D development community, it is great to have you with us!
        Getting Started
        Before creating your next postings, we would recommend making yourself accustomed with our Forum and Support Guidelines, as they line out details about the Maxon SDK Group support procedures. Of special importance are:
        • Support Procedures: Scope of Support: Lines out the things we will do and what we will not do.
        • Support Procedures: Confidential Data: Most questions should be accompanied by code but code cannot always be shared publicly. This section explains how to share code confidentially with Maxon.
        • Forum Structure and Features: Lines out how the forum works.
        • Structure of a Question: Lines out how to ask a good technical question. It is not mandatory to follow this exactly, but you should follow the idea of keeping things short and mentioning your primary question in a clear manner.
        About your First Question
        Please provide us testscript(s) and a testfile which would help us to reproduce the issue.
        Thanks and Cheers
        Jana
