    Howto add headers & dividers for a ShowPopupDialog?
    windowss26python
    13 Posts 4 Posters 3.9k Views 1 Watching
    • G Offline
      Gaal Dornik
      Hello, i'd like to add headers & dividers to my popup dialog similar to modeling (Mesh menu) popup. Is that possible?
      Thanks.
      • . Offline
        .del
        Hi - How are you generating the popup dialog right now? Are you using gui.GeDialog to create your own dialog box or are you using c4d.gui.MessageDialog to generate a simple prompt?
        I found that I can create the kind of stuff your talking about with gui.GeDialog but it also makes me feel like I'm in over my head 🙂 - (self taught hack that is distracted easily)
        • G Offline
          Gaal Dornik
          Hi, i'm using gui.ShowPopupDialog.
          popup = c4d.BaseContainer()
          popup.SetString(ID_LIVE_SELECTION, "Live Selection")
          result = gui.ShowPopupDialog(cd=None, bc=popup, x=c4d.MOUSEPOS, y=c4d.MOUSEPOS)
          • G Offline
            Gaal Dornik
            I also would like to know can i add icons to popup menus?
            gheyretG 1 Reply Last reply Reply Quote 0
            • gheyretG Offline
              gheyret @Gaal Dornik
              Hi, @Gaal-Dornik
              Of course you can add header, divider and icon in to Popup dialog.
              this is a simple example for how to add title, separator and icon:
                  bc = c4d.BaseContainer()
                  bc.InsData(c4d.FIRST_POPUP_ID, "item01")
                  bc.InsData(c4d.FIRST_POPUP_ID+1, "item02")
                  # add a title
                  bc.InsData(0, "This is Title")
                  bc.InsData(c4d.FIRST_POPUP_ID+2, "item03")
                  bc.InsData(c4d.FIRST_POPUP_ID+3, "item04")
                  # add separator
                  bc.InsData(0, "")
                  bc.InsData(c4d.FIRST_POPUP_ID+4, "item05")
                  # add icon for an item
                  bc.InsData(c4d.FIRST_POPUP_ID+5, f"item06 &i{5140}&")
                  bc.InsData(c4d.FIRST_POPUP_ID+6, "item07")
                  res = c4d.gui.ShowPopupDialog(cd=None, bc=bc, x=500, y=500)
              And the result is like this:
              You can also visit API Documentation page for more information.
              www.boghma.com
              • G Offline
                Gaal Dornik
                That's great! Thanks a lot!)
                  Hello @Gaal-Dornik,
                  Thank you for reaching out to us. And thank you @gheyret for providing an answer and solution, I do not really have to add anything here.
                  • G Offline
                    Gaal Dornik
                    BTW Is there a way to remove 'Type to search' at the top of a popup?
                      ferdinand @Gaal Dornik
                      Hello @Gaal-Dornik,
                      I am not quite sure how you mean that. The code example @Gaal-Dornik has provided does not come with the search box (and neither do our code examples). The option has never been documented for Python (I just fixed that) but you must pass POPUP_ALLOW_FILTERING as flag when opening the menu to enable the filtering. To disable filtering, you simply must omit the flag (which is the default).
                      Result:
                      Code:
                      # add a title
                      # add separator
                      bc.InsData(0, "")
                      # Redefine the default flags and add the flag which enables the serach box.
                      flags: int = c4d.POPUP_RIGHT | c4d.POPUP_EXECUTECOMMANDS | c4d.POPUP_ALLOW_FILTERING
                      res = c4d.gui.ShowPopupDialog(cd=None, bc=bc, x=500, y=500, flags=flags)
                      • G Offline
                        Gaal Dornik
                        That's indeed strange because i haven't included this flag for sure, but i can see this field at the top...
                          Hey @Gaal-Dornik,
                          I just tried it on S26.1 and I have the filtering there too no matter what I do:
                          Must have been a bug of S26. I do not see much what you can do here.
                          • G Offline
                            Gaal Dornik
                            Actually i've got 'Type to search' popup field in C4D 2023.2.0 also, but POPUP_ALLOW_FILTERING flag is omitted.
                            Is there a way to hide it?
                            • G Offline
                              Gaal Dornik
                              It works as expected in C4D 2024, but not in the previous versions.
