    XPresso tag
    31 Posts 0 Posters 16.3k Views
    • H Offline
      Helper
      On 22/07/2008 at 06:48, xxxxxxxx wrote:
      Hey Matthias how are things going? 😐
      I'm working on it also. Do you or someone else know why this resulting DescID depth is zero? Look:
      (we allready have a Node(node) and a Port (port).
      long portid = port->GetMainID();
      GvOperatorData *od = n->GetOperatorData();
      if (!od) break;
      DescID descid = od->GetDescID(node, GV_PORT_INPUT, portid);
      GePrint("DescID depth: " + LongToString(descid.GetDepth()));
      Regards,
      Jan
      • H Offline
        Helper
        On 22/07/2008 at 06:54, xxxxxxxx wrote:
        The previous post should do the trick, because I can use the descid to: FindTrack(descid), and to: CTrack::Alloc(ob, decid).
        Or do I see this wrong?
        Regards,
        Jan
        • H Offline
          Helper
          On 22/07/2008 at 16:01, xxxxxxxx wrote:
          Djee, I only need to know dynamically a port's animated parameter, like:
          ID_BASEOBJECT_POSITION or
          CAMERA_FOCUS.
          That can be done can't it ??
          I just need to create a track and a key programaticaly.
          When i started this, I thougt it was peanuts.
          jan
          • H Offline
            Helper
            On 25/07/2008 at 03:00, xxxxxxxx wrote:
            Matthias, still no sign of the developers?
            Ok, in the meanwhile, I have setup an elaborate system of recognizing a port by it's name string!
            1. I get the port's name from the GvPortDescription
            2. construct the description id from a list of known port names and get the animated parameter id (like "Position . X")
            3.Then I can create a track and set a key.
            Well, it's a long list and there are a lot of if's and 'switch's but it works for now.
            There are big disadvantages: it is slow, only the english language can be used and it's practically impossible to support all posible animatable parameters. (and it is unelegant)
            regards,
            Jan
            • H Offline
              Helper
              On 25/07/2008 at 05:16, xxxxxxxx wrote:
              I still have no answer for you but I am fiddling around with it too.
              Btw. depending from where you call GetOperatorData() it is not allowed to call the virtual functions. See the docu note:
              Note: You can only use the virtual functions of this object if you are in the same module that registered the node!
              cheers,
              Matthias
              • H Offline
                Helper
                On 25/07/2008 at 06:37, xxxxxxxx wrote:
                Yes, I am aware of your alert.
                But I'm not sure. At the moment I use the GvNode->GetPortDescription in my (dialog) plugin. Would that cause a problem ?
                Awaiting a word from you, I stopped experimenting with GetOperatorData(), because the DescID was not valid anyway.
                By the way, I need to set keys for C4D BaseObjects or derivates, so not created by my plug.
                Jan
                • H Offline
                  Helper
                  On 25/07/2008 at 07:12, xxxxxxxx wrote:
                  Quote: _But I'm not sure. At the moment I use the GvNode- >GetPortDescription in my (dialog) plugin. Would that cause a problem ?
                  _
                  This is ok to do.
                  > Quote: _By the way, I need to set keys for C4D BaseObjects or derivates, so not created by my plug.
                  _
                  So if I understand this right you want to check Xpresso Object nodes for their ports and then create tracks depending on the ports?
                  cheers,
                  Matthias
                  • H Offline
                    Helper
                    On 25/07/2008 at 09:17, xxxxxxxx wrote:
                    Tracks if they do not excist and keys, yes.
                    Something like the setdriven. But the keys are set by my plug at every frame in 'real time'.
                    Regards,
                    Jan
                    • H Offline
                      Helper
                      On 28/07/2008 at 03:00, xxxxxxxx wrote:
                      Hi Jan,
                      I am afraid I have bad news. I just got the answer from the developers that it is not possible to get the description IDs from the port IDs.
                      cheers,
                      Matthias
                      • H Offline
                        Helper
                        On 30/07/2008 at 04:13, xxxxxxxx wrote:
                        Hi Matthias,
                        Well, I'm a bit silenced. So i shall have to use the elaborate string compare method to get the port DescsiD.
                        Some thougths.
                        It is strange, because C4D does it self all the time whenever a key must be set. How does C4D 'know' what keys to set autokeying is ON. I think it iterates through ALL objects and compares ALL animatable parameters of an object and creates tracks and keys for those parameters which have changed. OK, then we have a parameter that has changed. Now, if you allowe me to ask, how does C4D internally construct (programatically) the DescID?
                        Is there a kind of shortcut to find out if an object in the objectManager has a gvNode representation ?
                        Can you, or the team, suggest another way to get to my goal, Where would you look?
                        Thanks anyway and regards,
                        Jan
                        • H Offline
                          Helper
                          On 06/08/2008 at 01:48, xxxxxxxx wrote:
                          Hi Matthias,
                          Is it not possible to answer the questions 2 and 3 from my previous post ?
                          Jan
