    Basic plugin creation
    Scheduled Pinned Locked Moved PYTHON Development
    33 Posts 0 Posters 17.6k Views
    • H Offline
      Helper
      On 16/02/2013 at 09:03, xxxxxxxx wrote:
      ps: this feature is already implemented in c4d. the coords tab of an object node works that
      way.
      • H Offline
        Helper
        On 16/02/2013 at 09:12, xxxxxxxx wrote:
        Thank you, that keeps my motivation up 😉
        • H Offline
          Helper
          On 16/02/2013 at 09:13, xxxxxxxx wrote:
          way.
          Yeah, but just working on objects, not all the modes...
          • H Offline
            Helper
            On 21/02/2013 at 02:31, xxxxxxxx wrote:
            I´m studying this tutorial:
            http://www.smart-page.net/blog/2012/02/22/smart-hn-options-cinema-4d-python-commanddata-plugin-template/
            It works with some custom modules and to get a better understanding I rearanged and modified the code to be all in one single pyp file.
            I finally got it to work, but there a thing I still don´t understand.
            This starts the function  "work" when you press OK in the menu:
                    result = work(aEnabledState  = enableState,
                                           aSetEditor     = self.GetBool(MAINDIALOG_CHECK_SETEDITOR),
                                           aSetRender     = self.GetBool(MAINDIALOG_CHECK_SETRENDER),
                                           aEditor        = self.GetLong(MAINDIALOG_SLIDER_EDITOR),
                                           aRender        = self.GetLong(MAINDIALOG_SLIDER_RENDER),
                                           aInc           = self.GetBool(MAINDIALOG_CHECK_INC))
            which looks like this:
            def work(aEnabledState = 0, aSetEditor = False, aSetRender = False, aEditor = 2, aRender = 3, aInc = False)
              doc = c4d.documents.Get......
              return result
            It works like that, but when I put the "work" function in a class (Worker) and update the result to Worker.work:
            result = Worker.work(aEnabled....
            I get this message for this line:
            "TypeError: unbound method work() must be called with Worker instance as first argument (got nothing instead)"
            What does it mean, and what did I do wrong calling the function from the class?
            Google couldn´t help me much 😉
            • H Offline
              Helper
              On 21/02/2013 at 05:04, xxxxxxxx wrote:
              Keep it the way you have it:
              Make the method a staticmethod. (google)
              Or make it an instance method:
              1. Add the self parameter for the Worker.work() function.
              2. Create an instance of the Worker class and call work() on it.
              • H Offline
                Helper
                On 22/02/2013 at 04:17, xxxxxxxx wrote:
                Thanks.
                I did a little Gui-Plugin, with a spinner, where the x position is read by CoreMessage and written back by Commmand.  Just  one thing I can´t figure out, the changes get updated in the viewport only after leaving the spinner, although the print command constantly updates:
                    def Command(self, id, msg) :
                          c4d.StopAllThreads()
                          if id == IDC_POS:
                              obj = c4d.documents.GetActiveDocument().GetActiveObject()
                              x_value = self.GetReal(IDC_POS)
                              obj_pos_y = obj.GetAbsPos().y
                              obj_pos_z = obj.GetAbsPos().z
                              obj.SetAbsPos(c4d.Vector(x_value, obj_pos_y, obj_pos_z))
                              print x_value
                • H Offline
                  Helper
                  On 22/02/2013 at 04:37, xxxxxxxx wrote:
                  1. What "spinner"?
                  2. Make your life easier:
                  pos = obj.GetAbsPos()
                  pos.x = x_value
                  obj.SetAbsPos(pos)
                  -Nik
                  • H Offline
                    Helper
                    On 22/02/2013 at 04:45, xxxxxxxx wrote:
                    Much easier 😉
                    Spinner might be 3ds terminology, I refer to the up/down arrows next to my number edit box, which control X Position...
                    • H Offline
                      Helper
                      On 22/02/2013 at 06:19, xxxxxxxx wrote:
                      1. I'm not sure what you're doing in the CoreMessage(), it shouldn't be necessary to override this method.
                      2. You need to redraw the editor, c4d.EventAdd() just tells Cinema that something happened and a redraw will be necessary the next time Cinema would normally decide whether to redraw or not. To invoke a redraw immediately, use c4d.DrawViews().
