    New Surfaces Materials?
    56 Posts 0 Posters 40.2k Views
    • H Offline
      Helper
      On 17/04/2013 at 11:10, xxxxxxxx wrote:
      I don't have a specific pattern in mind. I never got close enough to even get that far with it.
      I just wanted to know how to change the pattern.
      At this point. I have to go back and look at what you guys have posted again. And try to figure out how turn it into something that works (changes the pattern).
      • H Offline
        Helper
        On 17/04/2013 at 11:55, xxxxxxxx wrote:
        To generate things like stone or concrete you're really looking at generating a fractal noise of some kind. That's all these procedural rock/stone shaders are - just a fractal or combination of fractals. If you have Vue, it's node-based material editor is a good example of combining fractals like this.
        So you have to know how to produce those. There are some in Cinema, take a look at fBm or RidgedMultifractal. Otherwise you'll find lots on the net. You will want to generate a value from 0 to 1 and return a colour or bump value accordingly as others have already said.
        • H Offline
          Helper
          On 17/04/2013 at 12:49, xxxxxxxx wrote:
          Thanks Steve,
          I hope I can get far enough to use that information.
          Right now I'm still trying to figure out how to make even a very simple basic pattern. Like a simple checkerboard pattern. Or a series of circles.
          • H Offline
            Helper
            On 17/04/2013 at 14:19, xxxxxxxx wrote:
            i just wanted to stress book tip posted by yannick -  _Texturing and Modeling: A Procedural  _
            Approach. this book  contains a pretty down to earth description on how to write a brick
            wall shader (among dozens of dozens other shader listings). one of the must have books
            for coding simpletons like me imho 😉
            • H Offline
              Helper
              On 17/04/2013 at 15:37, xxxxxxxx wrote:
              Before I can use that kind of information. I first need to learn how to use the code in the C4D SDK.
              As far as I can make out. The main methods I need to use are the InitRender() method & the Output() method. But I'm not even really sure if I really need the InitRender() method.
              InitRender() seems to be for sampling. But will I need to do any sampling to create my own patterns?
              These are the basic things I need is to know how to do with the SDK first. Before trying to do anything fancy:
              -How to create colored lines using cd->p?
              -How to create a colored checkerboard pattern using cd->p?
              -How to create a colored grid of circles using cd->p?
              I'm having a very hard time understanding how these basic things work in C4D SDK.
              • H Offline
                Helper
                On 17/04/2013 at 16:12, xxxxxxxx wrote:
                You will need to implement InitRender, for (at least) two reasons. If you need to access any data from the shader interface, do it here and store the results - otherwise you could be accessing the parameters hundreds of times whenever a render occurs. Also, if you have any shader links in your shader you absolutely must call their InitRender functions, and you do that here.
                To get started, here's the complete listing of a simple shader I wrote to mirror-image a bitmap. It's very simple and you won't need the resource to understand it. It just lets the user choose to mirror the bitmap horizontally and/or vertically, and the only other interface element is a link for the bitmap:
                // BMFlip
                // bmflip.cpp
                // includes
                #include "c4d.h"
                #include "bmflip.h"
                #include "xbmflip.h"
                #include "c4d_symbols.h"
                SHADERINFO BitmapFlip::GetRenderInfo(BaseShader *sh)
                     return SHADERINFO_BUMP_SUPPORT;
                Bool BitmapFlip::Init(GeListNode *node)
                        // these are class-level variables
                     shader = NULL;
                     flipX = FALSE;
                     flipY = FALSE;
                     return TRUE;
                void BitmapFlip::FreeRender(BaseShader *chn)
                     if(shader)
                          shader->FreeRender();
                     shader = NULL;
                Bool BitmapFlip::Message(GeListNode *node, LONG type, void *msgdat)
                     BaseContainer *data;
                     data = ((BaseShader* )node)->GetDataInstance();
                     HandleInitialChannel(node, BMFLIPSHADER_TEXTURE, type, msgdat);
                     HandleShaderMessage(node, (BaseShader* )data->GetLink(BMFLIPSHADER_TEXTURE, node->GetDocument(), Xbase), type, msgdat);
                     return TRUE;
                INITRENDERRESULT BitmapFlip::InitRender(BaseShader *chn, const InitRenderStruct& irs)
                     INITRENDERRESULT result;
                     data = chn->GetDataInstance();
                     // get gadget values
                     flipX = data->GetBool(BMFLIPSHADER_FLIPX);
                     flipY = data->GetBool(BMFLIPSHADER_FLIPY);
                     shader = (BaseShader* )data->GetLink(BMFLIPSHADER_TEXTURE, irs.doc, Xbase);
                     if(shader)
                          result = shader->InitRender(irs);
                          return result;
                     return INITRENDERRESULT_OK;
                Vector BitmapFlip::Output(BaseShader *chn, ChannelData *cd)
                     Vector res, uv;
                     if(!shader) return Vector(0.0, 0.0, 0.0);          // return black if no bitmap present
                     uv = cd->p;                         // get the original UV value so we can restore it later
                     if(flipX)
                          cd->p.x = 1.0 - cd->p.x;
                     if(flipY)
                          cd->p.y = 1.0 - cd->p.y;
                     res = shader->Sample(cd);           // get the bitmap value at this point
                     cd->p = uv;                         // restore the UVs
                     return res;                                                  // return the colour of the bitmap at the mirrored position
                // register the plugin
                Bool RegisterBMFlip(void)
                     String name;
                     name = "Bitmap Transform";
                     if(RegisterShaderPlugin(ID_BMFLIP, GeGetDefaultFilename(DEFAULTFILENAME_SHADER_EFFECTS) + String("Bitmap Transform"), 0, BitmapFlip::Alloc,"Xbmflip", 0))
                          return TRUE;
                     else
                          return FALSE;
                Hope that helps!
