    EventAdd() doesn't update C4D
    Scheduled Pinned Locked Moved PYTHON Development
    25 Posts 0 Posters 21.5k Views
    • H Offline
      Helper
      On 08/02/2013 at 06:19, xxxxxxxx wrote:
      You can also just automate the process of putting them under a null-object, run what the script
      currently does on the null-object (but with taking its children into account) and unpack the null-object
      again. Still better then redrawing the editor for each pass.
      If you don't want that workaround, you could also manage to offset the objects aiming for seperately,
      but this would be more code to write and less perfomant (because of Pythons slow iterations).
      • H Offline
        Helper
        On 08/02/2013 at 08:30, xxxxxxxx wrote:
        Originally posted by xxxxxxxx
        @Scott: You said, that scripts should not be used for this and that I should use a plugin instead. I'm quite open to that but I'm not really sure what the significant changes regarding your code will be. Can I use a complete new (and simpler) approach when using PlugIns? If so, what will it look like? I'm sorry if you had this question already answered, but I still have problems with that.
        A plugin or pytag is just the usual choice for this kind of thing. Because they can execute their code several times. Not just once.
        It's often an advantage to have this ability so you can compare things->move them->compare them again.
        Most people would probably use a plugin or a pytag for this task you're doing. And take advantage of that running several times thing to do a task like multiple comparisons and moves.
        But Niklas found a way to do this using a script that's just a s good as using a plugin or a pytag.
        Normally this kind of task isn't done with a script due to it's run once nature.
        But people who are clever (like Niklas) can often figure out a way to get around that problem.
        • H Offline
          Helper
          On 12/02/2013 at 02:13, xxxxxxxx wrote:
          Hey guys!
          Thanks for your replies!
          I did some calculations the last days and it took me quite a while, because I got really confused about that many coordinate systems and matrices and vectors...
          Anyways, I managed to get a working code which did the repositioning of my camera in one calculation, without Redrawing or moving objects. It works pretty fine as long as the camera aims directly to the midpoint of the object (need to add an offset to the midpoint to the calculation) and the object is in front of the camera (not necessarily completly). So there is room for improvements 😉
          Created on 12.02.2013
          from c4d import documents
          import math
          def GetNewCameraPosition(cam, obj, doc) :
            bd = doc.GetActiveBaseDraw()
            safeFrame = bd.GetSafeFrame()
            #Get the active object bounding box center and radius, including midpoint as last point
            box = [c4d.Vector() for x in xrange(9)]
            points = [c4d.Vector() for x in xrange(9)]
            rd = obj.GetRad()
            mp = obj.GetMp()
            #Build the active object bounding box
            box[0].x = mp.x - rd.x
            box[0].y = mp.y - rd.y
            box[0].z = mp.z - rd.z
            box[0] *= obj.GetMgn()
            box[1].x = mp.x - rd.x
            box[1].y = mp.y + rd.y
            box[1].z = mp.z - rd.z
            box[1] *= obj.GetMgn()
            box[2].x = mp.x + rd.x
            box[2].y = mp.y - rd.y
            box[2].z = mp.z - rd.z
            box[2] *= obj.GetMgn()
            box[3].x = mp.x + rd.x
            box[3].y = mp.y + rd.y
            box[3].z = mp.z - rd.z
            box[3] *= obj.GetMgn()
            box[4].x = mp.x + rd.x
            box[4].y = mp.y - rd.y
            box[4].z = mp.z + rd.z
            box[4] *= obj.GetMgn()
            box[5].x = mp.x + rd.x
            box[5].y = mp.y + rd.y
            box[5].z = mp.z + rd.z
            box[5] *= obj.GetMgn()
            box[6].x = mp.x - rd.x
