    Fractal surface
    40 Posts 0 Posters 27.7k Views
    • H Offline
      Helper
      On 05/06/2010 at 21:38, xxxxxxxx wrote:
      Hey Jack,
      So I have successfully created an object and am using noise functions to alter the look of the object.
      Here is the code I am using.
      Real arr[20];
      	InitFbm(arr,20,7,0.5);
      	for (int i = 0; i < pointCount; i++)
      		Real rmf = RidgedMultifractal(arr, points[i], octaves, offset, gain) * .8;
      		Real turb = Turbulence(points[i],octaves, abs) * .8;
      		Real wavturb = WavyTurbulence(points[i],time, octaves, 1) * .8;
      		Real noise = Noise(points[i]) * .8;
      		//RIDGED MULTIFRACTAL
      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_RIDGEDMULTIFRACTAL)
      			points[i] = Mix(points[i] * rmf, points[i], amt);
      		//Turbulence
      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_TURBULENCE)
      			points[i] = Mix(points[i] * turb, points[i], amt);
      		//Wavy Turbulence
      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_WAVY_TURBULENCE)
      			points[i] = Mix(points[i] * wavturb, points[i], amt);
      		//Noise
      		if (bc->GetLong(SPACEROCK_NOISE_TYPE) == SPACEROCK_NOISE)
      			points[i] = Mix(points[i] * noise, points[i], amt);
      	//SUBDIVISION
      		Real subAmount = bc->GetReal(SPACEROCK_SUBDIVISIONS);
      		bc2.SetBool(MDATA_SUBDIVIDE_HYPER, TRUE);
      		bc2.SetLong(MDATA_SUBDIVIDE_SUB, subAmount);
      		bc2.SetReal(MDATA_SUBDIVIDE_ANGLE, pi);
      		mcd2.bc = &bc2;
      		mcd2.op = polyCube;
      		mcd2.mode = MODIFY_ALL;
      		mcd2.doc = hh->GetDocument();
      		if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2))
      			GePrint("done");
      		else
      			GePrint("failed");
      My results are okay but I would like to get a more detailed and fine noise look.  Do you have any tips on how to improve the way I am affecting the object with the noise functions.  This is how my object looks right now with noise applied.
      • H Offline
        Helper
        On 06/06/2010 at 10:57, xxxxxxxx wrote:
        well, i guess you first need to create more faces to get more details. than you could apply more layers of noise at different scales and coordinates..  or you  simply add the detail using a nice mix of noises in the relief channel
        cheers,
        Ello
        • H Offline
          Helper
          On 06/06/2010 at 11:04, xxxxxxxx wrote:
          Hi ello,
          even when I subdivide the rock the noise still follows this broad pattern.  as if it's not fully affecting each point.  I would like the ripples and bumps to be on a smaller scale.     Hopefully that makes sense.
          Can you provide an example of layering the noise functions?  I have tried to do this but don't seem to be getting success.
          ~Shawn
          • H Offline
            Helper
            On 06/06/2010 at 11:08, xxxxxxxx wrote:
            does using the subdivide command actually add more polygons to the image?
            • H Offline
              Helper
              On 06/06/2010 at 19:50, xxxxxxxx wrote:
              okay so I'm getting some good results now but I want to add some bulges throughout the rock.   Take a look at this image.
              you can see that this particular spacerock is a bit too perfect.  I want to use the noise functions to create som random buldges to the overall shape of the rock.  Is it possible to apply noise to the whole rock?   Does anyone have any thoughts on how I could accomplish these random bulges?
              Would it work to create a random function and then iterate through the rock's points again and only apply noise to random points this time?
              Thanks in advance.
              ~Shawn
              • H Offline
                Helper
                On 06/06/2010 at 21:46, xxxxxxxx wrote:
                you could use another noise and do something like if (noise>0.8) add certain ammount to point offset
                plus, you should add different results to the x, y and z part of the points.. like
                                  Real rmf1 = RidgedMultifractal(arr, 1 + points[i]*factor.x, 20, 0, 1)*strength.x;
                                  Real rmf2 = RidgedMultifractal(arr, 2 + points[i]*factor.y, 20, 0, 1)*strength.y;
                                  Real rmf3 = RidgedMultifractal(arr, 3 + points[i]*factor.z, 20, 0, 1)*strength.z;
                                  points[i] += Vector(rmf1,rmf2,rmf3);
                hope this helps
                edit: plus you really should use bools for the noise types so to make a mix off all of them 🙂
                • H Offline
                  Helper
                  On 07/06/2010 at 05:14, xxxxxxxx wrote:
                  I'm not sure what you mean by factor.x is factor a vector?   and is strength a vector?   or should the .x .y and .z be on the points _?
                  Thanks,
                  ~Shawn
                  • H Offline
                    Helper
                    On 07/06/2010 at 05:30, xxxxxxxx wrote:
                    those are vectors you can let the user change, to adjust the size (factor) and the strength of the noise..
                    btw, i could think that it would be a good idea to take the normal direction into account. i'd share my normal calculation code with you, but its only for faces and point normals are not really working.
