    2. Tags
    3. s22
    Log in to post
    • All categories
    • kbarK
      Drag and Drop Gradient Data onto a Gradient
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK c++ r20 r21 r23 s22 s24 sdk
      Hello @kbar, without any further questions, we will consider this topic as solved by Monday, the 25th and flag it accordingly. Thank you for your understanding, Ferdinand
    • kbarK
      Filename::SetMemoryReadMode Docs don't seem right.
      Watching Ignoring Scheduled Pinned Locked Moved Bugs c++ r20 r21 r23 s22 s24 sdk
      Hello @kbar, I should have replied here since there is at least an implied request in your last answer. I have added a task for this in our documentation task pool and added the tracking tag to this topic. Without any further questions or replies, we will consider this thread as solved by Monday the 20th and flag it accordingly. But that does not mean that the topic is forgotten, due to its to fix tag. Thank you for your understanding, Ferdinand
    • kbarK
      Accessing json data from DataDictionary
      kbarK
      That is what I was looking for. Thanks Manuel!
    • a_blockA
      Close button of docked dialog emits Command(id=92)
      B
      i removed the ids from the sdk. it looks like they are only used internally. there is no use in the sdk for developers.
    • fwilleke80F
      Colors on a generator
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK r20 r21 r23 s22 s24 c++
      14
      Hello @fwilleke80, without further questions or postings, we will consider this topic as solved by Wednesday and flag it accordingly. Thank you for your understanding, Ferdinand
    • kbarK
      Double clicking behaviour in a Field List.
      1 Votes
      kbarK
      This is for my own plugin. I was looking for a flag that I could set. Totally forgot about just checking for the parameter being set. Great solution. Thanks.
    • D
      Wrong editor preview of material plugins with TextureTag repetitions
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK s22 c++
      D
      Thanks for the investigation. At least now we are aware the problem is not on our side. Cheers, Deyan
    • fwilleke80F
      Open a GeModalDialog from a Job Observer
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK r20 r21 s22 r23 c++ maxon api
      fwilleke80F
      It works perfectly, thanks again! Cheers, Frank
    • fwilleke80F
      EffectorData: Set clone visibility?
      fwilleke80F
      Works like a charm, thank you! Greetings, Frank
    • fwilleke80F
      How to download a file in R20+
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK maxon api r21 s22 r23
      ManuelM
      hi, by the way, i forgot to talk about the thread thing. This thread might help And of course our manuals about threading Cheers Manuel
    • kbarK
      HandleMouseDrag for ID_GRADIENTGUI_BROWSERPRESET and ColorSwatchData::browserPresetType
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK c++ r21 s22 r23 r20 sdk
      18
      ManuelM
      Hi, Sorry about not having time to investigate the gradient part of your question. I was waiting for feedback about the color presets. With the new asset browser out there's no point into investigate this question furthermore. Cheers, Manuel
    • P
      How to remove generator childs when converting via "c"
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK python r20 r21 s22 r23
      P
      forget about it. i removed the c4d.OBJECT_INPUT flag during development and forgot to add it back.
    • fwilleke80F
      Dynamic elements in a CYCLE, CYCLE empty after loading document?
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK c++ r20 r21 s22 r23
      fwilleke80F
      Thanks, Maxime! Looks like I have it running flawlessly now. good work on Terraform looks solid! Thank you! It is pretty solid, yes Cheers & happy Easter, Frank
    • A
      Custom FieldList is not reevaluated on field change
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK c++ s22 windows
      ManuelM
      hi, this shouldn't make any difference, what do you mean by "my own FIELDLIST gui element" . Can i see how do you add it and initialise it ? Cheers, Manuel
    • F
      Python: "Frame Selected" Within a Thread
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK python s22
      Hi @flewis, sorry, there has been some mix-up with access rights, you should be now able to access the page. About your fix: It does not really matter if you do it manually or not. While you can decouple the modification of the node attributes - which is allowed from within a thread - from the redraw event, to carry out that newly computed camera transform, you still will have to invoke a redraw, which you cannot do from within your threaded environment. When you invoke such redraw event, the first thing the internal code does, is to check if its running on the main thread and if not, it just gets out. So there is not much won by doing it manually, at least for what from my understanding is the premise of your problem: To constantly frame the viewport to the object that is currently processed by your async code. Cheers, Ferdinand
    • chuanzhenC
      How to find an object quickly?
      10
      chuanzhenC
      @r_gigante Thanks for your help!
    • fwilleke80F
      Default Object: How to apply those defaults?
      11
      ManuelM
      well sorry for the misleading. I was thinking it should work because the object is inserted with doc->InsertObject Cheers, Manuel
    • kbarK
      Setting volume as dirty doesn't refresh in S22 or R23.
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK s22 r23 c++
      Hi @kbar I'm able to reproduce the issue and I've opened a new bug report about it. The only workaround is to return a new VolumeObject each time. Cheers, Maxime.
    • mikeudinM
      CallCommand Select Connected is not working on R22
      Watching Ignoring Scheduled Pinned Locked Moved Cinema 4D SDK python s22 r23
      mikeudinM
      Thank you @m_magalhaes !