                Steve
                • H Offline
                  Helper
                  On 17/04/2013 at 16:22, xxxxxxxx wrote:
                  I haven't tried it but I imagine that for a four-square checkerboard Output() would look something like this:
                  Vector MyShader::Output(BaseShader *chn, ChannelData *cd)
                       Vector col;
                       // cd.p.x and cd.p.y range from 0 to 1
                       if((cd.p.x < 0.5 && cd.p.y < 0.5) || (cd.p.x >= 0.5 && cd.p.y >= 0.5))
                            col = Vector(0.0);     // return black for top-left and bottom-right squares
                       else
                            col = Vector(1.0);     // return white for the other two squares
                       return col;
                  No idea if it works! But try it and see.
                  • H Offline
                    Helper
                    On 17/04/2013 at 16:47, xxxxxxxx wrote:
                    ^Yes. It does work.
                    Thanks Steve.
                    But I'm a bit puzzled why it works.
                    You aren't using a loop to get the positions of p.
                    I would have thought that I would have needed to use a loop in this case. To check the position (then set the color) of p.
                    That's how I normally get the colors of a bitmap for example. looping through each line of pixels.
                    But what you did.
                    Setting certain sections of the shader to black or white without using a loop. Seems strange to me. And something I'll need to understand. Because I think I'll need to use a similar technique to create other things. Like circles and more complex shapes.
                    • H Offline
                      Helper
                      On 18/04/2013 at 01:00, xxxxxxxx wrote:
                      Glad to know it works. You don't need a loop because Cinema calls Output() for each point to be rendered, setting cd->p accordingly. So you don't iterate through all the points in the UV data, you just calculate the colour to return at the point passed to Output().
                      • H Offline
                        Helper
                        On 18/04/2013 at 07:38, xxxxxxxx wrote:
                        OK. Thanks a lot for the help Steve.
                        I have enough information now to start looking at formulas and trying to putting something together.
                        But I'm a long way from controlling gaps and shapes.
                        Once again. I must make this final plea the the Maxon team (or anyone willing).
                        Could you please provide us with one example of a procedural shader like the pavement shader?
                        It doesn't matter what the pattern is, or what the colors are.
                        Something that shows us how to change the gaps, shapes, and colors of the pattern so we can use it as a guide making our own shaders.
                        If I end up figuring it out myself. I'll share what I come up with.
                        Thanks,
                        • H Offline
                          Helper
                          // A simple turbulence shader
                          Vector ExampleShader::Output(BaseShader *chn, ChannelData *cd)
                          Vector p;
                          if (cd->vd)
                              p = cd->vd->p;
                          else
                              p = cd->p;
                          return Vector(Turbulence(p, 3.0, TRUE));
                          // Using the turbulence value to output either red or green
                          Vector p;
                          if (cd->vd)
                              p = cd->vd->p;
                          else
                              p = cd->p;
                          Real threshold = 0.5; // Introduce a threshold to decide on the output color
                          if (Turbulence(p, 3.0, TRUE) > threshold)
                              return Vector(1.0, 0.0, 0.0);
                          else
                              return Vector(0.0, 1.0, 0.0);
                          // Or: Displacing the turbulence with a noise
                          Vector p;
                          if (cd->vd)
                              p = cd->vd->p;
                          else
                              p = cd->p;
                          Real displace_scale = 0.5;        // Introduce a scale for the displacing noise
                          Real displace_intensity = 0.75;   // Introduce a value to control the intensity of the displacement effect
                          return Vector(Turbulence(p + Noise(p * displace_scale) * displace_intensity, 3.0, TRUE));
                          // Or: a simple 2D checkerboard (without MIP mapping, rather ugly)
                          Vector p = cd->p;
                          p *= 0.2; // Introduce a scale to control the size of the squares
                          p.x -= (LONG)Floor(p.x);
                          p.y -= (LONG)Floor(p.y);
                          if ((p.x > 0.5) != (p.y > 0.5))
                              return Vector(1.0);
                          else
                              return Vector(0.0);
                          Of course, all the control values I have introduced in the Output() function would normally be retrieved from the shader's BaseContainer in InitRender() and then stored in private class members.
