    Null object dimensions
    25 Posts 0 Posters 14.8k Views
    • H Offline
      Helper
      On 14/09/2012 at 08:15, xxxxxxxx wrote:
      Hei folks,
      in case someone needs it: Here's the working version of the above scene-file using Giblets method (but using GetRad()/GetMp() only!!)
      -Niklas
      • H Offline
        Helper
        On 14/09/2012 at 11:46, xxxxxxxx wrote:
        Thanks - it's neat seeing it (working and) ported to Python :). Did you try the full object point-transform method?
        • H Offline
          Helper
          Do you mean calculating the bounding-box of point-objects from its points? No. Because,
          1. I'm pretty sure GetDimension() does this internally for polygon-objects.
          2. For splines, the curves could exceed the bounding box defined only by the points.
          -Nik
          • H Offline
            Helper
            On 14/09/2012 at 13:17, xxxxxxxx wrote:
            Originally posted by xxxxxxxx
            ...1. I'm pretty sure GetDimension() does this internally for polygon-objects.
            Hmm...
            • Load your scene, delete the 2 cubes.
            • Add a "Tube" object.
            • Switch to Front view.
            • Rotate the Tube 30deg or so clockwise.
            • Make it editable (turn it into a Polygon Object).
            • Grab a point and (in Move mode), pull the point up (at that angle).
            • Observe that the top of the BBox is no longer 'tight' on the object (across the top/right sides).
              ...doing the point-transform method would tighten that box back up (if you needed that).
            • H Offline
              Helper
              On 26/06/2015 at 01:43, xxxxxxxx wrote:
              Oh i think this would solve my problem with this
              https://developers.maxon.net/forum/topic/6903/7745_eventadd-doesnt-update-c4d
              Not the topic the solution from NiklasR, but The Python c4d file is 404 missing, here.
              Anyhow does somebody have a multiple objects boundingbox Python Script Snippet?
              Kind regards
              mogh
