    Snap object in mouse input
    Scheduled Pinned Locked Moved PYTHON Development
    25 Posts 0 Posters 18.6k Views
    • H Offline
      Helper
      On 12/01/2013 at 14:28, xxxxxxxx wrote:
      Originally posted by xxxxxxxx
      or you have to make an instance of your GeDialog class a memeber of your
      ToolData class.
      class ToolDataClass() :
          def __init__(self) :
              self.dialog = None
              self.data = None
          def doSomething(self) :
              if (self.dialog) :
                  print self.Dialog.linkBox.GetLink(document, c4d.Obase)
                  print 'dialog has not been raised yet.'
          def AllocSubDialog(self, bc) :
              self.Dialog = SettingsDialog(self.data)
              return self.Dialog
      edit : fixed a typo,  should be if (self.dialog) : of course and not if(self.data) :
      Work!!! I succeeded! littledevil Thanks!!!!!!! 🤝
      • H Offline
        Helper
        You need to use the c4d.utils.GeRayCollider class to find an intersection on the surface of the
        destination-object, intersected by the line defined by the mouse-position in global space and
        the camera position.
        op = doc.GetActiveObject()
              op_next = op.GetNext()
              if not op_next:
        # Convert op_next to a polygon object.
              # Simplified here, just for demonstration purpose.
              op_next = op_next.GetCache()
              if not op_next or not op_next.CheckType(c4d.Opolygon) :
                  print "Cache is not existent or is not a polygon object."
              win.MouseDragStart(button=device, mx=int(mx), my=int(my), flags=c4d.MOUSEDRAGFLAGS_DONTHIDEMOUSE)
              result, dx, dy, channel = win.MouseDrag()
              while result==c4d.MOUSEDRAGRESULT_CONTINUE:
                  mx += dx
                  my += dy
                  cursorpos = bd.SW(c4d.Vector(mx,my,500))     #screen to world conversion
                  if(axis == 1) :
                      cursorpos.x = 0
                  elif(axis == 2) :
                      cursorpos.y = 0                          #Constrain drawing along an axis based on the comboButton's value
                  elif(axis == 3) :
                      cursorpos.z = 0
        cam_pos = bd.GetSceneCamera(doc).GetAbsPos()
                  collider = c4d.utils.GeRayCollider()
                  collider.Init(op_next)
        length = 500000
                  direction = -(cam_pos - cursorpos).GetNormalized()
        did_intersect = collider.Intersect(cam_pos, direction, length)
                  if did_intersect:
                      position = collider.GetNearestIntersection()['hitpos']
                      print "Intersection at", position
                      print "No intersection."
                      position = cursorpos
        doc.AddUndo(c4d.UNDOTYPE_CHANGE, op)
                  op.SetAbsPos(position)
                  op.Message(c4d.MSG_UPDATE)
        c4d.DrawViews(c4d.DA_ONLY_ACTIVE_VIEW|c4d.DA_NO_THREAD|c4d.DA_NO_ANIMATION)
        -Nik
        an example for snap on point object? thanks 🙂
        • H Offline
          Helper
          What do you mean with "the snap does not work"? You are not even trying to snap the
          object, just setting it to the cursor position.
          joint.SetAbsPos(cursorpos)
          If you want to to snap to a grid with a spacing of 50 units (just for the sake of example), you
          need to adjust the position vector.
          def snap_value(value, step) :
                rest = value % step
                on_grid = value - rest
          if rest / float(step) >= 0.5:
                    on_grid += step
          return on_grid
          def snap_grid(vector, gridsize) :
                vector = c4d.Vector(vector)
                vector.x = snap_value(vector.x, gridsize)
                vector.y = snap_value(vector.y, gridsize)
                vector.z = snap_value(vector.z, gridsize)
                return vector
          gridsize = 50
            position = snap_grid(cursorpos)
            joint.SetAbsPos(position)
          See the full code here.
          -Niklas
          HI NiklasR How do you adjust the cursor position for snap points ? 🙂
          • H Offline
            Helper
            Assuming you have a coordinate in 3D space, you can just use the nearest mesh point and maybe
            check if the point is within the snap radius.
                def snap_point(point, radius, obj) :
                    Calculate the snapping point from a coordinate in 3D space
                    to a point object within the defined \*radius\*. Requires
                    the \*point\* in global space.
                    mg = obj.GetMg()
                    points = obj.GetAllPoints()
                    point = ~mg \* point
                    radius \*\*= 2
                    nearest = None
                    for p in points:
                        delta = (p - point).GetLengthSquared()
                        if delta <= radius and (not nearest or nearest[1] > delta) :
                            nearest = p, delta
                    if nearest:
                        point = nearest[0]
                    return point
                def main() :
                    p = c4d.Vector(102, 99, 97)
                    print snap_point(p, 10, op)
            Best regards,
            -Niklas
            • H Offline
              Helper
              You can not "adjust" the cursor position, the cursor is where the mouse points it to. There is also
              a snapping mode for snapping to object points, so what exactly do you need?
              -Niklas
