    Search vertexes within a radius [SOLVED]
    28 Posts 0 Posters 16.1k Views
    • H Offline
      Helper
      On 17/05/2016 at 12:56, xxxxxxxx wrote:
      Here is the sample code.
      Tell me what you guys think of it
      # the_selection is a variable that holds a Selection Set tag,
      # if just a sub-set of points is to be evaluated
      selection=None
      if the_selection!=None:
           selection=the_selection.GetBaseSelect()
      # now 'selection' is None or a selection bit list
      points=obj.GetAllPoints()
      if selection!=None:
           # create a list with only the selected points
           pts=[[i,p] for i,p in enumerate(points) if selection.IsSelected(i)]
           # no selection, so create a list with all the points
           pts=[[i,p] for i,p in enumerate(points)]
      # now pts contains a list with all the points coordinates and their index,
      # in the for [[index1,c4d.Vector()],...[indexN,c4d.Vector()]]
      # calculate the min and max values of the bounding box
      # defined by all points in the list
      min_x=min(a.x for a in pts)
      max_x=max(a.x for a in pts)
      min_y=min(a.y for a in pts)
      max_y=max(a.y for a in pts)
      min_z=min(a.z for a in pts)
      max_z=max(a.z for a in pts)
      # center coordinates of the cluster of points
      mid_coords=utils.MixVec(c4d.Vector(min_x,min_y,min_z),c4d.Vector(max_x,max_y,max_z),.5)
      # calculate all the octrees and their centers
      # three octrees will be created but it is easy
      # to create more levels.
      # Octree 1 will contain 8 lists of points
      # Octree 2 will contain 64 lists of points (8*8)
      # Octree 3 will contain 512 lists of points (8*8*8)
      # the oct_center lists contain the center coordinates of the
      # 2nd and 3rd octrees
      # 'distance' is the radius around the points coordinates
      # in the case of the octrees it is useful to add extra points
      # that overlap, to create a bit of redundancy.
      # Otherwise, points that align with the limits of octrees clusters
      # could be ignored, if the resulting list is to be checked
      # for distances between points
      oct1,oct2,oct3,oct_center2,oct_center3 = Calc_All_Octress(pts,min_x,max_x,min_y,max_y,min_z,max_z,distance)
      # sample code to show how to check for points within a distance:
      for pts1 in pts:
           # get the index and the point coordinates
           i,pt=pts1[0],pts1[1]
           # get the index of the point in the octree 1
           id1=GetQuadrant(pt,mid_coords)
           # if the point is found in octree #1...
           if oct1[id1]!=[[],[],[],[],[],[],[],[]]:
                # get the index of the point in the octree 2
                id2=(id1*8)+GetQuadrant(pt,oct_center2[id1])
                # if the point is found in octree #2...
                if oct2[id2]!=[[],[],[],[],[],[],[],[]]:
                     id3=(id2*8)+GetQuadrant(pt,oct_center3[id2])
                     # if the point is found in octree #3...
                     if oct3[id3]!=[[],[],[],[],[],[],[],[]]:
                          # go through all the points in the relevant octree #3 subset
                          for pts2 in oct3[id3]:
                               # if we dont't need to check the point against itself
                               # keep the following line
                               if pts2[0]==i: continue
                               # calculate the distance between the points
                               # I used LengthSquared for speed reasons
                               dist=(pts2[1]-pt).GetLengthSquared()
                               # only go on if the distance is within the required radius
                               if dist<=distance:
                                    # do something with the original point stored in 'pt'
                                    # or something with the newly found point,
                                    # whose index is stored in pts2[0] and
                                    # whose coordinates are stored in pts2[1]
                                    # If just the first match is needed, we can
                                    # perform a 'break' and this will get back to the
                                    # main loop, increasing speed even further
      # ****************** Here are the octree creating routines ********************
      def GetQuadrant(p,center) :
           return (4*(p.x<center.x))+(2*(p.y<center.y))+(p.z<center.z)
      def Create_Octs(ls,cx,cy,cz,dist) :
           # if the list is empty, return a list containing 8 empty lists
           # just to keep the structure intact
           if len(ls)==0: return [[],[],[],[],[],[],[],[]]
           # calculate the new limits with the distance padding added/subtracted
           cx1=cx-dist
           cx2=cx+dist
           cy1=cy-dist
           cy2=cy+dist
           cz1=cz-dist
           cz2=cz+dist
           # create the 8 new lists from the main volume list
           ls1=[a for a in ls if a[1].x<cx2 and a[1].y<cy2 and a[1].z<cz2]
           ls2=[a for a in ls if a[1].x<cx2 and a[1].y<cy2 and a[1].z>=cz1]
           ls3=[a for a in ls if a[1].x<cx2 and a[1].y>=cy1 and a[1].z<cz2]
           ls4=[a for a in ls if a[1].x<cx2 and a[1].y>=cy1 and a[1].z>=cz1]
           ls5=[a for a in ls if a[1].x>=cx1 and a[1].y<cy2 and a[1].z<cz2]
           ls6=[a for a in ls if a[1].x>=cx1 and a[1].y<cy2 and a[1].z>=cz1]
           ls7=[a for a in ls if a[1].x>=cx1 and a[1].y>=cy1 and a[1].z<cz2]
           ls8=[a for a in ls if a[1].x>=cx1 and a[1].y>=cy1 and a[1].z>=cz1]
           # return a list containing all the calculated sub-lists
