    Light.. back the Normal
    25 Posts 0 Posters 14.8k Views
    • H Offline
      Helper
      On 25/08/2006 at 06:45, xxxxxxxx wrote:
      Ok, i understand.. but how i can redo the call?
      I don't make any call so i don't know how i can re-make the call 🙂
      Renato
      • H Offline
        Helper
        On 07/09/2006 at 14:44, xxxxxxxx wrote:
        (Removed some bump messages. Not to be seen as a criticism; by all means keep posting them if I'm slow. I'm terribly sorry for the delay.)
        Ok, I see. So you're not calling the illumination function yourself but just looking in the lights returned by VolumeData::GetLight()? In that case, you're right that it wouldn't be remaking the call, of course. But what happens if you add an extra call to IlluminateSurfacePoint(), with the normal reversed, for the RayLights that are wrong in the pre-calculated GetLight() array? Wouldn't you then get the right color?
        • H Offline
          Helper
          On 07/09/2006 at 15:17, xxxxxxxx wrote:
          IlluminateSurfacePoint it's a 9.6 function. In the new sdk there is also a flag to prevent the normal.
          Did you mean Illuminate on the 9.1 sdk?
          Renato
          • H Offline
            Helper
            On 08/09/2006 at 00:08, xxxxxxxx wrote:
            Sorry, I only looked back at the 9.5 API. (To my defense, only really 9.6 is supported. The rest is bonus... 😉
            But yes, Illuminate() would be my guess in 9.1 then. Perhaps, even if it doesn't give you totally accurate results for <9.6, it will be good enough to fake backlight? (Though I guess not being foreward compatible in rendering results might be bad as well.)
            • H Offline
              Helper
              On 08/09/2006 at 00:53, xxxxxxxx wrote:
              But i need to get the returned color because i need to take account of light cone, faloff and some others things.
              Maybe faster that i make my self this count or another illuminate will no slower my material?
              Thanks
              Renato