                    • H Offline
                      Helper
                      On 08/06/2010 at 17:56, xxxxxxxx wrote:
                      can someone provide me an example of layering noise functions.  many resources mention that it is important to layer noise functions.  I am not entirely sure what is exactly meant by that.  Could someone elaborate?
                      Thanks,
                      ~Shawn
                      • H Offline
                        Helper
                        On 08/06/2010 at 21:42, xxxxxxxx wrote:
                        there are many ways how you can mix some noises. for example:
                        Vector someNoise = 0;
                        someNoise.x = RidgedMultifractal(arr, 1 + points[i]*factor.x, 20, 0, 1)*strength.x;
                        someNoise.y = RidgedMultifractal(arr, 2 + points[i]*factor.y, 20, 0, 1)*strength.y;
                        someNoise.z = RidgedMultifractal(arr, 3 + points[i]*factor.z, 20, 0, 1)*strength.z;
                        Vector anotherNoise = 0;
                        anotherNoise.x = Turbulence(points[i]*anotherFactor.x,20, false) * anotherStrength.x; anotherNoise.y = Turbulence(points[i]*anotherFactor.y,20, false) * anotherStrength.y; anotherNoise.z = Turbulence(points[i]*anotherFactor.z,20, false) * anotherStrength.z;
                        Vector myNoise = Mix (someNoise,anotherNoise,mix);
                        where mix is a user value or jet another noise...
                        or you could multiply
                        Vector myNoise = someNoise * anotherNoise;
                        or add
                        Vector myNoise = someNoise + anotherNoise;
                        or just try anything out.. there are just too many things you can do 🙂
                        hope it helps..
                        • H Offline
                          Helper
                          On 09/06/2010 at 15:51, xxxxxxxx wrote:
                          Okay that's easy enough.,. thanks a lot. ello!
                          ~Shawn
                          • H Offline
                            Helper
                            On 11/06/2010 at 04:16, xxxxxxxx wrote:
                            Originally posted by xxxxxxxx
                            ..btw, i could think that it would be a good idea to take the normal direction into account. i'd share my normal calculation code with you, but its only for faces and point normals are not really working.
                            As an aside, here is some Normal info...
                            For faces, you can simply do:
                                 Vector *padr = ToPoly(op)->GetPointW();
                                 CPolygon *polys = ToPoly(op)->GetPolygonW();
                                 Vector vNorm = CalcFaceNormal(padr, polys[poly_of_interest]);
                            For Point Normals, I created a helper structure, similar to how the UVWStruct is used...
                            struct NormalStruct
                                 NormalStruct(_DONTCONSTRUCT dc) : a(DC), b(DC), c(DC), d(DC) { }
                                 NormalStruct(void) {}
                                 NormalStruct(const Vector &t;_a, const Vector &t;_b, const Vector &t;_c, const Vector &t;_d) { a=t_a; b=t_b; c=t_c; d=t_d; }
                                 NormalStruct(const Vector &t;_a, const Vector &t;_b, const Vector &t;_c) { a=t_a; b=t_b; c=t_c; }
                                 Vector a,b,c,d;
                            ...for Point Normals, you want "a normal for every vertex/point of every polygon" (ie. not just one per point) - this allows for Phong Edge-Breaks in the shading. So, assuming that the mesh _has_ a Phong Tag, you can just do:
                                 NormalStruct *pNorms = (NormalStruct * )ToPoly(op)->CreatePhongNormals();
                            ...the CreatePhongNormals() routine will return a pointer to an array of Point Normals - **4** normals for every polygon in the mesh (just like the UVW Tag returns 4 uv coordinates per polygon). This is the same as the NormalStruct I list above, so you can use that structure to access the (a,b,c,d) normals.
                            If the mesh doesn't have a Phong Tag (ie. CreatePhongNormals() returns a Null), you can either skip it, or generate normals based on averaging the face normals (I'd suggest writing your own routine that does this, allocating, filling in and returning the same NormalStruct pointer/array).
                            Be sure to GeFree(pNorms) when done.
                            • H Offline
                              Helper
                              On 11/06/2010 at 04:36, xxxxxxxx wrote:
                              thanks giblet for your input.. at the moment i am averaging the neighbouring polygon normals and it works like this on a standard sphere for example:
                              this is how i calculate it:
                                            neighbor.GetPointPolys(i, &dadr, &dcnt);
                                            polyNormal=0;
                                            for (int j=0;j<dcnt;j++)
                                                if (dadr[j]<maxcount)
                                                    polyNormal += polygonNormal(nCalc1,nCalc2,padr,pol,dadr[j]);
                                            polyNormal /= dcnt;
                              where polygonNormal(...) is returning the correct mormal for each polygon as it is working in my plugin.
                              it seems to me that there is an invisible cut going thru the mesh which results in wrong or no neighbour
                              any ideas?
                              cheers,
                              ello
                              btw: sorry for the hijacking here...
                              • H Offline
                                Helper
                                On 11/06/2010 at 05:01, xxxxxxxx wrote:
                                Hmmm.. not sure. Are you calling neighbor.Init() before trying to use it?
                                Here's some code I've been using (several class member variables are set up elsewhere, but it should be self-explanitory)...
