    GeDialog Timer Always Printing to Console?
    s262023python
    2 Posts 1 Posters 587 Views
    • K Offline
      kvb
      Hey Folks,
      Getting some odd behavior from a GeDialog's Timer and I've been troubleshooting this all day with no success. I thought it was due to a lot of different things, including some python libraries I had been using, but when I boiled it down to the most basic example and tried testing in a c4d without those libraries installed, I still get this very odd behavior of "(null)" being printed to the console over and over again if my Timer is active.
      If I uncomment the print("Timer") line it just prints "(null)Timer". The "(null)" calls always show up on the same line, unless I print from Timer(), then the print statement adds a new line break.
      Issues are the same in 2023 and S26, whether I have the 3rd party python libraries installed or not. The following example is pure vanilla. No libs, just a boilerplate dialog that runs a timer and has 4 static text fields.
      Thanks for your help!
      from c4d import gui
      PLUGIN_ID = 1234567  # Replace with your unique plugin ID from PluginCafe
      class MyDialog(gui.GeDialog):
          ID_GROUP1 = 1000
          ID_GROUP2 = 2000
          ID_STATIC_TEXT1 = 1001
          ID_STATIC_TEXT2 = 1002
          ID_STATIC_TEXT3 = 2001
          ID_STATIC_TEXT4 = 2002
          def CreateLayout(self):
              self.SetTitle("My Custom GeDialog")
              # Group 1
              if self.GroupBegin(self.ID_GROUP1, c4d.BFH_SCALEFIT, 2, 1, "Group 1"):
                  self.AddStaticText(self.ID_STATIC_TEXT1, c4d.BFH_LEFT, name="Static Text 1")
                  self.AddStaticText(self.ID_STATIC_TEXT2, c4d.BFH_LEFT, name="Static Text 2")
              self.GroupEnd()
              # Group 2
              if self.GroupBegin(self.ID_GROUP2, c4d.BFH_SCALEFIT, 2, 1, "Group 2"):
                  self.AddStaticText(self.ID_STATIC_TEXT3, c4d.BFH_LEFT, name="Static Text 3")
                  self.AddStaticText(self.ID_STATIC_TEXT4, c4d.BFH_LEFT, name="Static Text 4")
              self.GroupEnd()
          def Timer(self, msg):
              print("Timer")
          def InitValues(self):
              self.SetTimer(100)
              print("InitValues")
      class MyCommandData(c4d.plugins.CommandData):
          dialog = None
          def Execute(self, doc):
              if self.dialog is None:
                  self.dialog = MyDialog()
              return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=PLUGIN_ID, defaultw=300, defaulth=150)
          def RestoreLayout(self, sec_ref):
              return self.dialog.Restore(pluginid=PLUGIN_ID, secret=sec_ref)
          c4d.plugins.RegisterCommandPlugin(PLUGIN_ID, "My Custom GeDialog", 0, None, "A custom GeDialog example", MyCommandData())
      • K Offline
        kvb
        Well, that was a fast solution... couldn't it have emerged BEFORE I hit submit?!? Haha, the solution was easy... I was returning True on the Timer function. Took a look at the python memory viewer example and noticed they don't return a value on it. Removed the return from my Timer() function and all is working as expected.
            print("Timer")
        That's it:)