            box[6].y = mp.y - rd.y
            box[6].z = mp.z + rd.z
            box[6] *= obj.GetMgn()
            box[7].x = mp.x - rd.x
            box[7].y = mp.y + rd.y
            box[7].z = mp.z + rd.z
            box[7] *= obj.GetMgn()
            box[8].x = mp.x
            box[8].y = mp.y
            box[8].z = mp.z
            box[8] *= obj.GetMgn()
            #convert bounding box points to Screenspace
            for i in xrange(len(box)) :
                points[i] = bd.WS(box[i])
            #looking for extreme points
            minXIndex = maxXIndex = minYIndex = maxYIndex = minZIndex = maxZIndex = 0
            minX = maxX = points[minXIndex][0]
            minY = maxY = points[minYIndex][1]
            minZ = maxZ = points[minZIndex][2]
            for i in xrange(1, len(points) - 1) : #-1: Midpoint can never be an extreme point
                if points[i][0] < minX:
                    minX = points[i][0]
                    minXIndex = i
                if points[i][0] > maxX:
                    maxX = points[i][0]
                    maxXIndex = i
                if points[i][1] < minY:
                    minY = points[i][1]
                    minYIndex = i
                if points[i][1] > maxY:
                    maxY = points[i][1]
                    maxYIndex = i
                if points[i][2] < minZ:
                    minZ = points[i][2]
                    minZIndex = i
                if points[i][2] > maxZ:
                    maxZ = points[i][2]
                    maxZIndex = i
            #if a pair of indices is equal than a calculation can't be done
            if (minXIndex == maxXIndex) or (minYIndex == maxYIndex) or (minZIndex == maxZIndex) :
                print 'At least one pair of indices are equal: minX {0}, maxX {1}, minY {2}, maxY {3}, minZ {4}, maxZ {5}\nAborting function'.format(minXIndex, maxXIndex, minYIndex, maxYIndex, minZIndex, maxZIndex)
                return cam.GetMg().off
            #calculate offset from midpoint to nearest extreme point in z direction in sight of cam
            if points[minXIndex][2] <= points[maxXIndex][2]:
                offsetX = math.fabs(points[8][2] - points[minXIndex][2])
                offsetX = math.fabs(points[8][2] - points[maxXIndex][2])
            if points[minYIndex][2] <= points[maxYIndex][2]:
                offsetY = math.fabs(points[8][2] - points[minYIndex][2])
                offsetY = math.fabs(points[8][2] - points[maxYIndex][2])
            #calculate necessary distance between camera and extreme point
            fd_x = ((box[maxXIndex] - box[minXIndex]).GetLength() / 2.0) / math.tan(cam[c4d.CAMERAOBJECT_FOV] / 2)
            fd_y = ((box[maxYIndex] - box[minYIndex]).GetLength() / 2.0) / math.tan(cam[c4d.CAMERAOBJECT_FOV_VERTICAL] / 2)
            #add the corresponding offset
            fd_x += offsetX
            fd_y += offsetY
            #check if calculation went wrong (camera distance can't be negative),
            # set the focus distance to distance to midpoint of bounding box
            if fd_x > fd_y:
                if fd_x <= 0:
                    print 'fd_x smaller than 0'
                cam[c4d.CAMERAOBJECT_TARGETDISTANCE] = fd_x
                if fd_y <= 0:
                    print 'fd_y smaller than 0'
                cam[c4d.CAMERAOBJECT_TARGETDISTANCE] = fd_y
            #calculate the new camera position
            camMg = cam.GetMg()
            camMgOff = obj.GetMg().off
            camMgOff += camMg.v3.__neg__() * cam[c4d.CAMERAOBJECT_TARGETDISTANCE] #repositioning in negative z-axis
            return camMgOff
          def main() :
            doc = documents.GetActiveDocument()
            cam = doc.SearchObject('Cam')
            cube = doc.SearchObject('Cube')
            camMg = cam.GetMg()
            camMg.off = GetNewCameraPosition(cam, cube, doc)
            cam.SetMg(camMg)
          Any recommandations on this code would be appreciated!
          Greetings Nachtmahr
          • H Offline
            Helper
            How do i do that ?
