    Problems Loading .dlls
    31 Posts 0 Posters 18.6k Views
    • H Offline
      Helper
      On 02/12/2014 at 14:27, xxxxxxxx wrote:
      @Mohamed.
      Does my code help you out with your question about sub folders?
      The sPath variable can be used to target the .dll in any folder. Not just the master plugin folder.
      For example if it's in the "res" folder it would be something like this:
      //If you want to target the res folder use this instead
      //**Just be sure you have actually put the .dll file in the res folder**
        Filename fn = GeGetPluginPath() + "res";
        char *sPath = fn.GetString().GetCStringCopy();
      Did that answer your question?
      • H Offline
        Helper
        On 02/12/2014 at 16:26, xxxxxxxx wrote:
        I think I understand how it works with LoadLibrary() now, but using this method you won't need the headers & libraries anymore I guess "so the compiler will give you a function pointer, and will trust you about the usage"
        is this true?
        • H Offline
          Helper
          On 02/12/2014 at 16:31, xxxxxxxx wrote:
          Mohamed,
          yes, you are right. Except for some terminology. "the compiler will give" part. The compiler has nothing to do with it. LoadLibrary() in combination with GetProcAddress() will give you the function pointer. But the later part is right again, the compiler needs to trust you about the usage.
          • H Offline
            Helper
            On 02/12/2014 at 16:39, xxxxxxxx wrote:
            Oh yeah. Sorry about that.
            I forgot to post the header section in my plugin's main.cpp file.
            Yes. I am including the header file for the DLL's project. But that's all. And nothing else.
            #include <Windows.h>
            #include "C:\Program Files\MAXON\Your C4D version\plugins\SimpleDLL\SimpleH.h"  #The DLL's .h file must be here!!
            #include "c4d.h"
            #include <string.h>
            I am not setting any of the compiler's options to point at any of the DLL program's files either.
            That was another mistake I was making.
            • H Offline
              Helper
              On 02/12/2014 at 16:49, xxxxxxxx wrote:
              @Andreas you are right, my terminology was wrong !Tongue[URL-REMOVED] , but you got my point about the trust part.
              @Scotta you can compile the Cinema4D plugin without the header nor the library linkage , you just need the operating system API to hook the DLL
              [URL-REMOVED] @maxon: This section contained a non-resolving link which has been removed.
              • H Offline
                Helper
                On 02/12/2014 at 19:01, xxxxxxxx wrote:
                I'm still trying to figure out how to use classes in my DLL's.
                But you can mark this thread as Solved if want Andreas. I'll leave that up to you.
                If anyone has a class based example. They can send it to me at: [email protected]
                • H Offline
                  Helper
                  On 07/12/2014 at 13:08, xxxxxxxx wrote:
                  Hey guys.
                  I finally managed to figure out how to use dll's with classes in them.
                  It requires using a class as an "interface". Which is something I've never done before. And it took me a while to figure it all out.
                  I'll attempt to write a quick tutorial how to do this here.
                  Hopefully I won't gloss over anything. And it should be a simple cut and paste operation for you to follow along with.
                  Start Tutorial
                  Lets begin by using a simple 64bit C4D CommandData plugin to host the .dll to make it simple.
                  After you have your C4D CD plugin created and working. Lets write the DLL in a brand new separate project, and separate folder.
                  *Note: I will put this new DLL project in my C4D plugins folder. But it can go anywhere you want.
                            You'll just have to change the file paths accordingly if you do that.
                  -Launch Visual Studio and choose "New project"
                  -I named my project: "ExportingDllClasses" which will create a .dll file with this same name
                  -Select the C++ ->Win32 Project wizard
                  -In the wizard's Applications Settings window. Check "dll" & "Empty project"
                  -If you're using a 64 bit C4D plugin. Go to the Configuration Manager and change the platform to win64. Using copy setting from win32.
                  -You should now have a .dll making project consisting of only empty folders at this point
                  -Add a new .h file called "generic_interface.h" to your Header Files folder
                  -Add a new .cpp file called "mydll.cpp" to your Source Files folder
                  Put the following code into these two files. And compile it:
                  /////generic_interface.h
                  //We create an "Interface" class of virtual functions that will be the home class of our .dll
                  //Then we will create another class derrived from this interface...which we will then export so other programs can use it
                  class Iclass
                  public:
                    virtual void destroy() = 0;
                    virtual double myAdd(double a, double b) = 0;
                    virtual double GetNumber(double num) = 0;
                  /////mydll.cpp
                  #include "generic_interface.h"
                  #include <iostream>
                  #include <windows.h>
                  using namespace std;
                  class MyClass : public Iclass
                    private:
                        int my_data;
                    public:
                    MyClass() : my_data(0)
                        cerr << "MyClass constructor\n";  //Outputs message if an error occurs
                    ~MyClass()
                        cerr << "MyClass destructor\n";  //Outputs message if an error occurs
                    void destroy()
                        delete this;
                        return a+b;
                        return num;
                  //This will export the above MyClass class so other programs can use it from the .dll file
                  extern "C" __declspec(dllexport) Iclass* __cdecl create_Iclass()
                    return new MyClass;
                  //Now we add the code to load the .dll file into our C4D plugin in the plugin's main.cpp file
                  #include "C:\\Program Files\\MAXON\\Your C4D Version\\plugins\\ExportingDllClasses\\generic_interface.h"
                  #include "c4d.h"
                  #include <string.h>
                  ...Your other plugin stuff here...