                                Bool MeshMap::GetSrcVertexNormals(void)
                                     LONG i, j, faceCnt, *pFaces = NULL;
                                     Vector vNorm, *pNorm;
                                     // initialize neighbor class... this is used to compute m_SrcvNorms
                                     if( !m_Neighbor.Init(m_numSrcVerts, m_SrcPolys, m_numSrcPolys, NULL) )
                                          return false;
                                     StatusSetText("Computing Vertex Normals...");
                                     pNorm = &m;_pSrcvNorms[0];
                                     for(i=0; i<m_numSrcVerts; i++)
                                          vNorm = Vector();          // (re)intitialize
                                          m_Neighbor.GetPointPolys(i, &pFaces;, &faceCnt;);
                                          if( faceCnt )
                                               for(j=0; j<faceCnt; j++)
                                                    Vector n = CalcFaceNormal(m_pxfSrcVerts, m_SrcPolys[pFaces[j]]);
                                                    vNorm += !n;
                                               vNorm /= faceCnt;     // average the normal(s)
                                               *pNorm = !vNorm;     // normalize and store
                                          else
                                               *pNorm = Vector(0.0,1.0,0.0);
                                          pNorm++;
                                     return true;
                                EDIT: Note... this code only generates a normal-per-vertex, which is contrary to my suggestion in my previous reply (this particular implementation didn't need to concern itself with phong-edge-breaks).
                                • H Offline
                                  Helper
                                  On 11/06/2010 at 05:59, xxxxxxxx wrote:
                                  thank you very much. i'll see if i can fix it with this input. i remember i didnt normalize it so maybe that coul cause it...
                                  • H Offline
                                    Helper
                                    On 26/06/2010 at 18:25, xxxxxxxx wrote:
                                    Hi Giblet,
                                    Thank you for offering your struct for us to see.   After I add your struct to my code and then use
                                    NormalStruct \*pNorms = (NormalStruct \* )ToPoly(op)->CreatePhongNormals()
                                    how do I use the NormalStruct pNorms?
                                    could you give me an example of how I would then move a point along the normal that I found?
                                    Thanks,
                                    ~Shawn
                                    • H Offline
                                      Helper
                                      On 26/06/2010 at 22:51, xxxxxxxx wrote:
                                      Hi Shawn,
                                      The pNorms pointer will point to 'an array' of NormalStruct(s) - one for each polygon of the mesh.
                                      A 'Normal' (call it vNorm) is a 'Unit Vector' (a vector who's length == 1.0) and the x/y/z values define a 'direction'.
                                      So, given the above, if you multiply a float (Real rDist) distance value times a Normal (who's length is 1.0), you get a new Vector/Vertex that is rDist distance in vNorm direction.
                                      I often use the following macro:
                                      #define ray_project(vStart, vDir, rDist)     ((vStart) + ((vDir) * (rDist))) //given the start point of a line, the direction and a distance, return end point
                                      ...where:
                                      vStart - is any Vector/Point/Vertex that defines the start position
                                      vDir - is any Normal Vector
                                      vDist - is the floating point (Real) distance value that I want to travel/project.
                                      ...so example code might look something like so:
                                      Vector *pPoints = op->GetPointW();
                                      CPolygon *pPolys = op->GetPolygonW();
                                      LONG pNdx = 0; // poly index
                                      CPolygon *pPoly = &pPolys;[pNdx];
                                      Vector vStart = pPoints[pPoly->a];
                                      Vector vDir = pNorms[pNdx].a;
                                      Real rDist = 5.0;
                                      Vector vEnd = ray_project(vStart, vDir, rDist);
                                      ...so, vEnd would be a Point that is 5.0 distance from the first Point in the first Polygon of the mesh, along (in the direction of) the Normal of that Point.
                                      • H Offline
                                        Helper
                                        On 26/06/2010 at 23:04, xxxxxxxx wrote:
                                        ...or something like that :).
                                        Basically, anywhere you get a poly reference, you can also get the NormalStruct the same way - the difference between a CPolygon and a NormalStruct is that the elements (a,b,c,d) of the CPolygon are 'indices' into the points array and the elements of the NormalStruct are the actual Normal Vectors themselves, so:
                                        NormalStruct ns = pNorms[x]; // x == whatever polygon you are interested in
                                        Vector vNormA = ns.a; // Normal for Point a of Polygon
                                        Vector vNormB = ns.b; // Normal for Point b of Polygon
                                        Vector vNormC = ns.c; // Normal for Point c of Polygon
                                        Vector vNormD = ns.d; // Normal for Point d of Polygon
                                        Cheers.
                                        • H Offline
                                          Helper
                                          On 27/06/2010 at 03:40, xxxxxxxx wrote:
                                          BTW, I also remembered this topic (Normals / NormalStruct) comming up before, so I went back and found this thread, that has a lot of the same info in it (including a routine I used to generate a NormalStruct array if CreatePhongNormals() fails).
                                          • H Offline
                                            Helper
                                            On 27/06/2010 at 05:04, xxxxxxxx wrote:
                                            Awesome thanks a lot for you help Giblet!    That helped a lot!
                                            ~Shawn
