    How to weld two points to the last selected point?
    windowss262023python
    5 Posts 2 Posters 1.3k Views
    • G Offline
      Gaal Dornik
      Hello, currently this code welds two points in the middle, but i want it to weld to the last selected point, setting MDATA_WELD_TOPOINT to True doesn't help. How to solve this?
      import c4d, sys
      # M A I N
          settings = c4d.BaseContainer()
          settings[c4d.MDATA_WELD_TOPOINT] = True
          result = c4d.utils.SendModelingCommand(
                          command=c4d.ID_MODELING_WELD_TOOL,
                          list=[op],
                          mode=c4d.MODELINGCOMMANDMODE_POINTSELECTION,
                          bc=settings,
                          doc=doc,
                          flags=c4d.MODELINGCOMMANDFLAGS_CREATEUNDO)
          if not result:
              raise RuntimeError(f"Modelling command failed for {op}.")
          # Inform Cinema 4D that the document has been modified.
      # Execute main()
      if __name__=='__main__':
      • G Gaal Dornik deleted this topic on
      • ferdinandF ferdinand restored this topic on
      • i_mazlovI Offline
        i_mazlov
        Hi @Gaal-Dornik ,
        Sorry for the delayed answer.
        The welding command was already comprehensively explained by Riccardo in this thread: ID_MODELING_WELD_TOO - Doesn't work [SOLVED].
        In addition, the undo issue was discussed in the following thread: Problem on AddUndo and SendModellingCommand (Weld Tool)
        As a compilation of both answers you can find the following code snippet (below) that welds currently selected points to the point with index pointIdx.
        Ilia
            op = doc.GetActiveObject()
            pointIdx = 2  # FIXME: put here the index of the point you'd like to weld to'
            settings[c4d.MDATA_WELD_POINTINDEX] = 2
            settings[c4d.MDATA_WELD_OBJECTINDEX] = op
            doc.StartUndo()
            doc.AddUndo(c4d.UNDOTYPE_CHANGE, op)
                            list=[op],
                            bc=settings,
                            doc=doc,)
            doc.EndUndo()
        G 1 Reply Last reply Reply Quote 0
        • G Offline
          Gaal Dornik @i_mazlov
          @i_mazlov
          The problem with this code - it doesn't always work correctly. Sometimes it's not taking into account selection order - welds to the first selected point for example. Look at this preview.
              lastPoint = op.GetPointS().GetLastElement()
              settings[c4d.MDATA_WELD_POINTINDEX] = lastPoint
              doc.StartUndo()
                              list=[op],
                              bc=settings,
                              doc=doc,)
              doc.EndUndo()
          • G Offline
            Gaal Dornik @Gaal Dornik
            Considering this thread it looks like getting points selection order is not trivial task for c4d api.
            • i_mazlovI Offline
              i_mazlov
              Yes, you found the thread about point selection just right!