           return [ls8,ls7,ls6,ls5,ls4,ls3,ls2,ls1]
      def Calc_All_Octress(pt_list,min_x,max_x,min_y,max_y,min_z,max_z,distance) :
           # calculate the center of the points volume
           cx,cy,cz=utils.MixNum(min_x,max_x,.5),utils.MixNum(min_y,max_y,.5),utils.MixNum(min_z,max_z,.5)
           # create the octree 1
           # this first one is straightforward
           oct1=Create_Octs(pt_list,cx,cy,cz,distance)
           # create the octree 2
           oct2=[] # octree 2
           oct_center2=[] # centers 2
           # store the previous min and max values because some lists my be empty and
           # python would complain if we tried to get a min or a max from an empty list
           xmin,ymin,zmin=min_x,min_y,min_z
           xmax,ymax,zmax=max_x,max_y,max_z
           # go through all the sub-lists inside oct1
           for l in oct1:
                # retried the stored min and max values
                # if the sub-list is not empty, calculate new min and max values
                if len(l)>0:
                     min_x=min(a[1].x for a in l )
                     max_x=max(a[1].x for a in l )
                     min_y=min(a[1].y for a in l )
                     max_y=max(a[1].y for a in l )
                     min_z=min(a[1].z for a in l )
                     max_z=max(a[1].z for a in l )
                # calculate new center of the points volume in the sub-list
                # and add it to the list of centers of the new cluster for octree 2
                oct_center2.append(c4d.Vector(cx,cy,cz))
                # create 8 new cluters from this volume and add them to the octree 2 list
                oct2.extend(Create_Octs(l,cx,cy,cz,distance))
           # create the octree 3
           oct3=[] # octree 3
           oct_center3=[] # centers 3
           # go through all the sub-lists inside oct2
           for l in oct2:
                if len(l)>0:
                # and add it to the list of centers of the new cluster for octree 3
                oct_center3.append(c4d.Vector(cx,cy,cz))
                # create 8 new cluters from this volume and add them to the octree 3 list
                oct3.extend(Create_Octs(l,cx,cy,cz,distance))
           # seeing how the code for calculating octree 2 and octree 3 is very similar,
           # it would be wuite easy to implement deeper octree calculations
           # for my purposes, three levels are enough
           # return the octrees and the octree centers lists
           return oct1,oct2,oct3,oct_center2,oct_center3
      • H Offline
        Helper
        On 17/05/2016 at 15:49, xxxxxxxx wrote:
        Thanks Rui,
        I think you're missing [1] in one of your min max code blocks.
        It would not run using a.x, etc...
        When I change the distance value. I don't see any difference in what gets grabbed.
        Here is my entire code that I'm using in the script manager.
        Create a cube with 8 subdivisions in x,y,z. Then make it editable. Then run this script.
        At the end of the code I tested selecting the results from oct1,oct2,oct3,oct_center2, and oct_center3.
        Seems to work as expected. But oct1 and oct2 select very few points before oct3 finally selects the rest of them. Not sure if this is normal?
        But the main thing is the distance doesn't seem to do anything the way I'm using it.
        Am I using it wrong?
        from c4d import utils
           #If the list is empty, return a list containing 8 empty lists just to keep the structure intact
           #Calculate the new limits with the distance padding added/subtracted
           cx1 = cx-dist
           cx2 = cx+dist
           cy1 = cy-dist
           cy2 = cy+dist
           cz1 = cz-dist
           cz2 = cz+dist
           #Create the 8 new lists from the main volume list
           #Return a list containing all the calculated sub-lists
           #Calculate the center of the points volume
           cx,cy,cz = utils.MixNum(min_x,max_x,.5),utils.MixNum(min_y,max_y,.5),utils.MixNum(min_z,max_z,.5)
           #Create octree 1
           #This first one is straightforward
           oct1 = Create_Octs(pt_list,cx,cy,cz,distance)
           #Create octree 2
           oct2 = [] # octree 2
           oct_center2 = [] # centers 2
           #Store the previous min and max values because some lists my be empty and
           #python would complain if we tried to get a min or a max from an empty list
           xmin,ymin,zmin = min_x,min_y,min_z
           xmax,ymax,zmax = max_x,max_y,max_z
           #Go through all the sub-lists inside oct1
           for l in oct1:
                #Retried the stored min and max values
                #If the sub-list is not empty, calculate new min and max values
                if len(l)>0:
                #Calculate new center of the points volume in the sub-list
                #Then add it to the list of centers of the new cluster for octree 2
                #Create 8 new cluters from this volume and add them to the octree 2 list
                oct2.append(Create_Octs(l,cx,cy,cz,distance))
           #The octree 2 list ended up with an extra set of [] around it
           #Remove the internal list from outer list to keep the structure if the octree 2 equal to the structure of octree 1
           oct2=[val for sublist in oct2 for val in sublist]
           #Create the octree 3
           oct3=[]          #Octree 3
           oct_center3=[]   #Centers 3
           #Go through all the sub-lists inside oct2
           for l in oct2:
                if len(l)>0:
                     min_x = min(a[1].x for a in l )
                     max_x = max(a[1].x for a in l )
