    How to allocate a gradient in Python?
    Scheduled Pinned Locked Moved PYTHON Development
    22 Posts 0 Posters 15.2k Views
    • H Offline
      Helper
      On 10/06/2013 at 00:12, xxxxxxxx wrote:
      The symbols file is is needed because it is part of the resource associated with a plugin or more
      specifically its look up table the resource parser is using to identify certain elements.
      In python description ids are imported properly(automatically) from the symbols file, everything
      else - custom ids, dialog ids is not. The reason ? Only god knows why. You have either to copy
      the values or write a little parser for the symbols file which does autoimport its members to your
      project.
      The downside of auto importing - if you are using an IDE,  it won't know your symbols constants
      anymore, so will loose the autocomplete feature on these. That is why I personally went back
      to simply copy pasting the symbols file. With a little macro you can make it one press of a button.
      edit : You could of course write an autoimporter that doesn't work at runtime, but (over)writes
      a python symbols definition py(c) file, but doing that properly will be a bit more work. as you
      will have to analyze existing code in the file and so on.
      • H Offline
        Helper
        project.
        ⭐ https://github.com/NiklasRosenstein/c4dtools#example-code
        c4dtools does this for you, and it also allows parsing the description resources so you don't have to
        fuzz with the symbolcache. Well, if you're using an IDE, you won't have the symbols in the auto-
        ompletion, but you could also write a script that parses the resource symbols and creates an
        importable Python file that contains the resources.