                      See c4dtools.utils.update_editor() for an example call: https://github.com/NiklasRosenstein/c4dtools/blob/master/c4dtools/utils.py#L161-L163
                      -Nik
                      • H Offline
                        Helper
                        On 23/02/2013 at 02:30, xxxxxxxx wrote:
                        Thank you again, Core Message was just unnecessary information without real context here...
                        I hope I don´t become annoying, flooding beginner questions 😉
                        Now I am in a dead end again:
                        A right-click on the arrows of a Number Box setting a specific value.
                        I guess it´s done by using the GeDialog.Command msg:
                        http://www.thirdpartyplugins.com/python_r14/modules/c4d.gui/GeDialog/index.html?highlight=command#GeDialog.Command
                        Or maybe with GetInputState? Tried that too, though...
                        But doesn´t matter what, nothing seems to work.
                        Best thing I achieved was to show in console, that there are some changes in the msg Container:
                        left click:
                        print msg
                        <c4d.BaseContainer object at 0x00000000188ACCA8>
                        msg.GetDirty()
                        for x in xrange(0, 5) :
                           print x
                           print msg.GetIndexId(x)
                        0
                        1835362660
                        right click:
                        print msg
                        msg.GetDirty()
                           print x
                        0
                        1835362660
                        But what now, working with some strange IDs is surely not the way to do this?
                        I was hoping for something like this:
                            if id == IDC_POS and msg.BFM_ACTION_DP_MENUCLICK == True:
                        which obviously, isn´t the way to go 😕
                        • H Offline
                          Helper
                          On 23/02/2013 at 03:52, xxxxxxxx wrote:
                          It works like this, but, as I said, that´s surely not the way to do so?
                          if id == IDC_POS and msg.GetIndexId(2) == 1634887027:
                          I mean what would this msg information be good for then?
                          BFM_ACTION_DP_MENUCLICK bool Right mouse button.
                          BFM_ACTION_DP_ADDSELECT bool Shift.
                          BFM_ACTION_DP_SUBSELECT bool Control.
                          BFM_ACTION_DP_FOCUS bool Focus.
                          BFM_ACTION_DP_ANIMCLICK bool Animation click.
                          BFM_ACTION_DP_BUTTONCLICK bool Double left mouse button click.
                          BFM_ACTION_QUAL int Qualifier.
                          _<_t_>_
                          • H Offline
                            Helper
                            On 25/02/2013 at 04:16, xxxxxxxx wrote:
                            Ok, I found a solution by GetInputState:
                            self.GetInputState(c4d.BFM_INPUT_MOUSE, c4d.BFM_INPUT_MOUSERIGHT, msg)
                            if id == IDC_POS and msg[c4d.BFM_INPUT_VALUE] == True:
                            Now I am trying to get a value offset in my dialogue:
                            I´ve got two Number fields an if I change the first by mouse drag, the other one should show the value offset.
                            The thing is I don´t know how to store the inital value while mousedragging.
                            IDC_POS being the first field, OFFSET the second showing the offset.
                            Right now (base_value - x_value) keeps being zero, because the  base_value gets changed while dragging too 😕
                                  base_value = obj.GetAbsPos().x
                                  if id == IDC_POS:
                                      if obj:
                                          self.SetReal(OFFSET, base_value - x_value, -10000000, 10000000, 1, c4d.FORMAT_METER)
                                          pos.x = x_value
                                          obj.SetAbsPos(pos)
                                          c4d.DrawViews()
                            So how can I get&store the base value, when mouse dragging starts?
                            • H Offline
                              Helper
                              On 25/02/2013 at 05:23, xxxxxxxx wrote:
                              Ok, got that too 😉
                              Using "base_value = self.GetReal(IDC_POS)" as a global Variable from within CoreMessage does the job. Although I was told not to mess with global variables as a beginner, that seems like a good solution...
                              Thanks for listening to me monologing 🙂