                  Bool PluginStart(void)
                    //example of installing a crashhandler
                    old_handler = C4DOS.CrashHandler;     // backup the original handler (must be called!)
                    C4DOS.CrashHandler = SDKCrashHandler; // insert the own handler
                    /////////////// Dynamically Loading the DLL section //////////////
                    //Get the folder where the .dll file is located
                    Filename fn = "C:\\Program Files\\MAXON\\CINEMA 4D R13\\plugins\\ExportingDllClasses\\x64\\Debug";
                    char *path = fn.GetString().GetCStringCopy();
                    //Filename fn = GeGetPluginPath() + "res";
                    //char *sPath = fn.GetString().GetCStringCopy();
                    //Use SetDllDirectory to set the directory path where the .dll file exists
                    //Stops loading the plugin if the .dll file is not found
                    if(!SetDllDirectory((LPCSTR)path)) { GePrint("No .dll file Found!!"); return FALSE; }
                    //Try to Load the .dll...Don't load the plugin if it fails
                    HMODULE WINAPI dll_handle = LoadLibrary("ExportingDllClasses.dll");
                    if(!dll_handle)
                        GePrint("Error loading the .dll with LoadLibrary()!!");
                        DWORD err = GetLastError();
                        GePrint(LongToString((LONG)err));
                        return FALSE;
                    //If we have successfully loaded the .dll file
                    //First we create a custom type called: "iclass_factory" (it's called a factory because we can create as many instances as we want)
                    //Then we point to it using GetProcAddress()
                    typedef Iclass* (__cdecl *iclass_factory)();
                    iclass_factory icf = reinterpret_cast<iclass_factory>( ::GetProcAddress(dll_handle, "create_Iclass"));
                    if(!icf)
                        GePrint("Unable to load create_Iclass from DLL!");
                        ::FreeLibrary(dll_handle);
                        //Stop loading the plugin if this failed
                        return FALSE;
                    //Then we ask the factory to create a a new instance of the Iclass interface class in the dll program
                    //Now this instance is local and can be treated like any other class. So we get it's members the same way
                    Iclass *ik = icf();
                    //Then we get the functions from the DLL and use them in C4D
                    double sum = ik->myAdd(2.4, 2);
                    GePrint(RealToString(sum));
                    double num = ik->GetNumber(55.8);
                    GePrint(RealToString(num));
                    //Finally. We destroy the instance, and free the memory used
                    ik->destroy();
                    //Lastly...Register your plugin if the dll was loaded properly
                    if(!RegisterSimplePlugin()) return FALSE;
                    return TRUE;
                  ..The rest of you plugin's main.cpp code here...
                  Hopefully this is all clear enough to follow.
                  Let me know if I left something out.
                  • H Offline
                    Helper
                    On 08/12/2014 at 15:24, xxxxxxxx wrote:
                    I'm not 100% sure "may someone more experienced than me can confirm this" , I think you got a problem here with your library, it may work only for the same compiler & language.
                    I think a better option would be "don't return the class" , you need to just create the class, hold its pointer somewhere by the library, and make all your exported functions access that pointer to operate on class internal data/functions. , I think this would let the library be portable to any language that accepts C DLLs.
                    but as I said this needs confirmation as I didn't test it myself.
                    • H Offline
                      Helper
                      On 09/12/2014 at 03:33, xxxxxxxx wrote:
                      Hi Mohamed,
                      I'm not quiet sure, what you are referring to?
                      • H Offline
                        Helper
                        On 09/12/2014 at 07:16, xxxxxxxx wrote:
                        Hi Andreas, I'm referring to this:
                        extern "C" \__declspec(dllexport) Iclass\* \__cdecl create_Iclass()
                          return new MyClass;
                        here he returns the class, and have the header to show the compiler the class layout, but what if the DLL is compiled with MSVC100 and used in a program which requires MSVC110 or Intel compiler,
                        or even used in a non C++ program, if it is for C++, the Class layout in the DLL will be different from the Class layout in the executable, which will create a potential crash for an undefined behavior "hard to debug".
                        this is all an assumption from what I learnt about C++ and why Classes are hard to export.
                        I think a possible solution would be:
                        static MyClass\* theClass = nullptr;
                        extern "C" \__declspec(dllexport) bool \__cdecl create_Iclass()
                              if(!theClass)
                                    theClass = new MyClass;
                            return theClass != nullptr;
                        rest of the functions should operate on that pointer, delete that pointer at the end, etc... this is considered an encapsulated class which is inside the DLL and won't need to be exported outside the DLL borders.
                        off topic: how to put code in a code brackets on forums.
                        • H Offline
                          Helper
                          On 09/12/2014 at 11:05, xxxxxxxx wrote:
                          after some reading, I noticed what Scotta did is a Class interface, which should be fine across different C++ compilers.
                          but I think it will be a " C++ DLL " so it is unusable for other languages like C#.