                          You see, writing a shader is very easy. But it can also get very complex, depending on the pattern you want.
                          Algorithms for common patterns can be easily found on the web. For example, here are some old Renderman shaders from the 80s 🙂
                          You can open the .sl files in a text editor.
                          http://www.cs.rit.edu/~mrp9521/cg/renderman.html
                          http://www.renderman.org/RMR/Shaders/BMRTShaders/
                          Frank
                          • H Offline
                            Helper
                            On 18/04/2013 at 12:51, xxxxxxxx wrote:
                            Thanks Frank,
                            I think the thing I'm going to have the toughest time figuring out is how to control gap size between shapes. That's probably what I'll really need to see an example of the most.
                            Also.
                            After setting up my plugin and getting the basic stuff in place. I came across another issue.
                            If I use a vector type as a color. I get lots really horrible noises all over the object when I render it.
                            But If I use an LVector with a value of 125 like the mandelbrot SDK example uses. It fixes that problem.
                            Example:
                            #define CCOUNT 125
                            Vector *colors;
                            colors = GeAllocType(Vector,CCOUNT);
                            I'm wondering whats exactly going on with that?
                            I'm guessing that it maybe has something to do with the amount of bits a standard vector holds?
                            I'm also wondering what the value 125 means. And what happens if I use a higher of lower number?
                            • H Offline
                              Helper
                              On 18/04/2013 at 23:45, xxxxxxxx wrote:
                              I don't know what your shader code looks like, and why you would need a Vector array with 125 elements. The Mandelbrot shader needs an array because it calculates a fixed set of colors in InitRender() that it later chooses its result color from in Output(). But that's a special thing and you probably won't need that in your shader.
                              Vector is the correct type for a single color value, a Vector array would store lots of colors.
                              I can only imagine you're screwing your results up by doing some stuff in the Output() that might behave strange in a multi-threaded context. Remember, Output() is called for each (sub-)pixel that each thread renders.
                              And about the gaps, it really would just be a very simple addition to the checkerboard code I have posted. You already know where the seams between the squares are, so you could just introduce a value for gap width, add or subtract it from the position (depending on if you are closer to a lower or a higher border of a square) and fill it with another color.
                              It is all very basic stuff, you just have to read up on it 😉
                              Did you have a look e.g. at the Renderman brick shader on the second page I linked to in my previous posting? It shows everything you're just asking for, and it's even commented (well, a bit).
                              • H Offline
                                Helper
                                On 19/04/2013 at 08:58, xxxxxxxx wrote:
                                I have only had a chance to briefly look at those Renderman shaders.
                                I had to get my basic shader plugin working first. But I'll take a close look at them today.
                                I'm a complete newb at this shader stuff. So I copied a lot of the code in the Mandelbrot example to get me started.
                                I think I might have gotten that noisy result because I used my color vector as a pointer.
                                Today I removed   that color pointer code from my code. And just created a standard color vector. And now it seems to work fine without using an LVector.
                                Your 2D checkerboard example doesn't work for me for some reason. The shader is all black.
                                The other examples you posted work fine. But for some reason that one doesn't. And I'm trying to figure out why it isn't working correctly.
                                *Edit- I found where the noise problem is coming from.
                                If I declare the vector (pointer or not) as a class member variable. Then use that vector in my Output() method. I get horrendous noise when rendering.
                                But if I declare the vector inside of the Output() method. It renders fine.
                                That seems pretty strange to me...😵
                                • H Offline
                                  Helper
                                  Your 2D checkerboard example doesn't work for me for some reason. The shader is all black.The other examples you posted work fine. But for some reason that one doesn't. And I'm trying to figure out why it isn't working correctly.
                                  I wrote that out of my memory and didn't test the code. There might be a bug in it.
