    Plugins Search Path from Preferences
    3 Posts 2 Posters 708 Views 2 Watching
    • merkvilsonM Offline
      merkvilson
      Hello.
      I'm trying to access and subsequently modify Plugins Search Path, which is located in the Preferences window.
      I have to accomplish this task via a Python script (not from pyp file).
      I have a problem at the first step when I'm trying to simply access its value and print it.
      pid, att = None, c4d.plugins.GetFirstPlugin()
      while att:
          if 'Plugins/Plugins' in str(att):
              pid = att.GetID()
              break
          att = att.GetNext()
      prefs = c4d.plugins.FindPlugin(pid)
      plugins = prefs[c4d.PREF_PLUGINS_PATHS]
      print(prefs[c4d.PREF_PLUGINS_PATHS])
      In this example, it prints an empty string even though several paths are already added.
      However, if I open the preferences window, it prints the correct values instead of an empty string. Is it possible to bypass opening the prefs window and make the script work correctly?
        ferdinand @merkvilson
        Hello @merkvilson,
        thank you for reaching out to us. That is unfortunately not possible because the preference node for the Plugins section in the preferences is designed in a manner which prevents that. It reads the necessary data only when its GetDDescription method is being called. I.e., the plugin paths parameter is only populated once you have opened the preferences dialog, causing GetDDescription of that node being called. I personally think this is bad design, but our developers seem to disagree, so it probably will stay as is.
        What you can do is read the values from the plugins.json file at the root of the preference directory of the running Cinema 4D instance. The JSON file is however serialized with our DescribeIO routines, so it will look something like this for a singular path:
          "identification": "plugins",
          "content": {
            "referenceDataType": "net.maxon.interface.datadictionary-C",
            "_impl": {
              "_mode": 2,
              "_data": [
                  "dataType": "net.maxon.datatype.id",
                  "content": "searchPaths"
                  "dataType": "(net.maxon.interface.url-C,bool)",
                  "isArray": true,
                  "content": [
                      "_0": {
                        "referenceIndex": 0,
                        "referenceDataType": "net.maxon.interface.url-C",
                        "_scheme": "file",
                        "_path": "/Path/To/Plugin/Directory/",
                        "_authority": {},
                        "_data": {}
                      "_1": true
        When we decide to change something about the object which is being serialized into this file, currently a DataDictionary, also this file will change. I know that this is not a very satisfying solution, but unfortunately the best we can currently offer.
        For your understanding: When DesribeIO is serializing key-value pair types, it puts them into a list in the form: key, value, key, value, key, value, .... The DataDictionary which is serialized above stores its data under the _data key. So _data must here be read in the manner that this dictionary has a key searchPaths which stores the following value, which is an array of Url, bool tuples, expressing a plugin path and its activation state, which is then decomposed into its parts.
        merkvilsonM 1 Reply Last reply Reply Quote 0
          merkvilson @ferdinand
          Thanks @ferdinand
          I wrote this little script for those who want to add one plugin path via the C4D script. I will update it later.
          It will NOT overwrite existing paths. Restart is required for instant result.
          import os
          import json
          def add_plugin_path(path, restart = False):
              if os.path.exists(path): new_path = path.replace("\\", "/")
                  print("Path does not exists")
              prefs_folder      = c4d.storage.GeGetC4DPath(c4d.C4D_PATH_PREFS)
              prefs_path        = os.path.dirname(prefs_folder)
              plugins_json_path = os.path.join(prefs_path, 'plugins.json')
              if os.path.exists(plugins_json_path):
                  with open(plugins_json_path,'r',encoding="utf-8-sig") as plugins: plugins_json_raw = plugins.read()
                  plugins_dict = json.loads(plugins_json_raw)
                  content_dict = plugins_dict["content"]["_impl"]["_data"][1]["content"]
                  # Check if the new path is already in Plugins Path
                  for content_path in content_dict:
                      if os.path.normpath(content_path["_0"]["_path"]) == os.path.normpath(new_path):
                          print(f"'{new_path}' is already in Plugins Path.")
                  plugins_dict = {
                      'identification': 'plugins',
                      'content': {
                          'referenceDataType': 'net.maxon.interface.datadictionary-C',
                              '_impl': {
                                  '_mode': 2,
                                  '_data': [
                                          'dataType': 'net.maxon.datatype.id',
                                          'content': 'searchPaths'
                                          'dataType': '(net.maxon.interface.url-C,bool)',
                                          'isArray': True,
                                          'content': []}]}}}
              # Create new path content
              new_content = {
                  "_0": {
                      "referenceIndex": len(plugins_dict["content"]["_impl"]["_data"][1]["content"]),
                      "_scheme": "file",
                      "_path": new_path,
                      "_authority": {},
                      "_data": {}
                  "_1": True
              # Append the new path to the list of paths
              plugins_dict["content"]["_impl"]["_data"][1]["content"].append(new_content)
              # Convert the dictionary back to a JSON string
              updated_plugins_dict = json.dumps(plugins_dict, indent=4)
              # Write the updated dictionary back to a JSON file
              with open(plugins_json_path, 'w') as plugins_json: plugins_json.write(updated_plugins_dict)
              if restart: c4d.RestartMe()
          custom_path = r"/Path/To/Plugin/Directory/"
          add_plugin_path(path = custom_path, restart = False)