                     min_y = min(a[1].y for a in l )
                     max_y = max(a[1].y for a in l )
                     min_z = min(a[1].z for a in l )
                     max_z = max(a[1].z for a in l )
                #Then add it to the list of centers of the new cluster for octree 3
                #Create 8 new cluters from this volume and add them to the octree 3 list
                oct3.append(Create_Octs(l,cx,cy,cz,distance))
           #The octree 3 list ended up with an extra set of [] around it
           #Remove the internal list from outer list to keep the structure if the octree 3 equal to the structure of octree 1 and octree 2
           oct3 = [val for sublist in oct3 for val in sublist]
           #Seeing how the code for calculating octree 2 and octree 3 is very similar,
           #It would be easy to implement deeper octree calculations. But for my purposes three levels are enough
           #Return the octrees and the octree centers lists
        def main() :
          #The selection variable holds a Selection Set tag if just a sub-set of points is to be evaluated
          #Selection is either None. Or a selection bit list
          selection = None
          if selection != None: selection = the_selection.GetBaseSelect()
          points = op.GetAllPoints()
          #Create a list named "pts" with only the selected points
              pts = [[i,p] for i,p in enumerate(points) if selection.IsSelected(i)]
              #No selection, so create a list using all the points in the object
              pts = [[i,p] for i,p in enumerate(points)]
          # pts now contains a list with all the points coordinates and their index,
          #Calculate the min and max values of the object's bounding box defined by the points in the list
          min_x = min(a[1].x for a in pts)
          max_x = max(a[1].x for a in pts)
          min_y = min(a[1].y for a in pts)
          max_y = max(a[1].y for a in pts)
          min_z = min(a[1].z for a in pts)
          max_z = max(a[1].z for a in pts)
          #This gets the center coordinates of the cluster of points
          mid_coords = utils.MixVec(c4d.Vector(min_x,min_y,min_z), c4d.Vector(max_x,max_y,max_z), 0.5)
          # three octrees will be created but it is easy to create more levels.
          # the oct_center lists contain the center coordinates of the 2nd and 3rd octrees
          # In the case of the octrees it is useful to add extra points that overlap, to create a bit of redundancy
          # Otherwise, points that align with the limits of octrees clusters could be ignored,
          # if the resulting list is to be checked for distances between points
          distance = 1.0
          #Now let's select the points that the above code grabbed to visually see the results
          #Note: using oct3 seems to crash with array out of bounds error!
          PointS = c4d.BaseSelect()
          for p in xrange(len(oct1)) :  #<----Also try oct2,oct3,oct_center2,oct_center3
              PointS.Select(p)
          PointS.CopyTo(op.GetPointS())
        if __name__=='__main__':
        • H Offline
          Helper
          On 18/05/2016 at 00:53, xxxxxxxx wrote:
          The octrees don't store the points found within a distance.
          They just subdivide the volume space in smaller chunks for faster verification. The distance provided for the creation of the octrees is just used to adjust the possible error that would occur, near the limits of the chunks.
          Try the code below, that uses the octrees to go through all the points list and selects the points within a distance.
          Oh, if you are using a cube to test things, since the mesh is regular, eventually, all points will find a match within the radius and everything will get selected.
          Create more irregular shapes to test.
              distance =20.0
              PointS.DeselectAll()
              for pts1 in pts:
                                  # don't check a point against itself
                                  dist=(pts2[1]-pt).GetLength()
                                  if dist<=distance:
                                      PointS.Select(i)
          • H Offline
            Helper
            On 18/05/2016 at 02:02, xxxxxxxx wrote:
            Thanks for posting guys. This looks like really useful stuff!
            • H Offline
              Helper
              On 18/05/2016 at 07:50, xxxxxxxx wrote:
              By the way:
              I found a rather old link in my bookmarks. Maybe, it's interesting for you too:
              http://thomasdiewald.com/blog/?p=1488
              • H Offline
                Helper
                On 18/05/2016 at 08:47, xxxxxxxx wrote:
                Thanks Rui.
                I wasn't sure what to do with that for() loop in your original code (if it was optional or not).
                But after inserting your second for() loop example. It works as expected.
                Thanks for posting the code,
                • H Offline
                  Helper
                  On 18/05/2016 at 09:07, xxxxxxxx wrote:
                  You are welcome, Scott
                  And, thank you, mp5gosu.
                  I updated the Calc_All_Octrees routine (edited the post) a little bit to make it slightly faster.
                  • H Offline
                    Helper
                    On 29/12/2016 at 17:46, xxxxxxxx wrote:
                    Sorry to dig up an old thread...
                    Does anyone have the source code Kuroyume kindly provided at http://www.kuroyumeszone.com/downloads/CollisionDeformer.zip? It seems as though the website is dead.
                    -CMPX