                                  If I declare the vector (pointer or not) as a class member variable. Then use that vector in my Output() method. I get horrendous noise when rendering.But if I declare the vector inside of the Output() method. It renders fine.That seems pretty strange to me...
                                  The difference is that the Vector pointer in the Mandelbrot example is an array of vectors (see definition of GeAllocType() in the SDK docs).
                                  However, the reason for the noise is exactly the one I have already suspected and pointed out: Your are storing a color as a class member variable, and then all your render threads write to it and read from it simultaneuosly. That can't work, because the threads will overwrite each other's results.
                                  If you really want to store your result color in the class you will have to store it separately for each thread. But there's no reason for it, really. The only reason the Mandelbrot shader does it, is because it's calculating the colors before rendering; and then simply chooses (reads) from the colors during rendering process.
                                  • H Offline
                                    Helper
                                    On 20/04/2013 at 00:35, xxxxxxxx wrote:
                                    By the way, the checkerboard code works fine, here's a test render.
                                    I simply took the code and pasted it into the Output function of the mandelbrot shader.
                                    Of course, it's ugly because it does not yet take the MIP delta into account, but it's exactly what I have promised 🙂
                                    _<_img src="http://www.c4d-jack.de/darkside/checkerboard_test.jpg" border="0" /_>_
                                    The reason why the 2D shader preview in the Material Editor is black is: The shader preview is sampled from the UV space (0;0 to 1;1). Since we used a scale value of 0.2 and multiply p with it, the tiles ((p.x > 0.5) == (p.y > 0.5) creates black) are as big as 5 times the single UV space (0;0 to 5;5). Hence, the first black tile covers the entire preview area.
                                    Use a value of e.g. 2.0 instead and you'll see.
                                    • H Offline
                                      Helper
                                      On 20/04/2013 at 09:05, xxxxxxxx wrote:
                                      Thanks Frank,
                                      This is helping me a lot.
                                      • Q1 : How would I go about adding MIP delta to these shaders to make them look better?
                                      • Q2 : This is an example I made using the VolumeData method to create a checkerboard shader.
                                              But the problem is. It's in world coords. So the pattern doesn't stick to the object when it moves.
                                              How do I write this kind of VolumeData shader so that sticks to the object?
                                         Vector colors;
                                      if(cd->vd && enabled)     //"enabled" and "offset" are options in my code to control the pattern with gizmos
                                        Real r,s,t;
                                        Bool rs = cd->vd->GetRS(cd->vd->lhit,cd->vd->p,&r,&s);  //Use volume data to do the rendering
                                        Vector pos = cd->vd->p;
                                        if(pos.x < offset && pos.y > offset || pos.x > offset && pos.y < offset) colors = Vector(0,0,0);
                                        else colors = Vector(1,1,1);
                                        return colors;
                                      • H Offline
                                        Helper
                                        Check the cd->d values and use them to drive your level of detail. The smaller the values, the greater your detail should be. The exact value range depends on your shader and how you design it. Clamp the value into shape 🙂
                                        Especially for the checkerboard, you should read something about MIP mapping. You have to come up with a clever idea to blur the checkerboard. The greater the d values, the stronger the blur.
                                        With Noise-based shaders, I usually just reduce the noise octaves with increasing d values.
                                        Q2 : This is an example I made using the VolumeData method to create a checkerboard shader. But the problem is. It's in world coords. So the pattern doesn't stick to the object when it moves. How do I write this kind of VolumeData shader so that sticks to the object?
                                        You can use the inverse texture matrix cd->tex->im and multiply cd->vd->p with it. That should transform it into local space. Actually, the local texture space (controlled by the coordinates in the Texture Tag), which is what you want to use in Cinema.
                                        • H Offline
                                          Helper
                                          On 23/04/2013 at 08:55, xxxxxxxx wrote:
                                          I can't figure out how to use cd->d to do that.
                                          I also can't find anything resembling cd->tex->im in the SDK.
                                          I understand the theory about inverting a matrix to change global to local. I do that fairly often with mesh points.
                                          But I don't see how to write that code for VolumeData textures in the SDK.
                                          • H Offline
                                            Helper
                                            for the check board shader example you could blend the result color with the
                                            mixed vector of colA and colB with an increasing mip radius. distant points
                                            would become gray for a black / white check board which somewhat reflects
                                            the natural human perception of high contrast patterns.
                                            i would like to bring up again Modelling and Texturing : A Procedural Approach.
                                            a really good book, which is worth the money. all topics covered in this thread
                                            are described in the book (procedural patterns, various noise types / fractal
                                            noises, anti-aliasing, mip-mapping and much more).