            I am itterating through all objects at the moment and the result is the camera moves away way too far. (some cubes dimenson 200m camera moves to 246666m)
            I need to have my Null-Object with lots of objects inside to be full inside the rendersave frame. Is it posible to get a boundingbox from a Null-Object with its children taken into acount without iterationg through several thousand objects ?
            thanks in advance.
            • H Offline
              Helper
              On 27/06/2015 at 10:21, xxxxxxxx wrote:
              So I managed to add Niklas aabb Boundingbox Routine to your script but I am still getting weird results.
              sometimes nothing happens, passes = 0 even when something is not in view,
              sometimes it works kind of but the object is way to small in the midle,
              sometimes it runs forever in a loop
              can we get this as neat and tidy and better working than this "H"-Key in C4D?
              kind regrads mogh
              # Added Niklas Rosenstein AABB Utility to get the boundingbox of a Null-Object with its Children
              # please note that you have to install it
              # http://pythonhosted.org/c4dtools/
              # https://github.com/NiklasRosenstein/c4dtools <- download from here
              from c4d import utils
              import c4dtools.misc.aabb as aabb
              def TestPointInFrame(pt, frame) :
                  return pt.x > frame['cl'] and pt.x < frame['cr'] and \
                         pt.y > frame['ct'] and pt.y < frame['cb']
              #def CheckIfInView(obj, bd) :
              def CheckIfInView(obj, rd, mp, bd) :
                  box = [c4d.Vector() for x in xrange(8)]
                  #rd = obj.GetRad()
                  #mp = obj.GetMp()
                  #print box, rd, mp
                  #Build the active object bouding box
                  box[1].z = mp.y - rd.z
                  box[2].z = mp.y - rd.z
                  box[3].z = mp.y - rd.z
                  box[5].z = mp.y + rd.z
                  box[6].z = mp.y + rd.z
                  box[7].z = mp.y + rd.z
                  #Calculate bouding box coordinates in screen space
                  points = [bd.WS(p) for p in box]
                  #Test if the current object is completely visible in the rendered safe frame
                  for i in xrange(len(points)) :
                      if not TestPointInFrame(points[i], safeFrame) :
                          return False
              def MoveObjectRel(op, axis, offset) :
                  axis = axis.GetNormalized()
                  axis.off = op.GetRelPos()
                  op.SetRelPos(axis * offset)
              def EscapePressed(bc=None) :
                  if bc is None:
                      bc = c4d.BaseContainer()
                      c4d.gui.GetInputEvent(c4d.BFM_INPUT_KEYBOARD, bc)
                  return bc[c4d.BFM_INPUT_CHANNEL] == c4d.KEY_ESC
              def main() :
                  c4d.CallCommand(13957) # Konsole löschen
                  if not op:
                      c4d.gui.MessageDialog("please select an object")
                  cam = bd.GetSceneCamera(doc)
                  if op is cam:
                      return MessageDialog("can not apply on the cam")
                  campos = cam.GetAbsPos()
                  pos = op.GetAbsPos()
                  axis = cam.GetMg()
                  offset = c4d.Vector(0, 0, 10)
                  # Create an undo-state for the camera because we will offset it.
                  doc.AddUndo(c4d.UNDOTYPE_CHANGE, cam)
                  c4d.StatusSetSpin()
                  passes = 0
                  oppasses = 0
                  stopped = False
                  box = aabb.AABB()
                  box.expand_object(op, recursive=True)
                  print "AABB Values:"
                  print "Size: ", box.size
                  print "Midpoint: ", box.midpoint
                  mp = box.midpoint
                  rd = box.size
                  #while not CheckIfInView(op, bd) :
                  while not CheckIfInView(op, rd, mp, bd) : # pass aabb values to check routine
                      stopped = EscapePressed()
                      if stopped: break
                      oppasses += 1
                  print "Check in view passes: ", oppasses
                  delta = op.GetAbsPos() - pos
                  op.SetAbsPos(pos)
                  if not stopped:
                      campos -= delta
                  cam.SetAbsPos(campos)
                  c4d.StatusClear()
