    Create a bitmap and drawing in it?
    28 Posts 0 Posters 17.2k Views
    • H Offline
      Helper
      On 30/04/2012 at 08:26, xxxxxxxx wrote:
      It won't let me do this: bmp = gcm- >GetBitmap(); //error: cannot access private member  AutoAlloc()
      • H Offline
        Helper
        On 30/04/2012 at 08:40, xxxxxxxx wrote:
        Sorry, this is because bmp was already allocated with AutoAlloc(). We have to declare a new BaseBitmap variable to hold the modified bitmap:
        BaseBitmap *clipBmp = gcm->GetBitmap();
        • H Offline
          Helper
          On 30/04/2012 at 09:16, xxxxxxxx wrote:
          Sorry about that. I should have mentioned that I already tried assigning it to a new BaseBitmap variable like that.
          The code you posted still produces a rectangle full of lines. And not the correct color for the FillRect().
          An interesting thing to note is I got this same type of bad result when using SetPixelCnt() with the wrong buffer settings.
          • H Offline
            Helper
            On 30/04/2012 at 09:34, xxxxxxxx wrote:
            Here is the code that works for me:
            Filename fn = GeGetC4DPath(C4D_PATH_DESKTOP)+"myimage.jpg"; //Get the path to an image
            AutoAlloc<GeClipMap> gcm;        //Create an instance of the GeClipMap class
            gcm->Init(fn,0,0);               //Initialise it using the image in our path
            gcm->BeginDraw();
                gcm->SetColor(255L,255L,255L);      //Set the color to white
                gcm->FillRect(50L,50L,100L,100L);   //Create a filled rectangle area
            gcm->EndDraw();
            ShowBitmap(gcm->GetBitmap());           //Show the drawn bitmap
            • H Offline
              Helper
              On 30/04/2012 at 10:05, xxxxxxxx wrote:
              Now you've got it. 👍
              Here's my little addition to it that will also save the image as well as show it in the picture viewer:
                gcm->BeginDraw();
                gcm->EndDraw();
                ShowBitmap(gcm->GetBitmap());       //Show the drawn bitmap in the picture viewer
                BaseBitmap *clipBmp = gcm->GetBitmap();                         //Get the modified bitmap from GeClipMap
                Filename newfn = GeGetC4DPath(C4D_PATH_DESKTOP)+"newimage.jpg"; //Create a path to save our new image
                clipBmp->Save(Filename(newfn),FILTER_JPG,NULL,SAVEBIT_0);       //Save the new image
              Please don't kill me. 😉
              But could you possibly show me how to write the PolyLine code?
              It requires a GE_POINT2D struct pointer. And I can't figure out how to write that part.
              • H Offline
                Helper
                On 30/04/2012 at 12:20, xxxxxxxx wrote:
                I've tried a whole bunch of different things. But I just can't get the struct to work.
                Example#1
                    GE_POINT2D *points;       //<--Error. Variable is not initialized!!
                                            //Setting it to NULL doesn't work
                  LONG x = points->x = 5;
                  LONG y = points->y = 25;
                  gcm->PolyLine(20, points);
                Example#2
                Accessing the struct directly without pointers crashes C4D
                    GE_POINT2D points;
                  LONG x = points.x = 5;
                  LONG y = points.y = 25;
                  gcm->PolyLine(20, &points);
                Can anyone tell me how to do this?
                I've got all the parts and pieces. But I just can't make C4D happy.
                • H Offline
                  Helper
                  On 30/04/2012 at 15:04, xxxxxxxx wrote:
                  You have to initialize an array of struct (GE_POINT2D in this case) :
                  GE_POINT2D points[] =       //Define an array of GE_POINT2D
                      {200L,200L},      //x = 200L, y = 200L
                      {250L,250L},      //etc.
                      {200L,300L}
                  gcm->PolyLine(3, points);    //Draw the polyline with the given 3 points
                  This is a bit tricky at the beginning 🙂.
                  • H Offline
                    Helper
                    On 30/04/2012 at 15:34, xxxxxxxx wrote:
                    Wonderful.
                    I think I've got everything I need now.
                    If not... too bad. Because I've bothered you enough about this. 😂
                    Thanks a lot.
                    You've really helped me (and probably many others) out a great deal with this.🍺
