    changing Renderpath problem
    Scheduled Pinned Locked Moved PYTHON Development
    22 Posts 0 Posters 14.7k Views
    • H Offline
      Helper
      On 15/03/2013 at 01:15, xxxxxxxx wrote:
      Hey NiklasR,
      Here is what i belive to be a SSCCE:
      from c4d import gui, plugins, documents
      import os
      if __name__=='__main__':
            renderData = doc.GetActiveRenderData()
            xResolution = int(round(renderData[c4d.RDATA_XRES]))
            yResolution = int(round(renderData[c4d.RDATA_YRES]))
            pathChange = False
            if renderData[c4d.RDATA_PATH] != "":
                storedPath = renderData[c4d.RDATA_PATH]
                renderData[c4d.RDATA_PATH] =r'{0}_{1}'.format(renderData[c4d.RDATA_PATH], "extension")
                pathChange = True
            renderBmp = c4d.bitmaps.BaseBitmap()
            renderBmp.Init(x=xResolution, y=yResolution, depth=32, )
            result = documents.RenderDocument(doc, renderData.GetData(), renderBmp, c4d.RENDERFLAGS_EXTERNAL)
            if pathChange == True:
                renderData[c4d.RDATA_PATH] = storedPath
            if result==c4d.RENDERRESULT_OK:
                c4d.bitmaps.ShowBitmap(renderBmp)     # show image in pictureViewer
      Just create a new scene, save the renderoutput in some folder. If you run this script, the rendered file will actually be output to the folder. If you move the .GetData() to doc.GetActiveRenderData().GetData() and remove it from renderData.GetData(), theres no more file output.
      Aurel
      • H Offline
        Helper
        On 15/03/2013 at 06:21, xxxxxxxx wrote:
        Hi Amadeo,
        yes that is perfect, thanks.
        I'm also very confused, I can reproduce the behavior you describe. I don't see what is wrong
        in your code, mine works (see below). Anyway, you could still just save the image by hand. The
        script below is doing this as well so you will end up with two images when the Save parameter
        is checked in the render-data.
        import os
        def main() :
            rdata = doc.GetActiveRenderData().GetData()
         **    # rdata[c4d.RDATA_SAVEIMAGE] = False**
            xres = int(round(rdata[c4d.RDATA_XRES]))
            yres = int(round(rdata[c4d.RDATA_YRES]))
            path = rdata[c4d.RDATA_PATH]
            if not path:
                c4d.gui.MessageDialog("no save-path specified")
            dirname = os.path.dirname(path)
            if not os.path.exists(dirname) :
                os.makedirs(dirname)
            elif not os.path.isdir(dirname) :
                c4d.gui.MessageDialog("destination directory can not be created.")
            path = '%s_extension' % path
         **    # rdata[c4d.RDATA_PATH] = path**
            fileformat = rdata[c4d.RDATA_FORMAT]
            bmp = c4d.bitmaps.BaseBitmap()
            if bmp.Init(xres, yres, 32) != c4d.IMAGERESULT_OK:
                c4d.gui.MessageDialog("could not allocated bitmap for render.")
            result = c4d.documents.RenderDocument(doc, rdata, bmp, c4d.RENDERFLAGS_EXTERNAL)
            if result != c4d.RENDERRESULT_OK:
                c4d.gui.MessageDialog("rendering was not successful, see console.")
                print "rendering failed with error-code", result
            result = bmp.Save(path, fileformat)
            if result != c4d.IMAGERESULT_OK:
                c4d.gui.MessageDialog("rendered bitmap could not be saved, see console.")
                print "saving bitmap failed with error-code", result
        It seems to be the setting of the RDATA_PATH, because when you uncomment the red line,
        the RenderDocument() function does not save automatically anymore.
        Best,
        -Niklas
